- * PIC12F1822 WS2812b RC Led Strip Project
- - Version 1.0
- - 2 April 2020
- - Project settings are defined in the system.h file
- - based on work from https://github.com/DzikuVx/drone_led_strip_controller
- Copyright 2020 Patrick Tissot
- This program is free software: you can redistribute it and/or modify it under the terms of the GNU General
- Public License as published by the Free Software Foundation, either version 2 of the License, or (at your
- option) any later version.
- This program is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the
- implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License
- for more details. You should have received a copy of the GNU General Public License along with this program.
- If not, see <http://www.gnu.org/licenses/>.
- Development Environment
- To compile this you need:
- - XC8 2.20 PRO or higher (www.microchip.com) with -s optimization for size
- - Microchip MPLAB X IDE Version 5.35 or higher (www.microchip.com)
- // Global includes
- #include <xc.h>
- #include <stdint.h>
- // #pragma config statements should precede project file includes.
- // Use project enums instead of #define for ON and OFF
- // CONFIG1
- #pragma config FOSC = INTOSC // Oscillator Selection (INTOSC oscillator: I/O function on CLKIN pin)
- #pragma config WDTE = ON // Watchdog Timer Enable (WDT enabled)
- #pragma config PWRTE = ON // Power-up Timer Enable (PWRT enabled)
- #pragma config MCLRE = ON // MCLR Pin Function Select (MCLR/VPP pin function is MCLR)
- #pragma config CP = OFF // Flash Program Memory Code Protection (Program memory code protection is disabled)
- #pragma config CPD = OFF // Data Memory Code Protection (Data memory code protection is disabled)
- #pragma config BOREN = ON // Brown-out Reset Enable (Brown-out Reset enabled)
- #pragma config CLKOUTEN = OFF // Clock Out Enable (CLKOUT function is disabled. I/O or oscillator function on the CLKOUT pin)
- #pragma config IESO = OFF // Internal/External Switchover (Internal/External Switchover mode is disabled)
- #pragma config FCMEN = OFF // Fail-Safe Clock Monitor Enable (Fail-Safe Clock Monitor is disabled)
- // CONFIG2
- #pragma config WRT = OFF // Flash Memory Self-Write Protection (Write protection off)
- #pragma config PLLEN = ON // PLL Enable (4x PLL enabled)
- #pragma config STVREN = ON // Stack Overflow/Underflow Reset Enable (Stack Overflow or Underflow will cause a Reset)
- #pragma config BORV = HI // Brown-out Reset Voltage Selection (Brown-out Reset Voltage (Vbor), high trip point selected.)
- #pragma config LVP = ON // Low-Voltage Programming Enable (High-voltage on MCLR/VPP must be used for programming)
- #define _XTAL_FREQ 32000000UL
- * Structure of the LED array
- * cRGB: RGB for WS2812S/B/C/D, SK6812, SK6812Mini, SK6812WWA, APA104, APA106
- * cRGBW: RGBW for SK6812RGBW
- struct cRGB { uint8_t g; uint8_t r; uint8_t b; };
- // Change this setting based on your LED strip length (be aware of RAM size limitation!)
