- #define uchar unsigned char
- #define uint unsigned int
- sbit dula=P2^6;
- sbit wela=P2^7;
- uchar code table[]={ 0x3f,0x06,0x5b,0x4f,
- 0x66,0x6d,0x7d,0x07,
- 0x7f,0x6f,0x77,0x7c,
- 0x39,0x5e,0x79,0x71};
- void delayms(uint xms)
- uint i,j;
- for(i=xms;i>0;i--)
- for(j=110;j>0;j--);
- void display(uchar num)
- P0=table[num];
- dula=1;
- //P0=table[num];
- dula=0;
- //delayms(500);
- void matrixkeyscan()
- uchar temp,key;
- P3=0xfe;
- temp=P3;
- temp=temp&0xf0;
- if(temp != 0xf0)
- delayms(10);
- temp=P3;
- temp=temp&0xf0;
- if(temp!=0xf0)
- temp=P3;
- switch(temp)
- case 0xee: key=0;
- break;
- case 0xde: key=1;
- break;
- case 0xbe: key=2;
- break;
- case 0x7e: key=3;
- break;
- while(temp!=0xf0)
- temp=P3;
- temp=temp&0xf0;
- display(key);
- P3=0xfd;
- temp=P3;
- temp=temp&0xf0;
- if(temp != 0xf0)
- delayms(10);
- temp=P3;
- temp=temp&0xf0;
- if(temp!=0xf0)
- temp=P3;
- switch(temp)
- case 0xed: key=4;
- break;
- case 0xdd: key=5;
- break;
- case 0xbd: key=6;
- break;
- case 0x7d: key=7;
- break;
- while(temp!=0xf0)
- temp=P3;
- temp=temp&0xf0;
- display(key);
- P3=0xfb;
- temp=P3;
- temp=temp&0xf0;
- if(temp != 0xf0)
- delayms(10);
- temp=P3;
- temp=temp&0xf0;
- if(temp!=0xf0)
- temp=P3;
- switch(temp)
- case 0xeb: key=8;
- break;
- case 0xdb: key=9;
- break;
- case 0xbb: key=10;
- break;
- case 0x7b: key=11;
- break;
- while(temp!=0xf0)
- temp=P3;
- temp=temp&0xf0;
- display(key);
- P3=0xf7;
- temp=P3;
- temp=temp&0xf0;
- if(temp != 0xf0)
- delayms(10);
- temp=P3;
- temp=temp&0xf0;
- if(temp!=0xf0)
- temp=P3;
- switch(temp)
- case 0xe7: key=12;
- break;
- case 0xd7: key=13;
- break;
- case 0xb7: key=14;
- break;
- case 0x77: key=15;
- break;
- while(temp!=0xf0)
- temp=P3;
- temp=temp&0xf0;
- display(key);
- void main()
- P0=0;
- dula=1;
- dula=0;
- P0=0xc0;
- wela=1;
- //P0=0xc0;
- wela=0;
- while(1)
- matrixkeyscan();
复制代码
