[STM32L0] 用STM32L053做矩阵键盘的代码为什么IO口读不出数据
 楼主| flycamelaaa 发表于 2024-7-28 14:06 | 显示全部楼层 |阅读模式
麻烦各位帮忙看看
#include "KEY.h"
#define KEY_PIN_1            GPIO_PIN_0
#define KEY_PIN_2            GPIO_PIN_1
#define KEY_PIN_3            GPIO_PIN_2
#define KEY_PIN_4            GPIO_PIN_3
#define KEY_PIN_5            GPIO_PIN_4
#define KEY_PIN_6            GPIO_PIN_5
#define KEY_PIN_7            GPIO_PIN_6
#define KEY_PIN_8            GPIO_PIN_7
#define KEY_PIN_ALL         KEY_PIN_1|KEY_PIN_2|KEY_PIN_3|KEY_PIN_4|KEY_PIN_5|KEY_PIN_6|KEY_PIN_7|KEY_PIN_8
#define KEY_PORT             GPIOB
void GPIO_Init(void)
  GPIO_InitTypeDef GPIO_InitStruct;
  __HAL_RCC_GPIOB_CLK_ENABLE();
        __HAL_RCC_GPIOA_CLK_ENABLE();
        //__HAL_RCC_GPIOH_CLK_ENABLE();
  GPIO_InitStruct.Pin = KEY_PIN_1|KEY_PIN_2|KEY_PIN_3|KEY_PIN_4;
  GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
  GPIO_InitStruct.Pull = GPIO_NOPULL;
  GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;
        HAL_GPIO_Init(KEY_PORT, &GPIO_InitStruct);
        GPIO_InitStruct.Pin = GPIO_PIN_5;
        HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
        GPIO_InitStruct.Pin = KEY_PIN_5|KEY_PIN_6|KEY_PIN_7|KEY_PIN_8;
  GPIO_InitStruct.Mode = GPIO_MODE_INPUT;
  GPIO_InitStruct.Pull = GPIO_PULLDOWN;
  //GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;
unsigned char HL_Scan(void)
        unsigned char KeyVal=0;
        unsigned key=0;
        //unsigned int WriteVal=0;
        if(key==0)
                HAL_GPIO_WritePin(KEY_PORT,KEY_PIN_1|KEY_PIN_2|KEY_PIN_3|KEY_PIN_4,GPIO_PIN_SET);
                if(HAL_GPIO_ReadPin(KEY_PORT,KEY_PIN_5|KEY_PIN_6|KEY_PIN_7|KEY_PIN_8)==0)
                        key=0;
                        return 0;
                else
                        HAL_Delay(5);
                                key=0;
                                return 0;
                        else
                                key=1;
        if(key==1)
                HAL_GPIO_WritePin(KEY_PORT,KEY_PIN_1,GPIO_PIN_SET);
                HAL_GPIO_WritePin(KEY_PORT,KEY_PIN_2|KEY_PIN_3|KEY_PIN_4,GPIO_PIN_RESET);
                switch(HAL_GPIO_ReadPin(KEY_PORT,KEY_PIN_5|KEY_PIN_6|KEY_PIN_7|KEY_PIN_8)&0xf0)
                        case 0x10: KeyVal=15;        break;
                        case 0x20: KeyVal=11;        break;
                        case 0x40: KeyVal=7;        break;
                        case 0x80: KeyVal=3;        break;
                HAL_GPIO_WritePin(KEY_PORT,KEY_PIN_2,GPIO_PIN_SET);
                HAL_GPIO_WritePin(KEY_PORT,KEY_PIN_1|KEY_PIN_3|KEY_PIN_4,GPIO_PIN_RESET);
                        case 0x10: KeyVal=14;        break;
                        case 0x20: KeyVal=10;        break;
                        case 0x40: KeyVal=6;        break;
                        case 0x80: KeyVal=2;        break;
                HAL_GPIO_WritePin(KEY_PORT,KEY_PIN_3,GPIO_PIN_SET);
                HAL_GPIO_WritePin(KEY_PORT,KEY_PIN_1|KEY_PIN_2|KEY_PIN_4,GPIO_PIN_RESET);
                        case 0x10: KeyVal=13;        break;
                        case 0x20: KeyVal=9;        break;
                        case 0x40: KeyVal=5;        break;
                        case 0x80: KeyVal=1;        break;
                HAL_GPIO_WritePin(KEY_PORT,KEY_PIN_4,GPIO_PIN_SET);
                HAL_GPIO_WritePin(KEY_PORT,KEY_PIN_1|KEY_PIN_2|KEY_PIN_3,GPIO_PIN_RESET);
                        case 0x10: KeyVal=12;        break;
                        case 0x20: KeyVal=8;        break;
                        case 0x40: KeyVal=4;        break;
                        case 0x80: KeyVal=0;        break;
                key=0;
        return KeyVal;
stormwind123 发表于 2024-7-28 14:26 | 显示全部楼层
是不是不引脚配置错误
laocuo1142 发表于 2024-7-28 14:27 | 显示全部楼层
可能是初始化代码问题,确保没有遗漏或错误配置。
jcky001 发表于 2024-7-28 14:30 | 显示全部楼层
检查电源和地符不符要求
elephant00 发表于 2024-7-28 14:33 | 显示全部楼层
如果您的设计中使用了中断来读取键盘,请检查中断是否被正确配置,并且中断优先级设置是否合适。
powerantone 发表于 2024-7-28 15:00 | 显示全部楼层
检查矩阵键盘与STM32L053之间的连接是否稳固可靠,没有接触不良或短路现象。
probedog 发表于 2024-7-28 16:00 | 显示全部楼层
如果在读取键盘时没有实现去抖动,可能会导致读取到错误的数据。在读取按键之前,应该实现一个去抖动机制,例如通过延时函数等待一段时间再读取。
两只袜子 发表于 2024-7-28 17:05 | 显示全部楼层
扫描逻辑错误?
yiy 发表于 2024-7-28 21:41 | 显示全部楼层
有上拉电阻吗
yiy 发表于 2024-7-28 21:43 | 显示全部楼层