- #define NUM_PIXELS 8
- // Assembly function used to send the 24bits info to WS2812 leds
- void send_frame(void);
- // System definitions
- #define FCY 8000000UL
- #define TMR0_PRESCALER 256
- // 32 MHz / 4 = 8 MHz => 0.125 �s instruction cycle
- #define TICK 1 // 1ms interrupt Tick rate
- #define COUNT (FCY/1000000UL*TICK*1000/TMR0_PRESCALER)
- #if (COUNT > 255)
- #error "Change TMR0 prescaler or FCY"
- #endif
- #define TMR0_RELOAD (255-COUNT)
- // Hardware mapping definitions
- // LED PIN is fixed to RA2 (see Send_Frame.asm)
- #define INPUT_PIN RA5 // connected to PWM output from RC receiver or left floating
- #define LED_MULTIPLIER 4
- #define BUTTON_PIN RA4 // connected to push button (to ground), uses internal pull-up
- #define SLEEP_TIME 40
- #define SPEED_MAX 20
- #define SPEED_MID 10
- #define COLORS 7
- #define LONG_PUSH_THRESHOLD 20
- #define MAX_CYCLE 255
- #define MODES 11
- #define PWM_PRESS_MIN 1750 // pulse 1750ms mini to detect "button" press through RC
- #define PWM_PRESS_MAX 2200 // pulse 2200ms max to detect "button" press through RC
- #define PWM_SPEED_MIN 800 // pulse 800ms maps to minimum speed (led pattern change) through RC
- #define PWM_SPEED_MAX 1500 // pulse 1500ms maps to maximum speed (led pattern change) through RC
- // EEPROM parameters
- #define EEPROM_MODE_ADDRESS 0
- #define EEPROM_COLOR_ADDRESS 1
- #define EEPROM_SPEED_ADDRESS 2
- // State machine used for button press decoding
- #define IDLE 0
- #define PRESS 1
- #define SHORTPRESS 2
- #define LONGPRESS 3
- // COLOR patterns (can be adjusted if necessary)
- const uint8_t colors[COLORS][3] = {
- {1, 0, 0}, // RED
- {0, 1, 0}, // GREEN
- {0, 0, 1}, // BLUE
- {1, 0, 1}, // PURPLE
- {1, 1, 0}, // YELLOW
- {0, 1, 1}, // CYAN
- {1, 1, 1} // WHITE
- // Globals
- volatile uint8_t COLOR;
- volatile uint8_t count;
- struct cRGB currentColor;
- struct cRGB off;
- struct cRGB background;
- struct cRGB output[NUM_PIXELS] __at(0x40); // force LED array to be at fixed RAM address (for assembly routine taking care of LED refresh)
- uint8_t my_brightness = 250; // this can be changed to accomodate lower brightness level
- uint8_t previous_mode;
- uint8_t mode = 0;
- uint8_t pushStartCycle;
- uint8_t i;
- uint8_t previous_colorIndex;
- uint8_t colorIndex = 0;
- uint8_t cycle = 0;
- uint8_t currentCycle;
- uint16_t previous_speed;
- uint16_t speed;
- uint8_t controllState;
- // these variables will be accessed under interrupt, need to be declared as volatile
- volatile uint16_t risingStart = 0;
- volatile uint16_t channelLength = 0;
- volatile uint8_t timer_1ms;
- // running average of data (using 20% new value / 80% old value)
- uint16_t smooth(uint16_t data, uint16_t smoothedVal) {
- smoothedVal = ((data * 2) / 10) + (smoothedVal * 8) / 10;
- return smoothedVal;
- // Interrupt Service Request handler
- void __interrupt() isr(void) {
- // Is this interrupt on change pin interrupting?
- if (IOCIE && IOCIF) {
- IOCIF = 0;
- IOCAF = 0;
- TMR1ON = 0;
- if (INPUT_PIN) { // rising edge detected
- risingStart = TMR1;
- } else { // falling edge detected
- uint16_t val;
- if (TMR1 > risingStart)
- val = TMR1 - risingStart;
- else
- val = (65535U - risingStart) + TMR1;
- // val now contains PPM pulse duration
- channelLength = smooth(val, channelLength);
- // to get channel value, perform some filtering
- TMR1ON = 1;
- // Is this timer1 interrupting?
