[开发资料] 芯源单片机Sleep应用笔记
 楼主| tpgf 发表于 2024-11-4 11:17 | 显示全部楼层 |阅读模式
uint16_t SleepTime = 0;
_Bool b_StartSleep = 0;
void Gpio_Init(void)
    GPIO_InitTypeDef GPIO_InitStructure = {0};
    __SYSCTRL_GPIOB_CLK_ENABLE();
    PB04_AFx_GPIO();
    GPIO_InitStructure.Pins = GPIO_PIN_4;
    GPIO_InitStructure.Mode = GPIO_MODE_INPUT_PULLUP; //SDA/SCL设置为下拉
    GPIO_InitStructure.IT   = GPIO_IT_RISING;        //SDA/SCL上升沿唤醒,表示设备开机,总线从低电平跳转到高电平(I2C中断不能唤醒深度睡眠)
    GPIO_Init(CW_GPIOB,&GPIO_InitStructure);
    //清除中断标志并使能NVIC
    GPIOB_INTFLAG_CLR(GPIOx_ICR_PIN4_Msk);
void SleepOff(void)
    SYSCTRL_HSI_Enable(SYSCTRL_HSIOSC_DIV12); //睡眠前,时钟源要降低到不大于4M
    BTIM_Cmd(CW_BTIM1, DISABLE);
//    //打开FLASH时钟
//    REGBITS_SET( CW_SYSCTRL->AHBEN, SYSCTRL_AHBEN_FLASH_Msk);
//    REGBITS_SET(CW_FLASH->CR1, FLASH_CR1_STANDBY_Msk); //打开FLASH低功耗使能控制
//    //关闭FLASH时钟
//    REGBITS_CLR( CW_SYSCTRL->AHBEN, SYSCTRL_AHBEN_FLASH_Msk);
//    __RCC_I2C_CLK_DISABLE();  //关闭不需要的时钟(关不关功耗都一样的)
//    __RCC_GPIOA_CLK_DISABLE();
//    __RCC_BTIM_CLK_DISABLE();
    PA00_SETHIGH();  //关闭SDQ
    PB03_SETLOW();   //关闭IO口输出,66断电(降低功耗)
    PB04_SETLOW();
    SCL_OutLow;  //关闭和66通信的I2C主机
    SDA_OutLow;
//    Gpio_Init();  //IO口中断配置
    IIC_Slave_Sleep_Entry(1, GPIO_MODE_INPUT_PULLUP, GPIO_IT_RISING | GPIO_IT_FALLING);
void SleepOpen(void)
    FLASH_SetLatency(FLASH_Latency_2); //唤醒后,时钟恢复到初始化状态
    SYSCTRL_HSI_Enable(SYSCTRL_HSIOSC_DIV1);
//    __RCC_GPIOA_CLK_ENABLE();
//    __RCC_BTIM_CLK_ENABLE();
    IIC_Slave_WakeUp_Handle();
    I2c_Init();
    BTIM_Cmd(CW_BTIM1, ENABLE);
    Power_Init();
void GoToSleep(void)
    if (Get_IIC_Slave_RxTxFlag())
        Set_IIC_Slave_RxTxFlag(0);
        SleepTime = 0;
    if(((SDA_READ == GPIO_Pin_RESET)&&(SCK_READ == GPIO_Pin_RESET))||((SDA_READ == GPIO_Pin_SET)&&(SCK_READ == GPIO_Pin_SET)))
        if(SleepTime == 0)
            SleepTime = 1;
    if(SleepTime > 0)
        SleepTime++;
    if(SleepTime > 2500)
        SleepTime = 0;
        SleepOff();   //睡眠前关闭外设功能
        SCB->SCR |= SCB_SCR_SLEEPDEEP_Msk;  //设置深度睡眠模式
        __WFI();      //进入睡眠
        SleepOpen();  //睡眠唤醒后打开外设功能
原文链接:https://blog.csdn.net/weixin_50707044/article/details/141261160
小小蚂蚁举千斤 发表于 2024-11-6 14:54 来自手机 | 显示全部楼层
sleep函数学习一下
OKAKAKO 发表于 2024-11-14 08:40 | 显示全部楼层
Sleep应用笔记了解一下
星辰大海不退缩 发表于 2024-11-22 16:42 来自手机 | 显示全部楼层
sleep笔记学习一下
中国龙芯CDX 发表于 2024-11-24 14:55 | 显示全部楼层
sleep函数不是使用滴答时钟进行的配置
