Project/Target: "GW3323_GPIO_IN - Debug":
The compiler's setup is invalid, so Code::Blocks cannot find/run the compiler.
Probably the toolchain path within the compiler options is not setup correctly?!
Do you have a compiler installed?
Goto "Settings->Compiler...->Global compiler settings->unknown->Toolchain executables" and fix the compiler's setup.
Skipping...
没有什么可以做(所有项目是最新的).
我正确设置了编译器的位置,试过几遍无法编译
我用杰理的蓝牙SDk例程编译没有问题,差别是杰理有个codeblocks的工具链安装 |