- if (TMR0IE && TMR0IF) {
- // Reset the timer1 interrupt flag
- TMR0IF = 0;
- TMR0 = TMR0_RELOAD; // reload timer 0 for next TICK interrupt period
- LATAbits.LATA1 ^= 1; // for debug and interrupt monitoring
- timer_1ms = 1;
- // Init System timer (TMR0) used by Application for TICK generation
- void Init_Timer(void) {
- // Configure Timer 0 for system timer
- TMR0IF = 0; // Clean TMR0 flag
- T0CS = 0; // clock source = internal system clock
- // prescaler
- PSA = 0; // prescaler assigned to TMR0
- OPTION_REGbits.PS = 0b111; // Prescaler 1:256
- TMR0 = TMR0_RELOAD; // reload value = TICK ms
- // Enable System Timer Interrupts
- TMR0IE = 1; // Enable TMR0 Interrupt
- // Configure Timer 2 for Delay routine
- void Init_Timer2(void) {
- T2CON = 0b00110000; // prescaler 1/8 gives 1 us resolution
- // Duration is a multiple of 1 us
- // this routine will block until the time is ellapsed (only interrupts are allowed)
- void delay_us(uint8_t duration) {
- if (duration > 5)
- PR2 = duration - 4; // compensate for function overhead
- else
- PR2 = 1;
- TMR2 = 0; // reset Timer2
- TMR2IF = 0;
- TMR2ON = 1; // start Timer2
- while (!TMR2IF)
- NOP();
- TMR2ON = 0; // shutdown Timer2
- // Duration is a multiple of 1 ms
- void delay_ms(uint16_t duration) {
- uint16_t j;
- for (j = 0; j < (duration * 10); j++) {
- delay_us(100);
- CLRWDT();
- // Routine to write a single byte into EEPROM space
- void DATAEE_WriteByte(uint8_t bAdd, uint8_t bData) {
- uint8_t GIEBitValue = 0;
- EEADRL = bAdd; // Data Memory Address to write
- EEDATL = bData; // Data Memory Value to write
- EECON1bits.EEPGD = 0; // Point to DATA memory
- EECON1bits.CFGS = 0; // Deselect Configuration space
- EECON1bits.WREN = 1; // Enable writes
- GIEBitValue = INTCONbits.GIE;
- INTCONbits.GIE = 0; // Disable INTs
- EECON2 = 0x55;
- EECON2 = 0xAA;
- EECON1bits.WR = 1; // Set WR bit to begin write
- // Wait for write to complete
- while (EECON1bits.WR) {
- EECON1bits.WREN = 0; // Disable writes
- INTCONbits.GIE = GIEBitValue;
- // Routine to read a single byte from EEPROM space
- uint8_t DATAEE_ReadByte(uint8_t bAdd) {
- EEADRL = bAdd; // Data Memory Address to read
- EECON1bits.RD = 1; // EE Read
- NOP(); // NOPs may be required for latency at high frequencies
- NOP();
- return (EEDATL);
- // Initialize I/O ports
- void Init_Ports(void) {
- nWPUEN = 0; // PortA pull-ups enabled by individual PORT Latch values
- ANSELA = 0; // all pins digital
- WPUA = 0b00111000; // disable Weak pull-ups on outputs
- LATA = 0; // this will turn ON debug LED
- TRISA = 0b00111000; // Output bits RA0, RA2
- IOCAP = 0b00100000; // RA5 triggers interrupt for both rising and falling changes
- IOCAN = 0b00100000;
- IOCIF = 0;
- IOCIE = 1;
- void setColor(void) {
- currentColor.r = colors[colorIndex][0] * my_brightness;
- currentColor.g = colors[colorIndex][1] * my_brightness;
- currentColor.b = colors[colorIndex][2] * my_brightness;
- background.r = colors[colorIndex][0] * 50;
- background.g = colors[colorIndex][1] * 50;
- background.b = colors[colorIndex][2] * 50;
- // This will turn off all LEDs on the strip
- void modeOff(void) {
- for (i = 0; i < NUM_PIXELS; i++) {
- output[i] = off;
