若按字节写的话,写EEPROM每个字节耗时约6ms。块操作的方式将一个基本页(64字节)写入的理论时间也是6ms。但是在操作过程中也出现了写死机的情况。- int16 EepRomWrite(void *pWriteData, uint16 nWriteLen, SaveType nType)
- uint8 i;
- uint8 *p;
- if (pWriteData==NULL || nWriteLen==0 || nWriteLen>=EEPROM_SIZE)
- return -1;
- SetGpioLevel(PA,1,0);
- if (EepRomUnLock() == 0)
- //UART1_SendStr("eeprom fail unlock", 19);
- return -1;
- // 以下两行代码导致死机
- FLASH_CR2 |=0x01;
- FLASH_NCR2 &= ~(0x01);
- SetGpioLevel(PA,1,1);
- p = (uint8 *)(EEPROM_STARTADDR+nType*64);
- for(i=0; i<nWriteLen+(EEPROM_BLOCK_SIZE-nWriteLen%EEPROM_BLOCK_SIZE); i++, p++) // !!!!!
- *p = ((uint8 *)pWriteData)[i];
- if (i>=nWriteLen)
- *p = 0x00;
- if ((i+1)%EEPROM_BLOCK_SIZE == 0)
- while((FLASH_IAPSR & 0x40) ==0);
- while((FLASH_IAPSR & 0x04) ==1);
- FLASH_CR2 &= ~(0x01);
- EepRomLock();
- return 0;
