#技术资源# #申请原创#
试了好久,终于成功搭建windows下的GCC开发环境。开发环境如下:
系统:Win11
编译环境:GCC
仿真环境:pyOCD
整个开发环境的搭建,可以参考:https://mp.csdn.net/mp_blog/creation/editor/142444700
gcc开发环境下MCU编程,除了要搭建好开发环境之外,还有三个重要的文件,分别是makefile、.ld文件及.s文件。
在HC32F448提供的DDL demo中,有eclipse工程,里边包含了.ld文件及.s文件,还差了makefile文件。
在此奉献上我调试好的makefile文件,抛砖引玉,让更多人来使用及优化。也希望大神能提出不足及指正。
- # File automatically-generated by tool: [projectgenerator] version: [4.5.0-B34] date: [Sun Sep 22 18:25:32 CST 2024]
- # Generic Makefile (based on gcc)
- # ChangeLog :
- # 2017-02-10 - Several enhancements + project update mode
- # 2015-07-22 - first version
- # target
- TARGET = adc_awd
- # building variables
- # debug build?
- DEBUG = 1
- # optimization
- OPT = -O0
- # paths
- # Build path
- BUILD_DIR = build
- # source
- # C sources
- C_SOURCES = \
- ../source/main.c \
- ../../../../../../drivers/bsp/components/tca9539/tca9539.c \
- ../../../../../../drivers/bsp/ev_hc32f448_lqfp80/ev_hc32f448_lqfp80.c \
- ../../../../../../drivers/bsp/ev_hc32f448_lqfp80/ev_hc32f448_lqfp80_tca9539.c \
- ../../../../../../drivers/cmsis/Device/HDSC/hc32f4xx/Source/system_hc32f448.c \
- ../../../../../../drivers/hc32_ll_driver/src/hc32_ll.c \
- ../../../../../../drivers/hc32_ll_driver/src/hc32_ll_adc.c \
- ../../../../../../drivers/hc32_ll_driver/src/hc32_ll_aos.c \
- ../../../../../../drivers/hc32_ll_driver/src/hc32_ll_clk.c \
- ../../../../../../drivers/hc32_ll_driver/src/hc32_ll_efm.c \
- ../../../../../../drivers/hc32_ll_driver/src/hc32_ll_fcg.c \
- ../../../../../../drivers/hc32_ll_driver/src/hc32_ll_fcm.c \
- ../../../../../../drivers/hc32_ll_driver/src/hc32_ll_gpio.c \
- ../../../../../../drivers/hc32_ll_driver/src/hc32_ll_i2c.c \
- ../../../../../../drivers/hc32_ll_driver/src/hc32_ll_icg.c \
- ../../../../../../drivers/hc32_ll_driver/src/hc32_ll_interrupts.c \
- ../../../../../../drivers/hc32_ll_driver/src/hc32_ll_keyscan.c \
- ../../../../../../drivers/hc32_ll_driver/src/hc32_ll_pwc.c \
- ../../../../../../drivers/hc32_ll_driver/src/hc32_ll_tmr0.c \
- ../../../../../../drivers/hc32_ll_driver/src/hc32_ll_usart.c \
- ../../../../../../drivers/hc32_ll_driver/src/hc32_ll_utility.c
- # ASM sources
- ASM_SOURCES =
- # ASM sources
- ASMM_SOURCES = \
- startup_hc32f448.S
- # binaries
- PREFIX = arm-none-eabi-
- # The gcc compiler bin path can be either defined in make command via GCC_PATH variable (> make GCC_PATH=xxx)
- # either it can be added to the PATH environment variable.