- // This will turn on all LEDs on the strip (with currentcolor setting)
- void modeOn(void) {
- output[i] = currentColor;
- // returns
- uint8_t getDivider(uint8_t denom, uint8_t cycle) {
- return cycle / denom;
- // This will turn on one single led in the strip in sequence
- void modeSingleWander(void) {
- currentCycle = getDivider(2, currentCycle);
- output[i] = background;
- output[currentCycle % NUM_PIXELS] = currentColor;
- // this will turn on 3 consecutive leds in the strip in sequence
- void modeRapid(void) {
- if (currentCycle == NUM_PIXELS << 2) {
- cycle = 0;
- currentCycle = 0;
- if (currentCycle < NUM_PIXELS) {
- if (currentCycle + 1 < NUM_PIXELS) {
- output[(currentCycle + 1) % NUM_PIXELS] = currentColor;
- if (currentCycle + 2 < NUM_PIXELS) {
- output[(currentCycle + 2) % NUM_PIXELS] = currentColor;
- // this will turn on 2 consecutive leds in the strip in sequence
- void modeBoldWander(void) {
- // this will turn on 4 consecutive leds in the strip in sequence
- void modeBolderWander(void) {
- output[i] = off;
- output[(currentCycle + 3) % NUM_PIXELS] = currentColor;
- // this will turn on 2 opposite leds in the strip in sequence
- void modeDoubleWander(void) {
- output[i] = off;
- output[(MAX_CYCLE - currentCycle) % NUM_PIXELS] = currentColor;
- // this will turn on 2 leds (with gap in between) in the strip in sequence
- void modeChase(void) {
- output[i] = off;
- output[(currentCycle + (NUM_PIXELS / 2)) % NUM_PIXELS] = currentColor;
- // this will flash all leds in the strip
- void modeFlash(void) {
- struct cRGB state = off;
- if ((currentCycle % 16 == 12) || (currentCycle % 16 == 15)) {
- state = currentColor;
- output[i] = state;
- // this will progressively turn ON and OFF (breathing effect) all leds in the strip
- void modeBreathing(void) {
- struct cRGB my_color;
- uint16_t value;
- currentCycle = currentCycle & 0x3F;
- if (currentCycle > 31)
- currentCycle = 63 - currentCycle;
- value = (uint16_t)(currentCycle * currentCycle) >> 2;
- currentCycle = value;
- my_color.r = colors[colorIndex][0] * currentCycle;
- my_color.g = colors[colorIndex][1] * currentCycle;
- my_color.b = colors[colorIndex][2] * currentCycle;
- output[i] = my_color;
- // this will display a rainbow effect on the led strip
- void modeRainbow(void) {
- static uint8_t offset;
- uint8_t index;
- index = (i + offset) & 0x07;
- my_color.r = colors[index][0] * 85;
- my_color.g = colors[index][1] * 85;
- my_color.b = colors[index][2] * 85;
- if (currentCycle % 5 == 0)
- offset++;
- uint8_t abs_u8(int8_t value) {
- if (value < 0)
- return (-value);
- else
- return (value);
- // do actual work
- void loop(void) {
- // Test RC input pulse duration
- // first, compare pulse to speed control range
- if ((channelLength > PWM_SPEED_MIN) && (channelLength < PWM_SPEED_MAX)) {
- speed = ((channelLength - PWM_SPEED_MIN) * SPEED_MAX) / (PWM_SPEED_MAX - PWM_SPEED_MIN);
- // then compare pulse to "button" press threshold (or actual button press)
- if (((channelLength > PWM_PRESS_MIN) && (channelLength < PWM_PRESS_MAX)) || (BUTTON_PIN == 0)) {
- if (controllState == IDLE) {
- controllState = PRESS;
- pushStartCycle = cycle;
- // decide button status based on previous state