- ifdef GCC_PATH
- CC = $(GCC_PATH)/$(PREFIX)gcc
- AS = $(GCC_PATH)/$(PREFIX)gcc -x assembler-with-cpp
- CP = $(GCC_PATH)/$(PREFIX)objcopy
- SZ = $(GCC_PATH)/$(PREFIX)size
- else
- CC = $(PREFIX)gcc
- AS = $(PREFIX)gcc -x assembler-with-cpp
- CP = $(PREFIX)objcopy
- SZ = $(PREFIX)size
- endif
- HEX = $(CP) -O ihex
- BIN = $(CP) -O binary -S
- # CFLAGS
- # cpu
- CPU = -mcpu=cortex-m4
- # fpu
- FPU = -mfpu=fpv4-sp-d16
- # float-abi
- FLOAT-ABI = -mfloat-abi=hard
- # mcu
- MCU = $(CPU) -mthumb $(FPU) $(FLOAT-ABI)
- # macros for gcc
- # AS defines
- AS_DEFS =
- # C defines
- C_DEFS = \
- -D__DEBUG \
- -DHC32F448 \
- -DUSE_DDL_DRIVER
- # AS includes
- AS_INCLUDES =
- # C includes
- C_INCLUDES = \
- -I../../../../../../drivers/cmsis/Device/HDSC/hc32f4xx/Include \
- -I../../../../../../drivers/cmsis/Include \
- -I../../../../../../drivers/hc32_ll_driver/inc \
- -I../source \
- -I../../../../../../drivers/bsp/ev_hc32f448_lqfp80 \
- -I../../../../../../drivers/bsp/components/tca9539
- # compile gcc flags
- ASFLAGS = $(MCU) $(AS_DEFS) $(AS_INCLUDES) $(OPT) -Wall -fdata-sections -ffunction-sections
- CFLAGS += $(MCU) $(C_DEFS) $(C_INCLUDES) $(OPT) -Wall -fdata-sections -ffunction-sections
- ifeq ($(DEBUG), 1)
- CFLAGS += -g -gdwarf-2
- endif
- # Generate dependency information
- CFLAGS += -MMD -MP -MF"$(@:%.o=%.d)"
- # LDFLAGS
- # link script
- LDSCRIPT = ./config/linker/HC32F448xA.ld
- # libraries
- LIBS = -lc -lm -lnosys
- LIBDIR =
- LDFLAGS = $(MCU) -specs=nano.specs -T$(LDSCRIPT) $(LIBDIR) $(LIBS) -Wl,-Map=$(BUILD_DIR)/$(TARGET).map,--cref -Wl,--gc-sections
- # default action: build all
- all: $(BUILD_DIR)/$(TARGET).elf $(BUILD_DIR)/$(TARGET).hex $(BUILD_DIR)/$(TARGET).bin
- # build the application
- # list of objects
- OBJECTS = $(addprefix $(BUILD_DIR)/,$(notdir $(C_SOURCES:.c=.o)))
- vpath %.c $(sort $(dir $(C_SOURCES)))
- # list of ASM program objects
- OBJECTS += $(addprefix $(BUILD_DIR)/,$(notdir $(ASM_SOURCES:.s=.o)))
- vpath %.s $(sort $(dir $(ASM_SOURCES)))
- OBJECTS += $(addprefix $(BUILD_DIR)/,$(notdir $(ASMM_SOURCES:.S=.o)))
- vpath %.S $(sort $(dir $(ASMM_SOURCES)))
- $(BUILD_DIR)/%.o: %.c Makefile | $(BUILD_DIR)
- $(CC) -c $(CFLAGS) -Wa,-a,-ad,-alms=$(BUILD_DIR)/$(notdir $(<:.c=.lst)) lt; -o $@
- $(BUILD_DIR)/%.o: %.s Makefile | $(BUILD_DIR)
- $(AS) -c $(CFLAGS) lt; -o $@
- $(BUILD_DIR)/%.o: %.S Makefile | $(BUILD_DIR)
- $(BUILD_DIR)/$(TARGET).elf: $(OBJECTS) Makefile
- $(CC) $(OBJECTS) $(LDFLAGS) -o $@
- $(SZ) $@
- $(BUILD_DIR)/%.hex: $(BUILD_DIR)/%.elf | $(BUILD_DIR)
- $(HEX) lt; $@
- $(BUILD_DIR)/%.bin: $(BUILD_DIR)/%.elf | $(BUILD_DIR)
- $(BIN) lt; $@
- $(BUILD_DIR):
- mkdir $@
- # clean up
- clean:
- rd /s/q $(BUILD_DIR)
- # dependencies
- -include $(wildcard $(BUILD_DIR)/*.d)
- # *** EOF ***
在此上传文本,方便下载。
Makefile.zip
(1.8 KB, 下载次数: 2)
将此文件放到HC32F448_DDL_Rev1.1.0\projects\ev_hc32f448_lqfp80\examples\adc\adc_awd\GCC目录下,其他工程目录,需要更改相应的内容。
在HC32F448_DDL_Rev1.1.0\projects\ev_hc32f448_lqfp80\examples\adc\adc_awd\GCC目录下右键选择在终端中打开,执行make
编译成功后显示
下载:
观察串口log
可以看到gcc-ARM编译的文件在F448上已经成功执行。