- if ((channelLength < 1750) && (BUTTON_PIN == 1)) {
- if (controllState == PRESS) {
- controllState = SHORTPRESS;
- if (controllState == LONGPRESS) {
- controllState = IDLE;
- // if button is pressed
- // and this is a long press
- if (abs_u8(cycle - pushStartCycle) > LONG_PUSH_THRESHOLD) {
- // Change color procedure
- colorIndex++;
- if (colorIndex == COLORS) {
- colorIndex = 0;
- setColor();
- cycle = 0;
- pushStartCycle = 0;
- controllState = LONGPRESS;
- // if button is short pressed
- if (controllState == SHORTPRESS) {
- if (abs_u8(cycle - pushStartCycle) > 2) {
- // Change mode procedure
- mode++;
- if (mode == MODES) {
- mode = 0;
- cycle = 0;
- // memorize currentcycle
- currentCycle = cycle;
- // based on selected operating mode, dispatch to appropriate LED display routine
- switch (mode) {
- case 0:
- modeOn();
- break;
- case 1:
- modeSingleWander();
- break;
- case 2:
- modeBoldWander();
- break;
- case 3:
- modeDoubleWander();
- break;
- case 4:
- modeChase();
- break;
- case 5:
- modeFlash();
- break;
- case 6:
- modeBolderWander();
- break;
- case 7:
- modeRapid();
- break;
- case 8:
- modeBreathing();
- break;
- case 9:
- modeRainbow();
- break;
- case 10:
- modeOff();
- break;
- // Update LEDs
- send_frame();
- cycle++;
- // wait for next frame to display
- delay_ms(SLEEP_TIME - speed);
- // Set up the timer for input capture
- void Init_Timer1(void) {
- T1CON = 0b00110001; // Timer1 clock source is instruction clock (FOSC/4)
- // 1:8 Prescale value (1us timebase), Timer 1 ON
- // Main Rountine (the application)
- //DOM-IGNORE-BEGIN
- // _ __ __
- // _ __ ___ __ _(_)_ __ / / \ \
- // | '_ ` _ \ / _` | | '_ \ | | | |
- // | | | | | | (_| | | | | | | | | |
- // |_| |_| |_|\__,_|_|_| |_| | | | |
- // \_\ /_/
- void main(void) {
- // Set up the IO pins
- Init_Ports();
- OSCCON = 0b01110000; //Setup internal oscillator for 32MHz = 8M x 4
- Init_Timer2();
- Init_Timer1();
- // try to restore previous operating mode from EEPROM
- mode = DATAEE_ReadByte(EEPROM_MODE_ADDRESS);
- if (mode >= MODES) {
- mode = 0;
- previous_mode = mode;
- // try to restore previous color mode from EEPROM
- colorIndex = DATAEE_ReadByte(EEPROM_COLOR_ADDRESS);
- if (colorIndex >= COLORS) {
- colorIndex = 0;
- previous_colorIndex = colorIndex;
- // try to restore previous speed setting from EEPROM
- speed = DATAEE_ReadByte(EEPROM_SPEED_ADDRESS);
- if (speed > SPEED_MAX) {
- speed = SPEED_MID;
- previous_speed = speed;
- // prepare LED strip
- setColor();
- Init_Timer();
- // Enable the interrupts
- PEIE = 1;
- GIE = 1;
- // Program Main loop
- while (1) {
- // If 1ms timer expired, then launch loop
- if (timer_1ms) {
- timer_1ms = 0;
- loop();
- // is it time to save current settings to EEPROM?
- if (cycle == 255) {
- // if mode changed since last save, then store in EEPROM
- if (mode != previous_mode) {
- DATAEE_WriteByte(EEPROM_MODE_ADDRESS, mode);
- // if color changed since last save, then store in EEPROM
- if (colorIndex != previous_colorIndex) {
- DATAEE_WriteByte(EEPROM_COLOR_ADDRESS, colorIndex);
- // if speed changed since last save, then store in EEPROM
- if (speed != previous_speed) {
- DATAEE_WriteByte(EEPROM_SPEED_ADDRESS, speed);
