STM32文档关于i2c这段意思是什么
2186|2
 楼主| zyboy 发表于 2012-5-31 22:39 | 显示全部楼层 |阅读模式
Start cannot be generated after a misplaced Stop
Description
If a master generates a misplaced Stop on the bus (bus error), the peripheral cannot
generate a Start anymore.
Workaround
In the I²C standard, it is allowed to send a Stop only at the end of the full byte (8 bits +
acknowledge), so this scenario is not allowed
. Other derived protocols like CBUS allow it,
but they are not supported by the I²C peripheral.
A software workaround consists in asserting the software reset using the SWRST bit in the
I2C_CR1 control register.
是说只允许在发了8bits+ack后,才能发stop;  还是不允许? 谢谢
 楼主| zyboy 发表于 2012-5-31 22:41 | 显示全部楼层
错误的stop信号是什么含义?
是发了8bits+ack后,发stop 就有问题;还是不是这样,就有问题?
IJK 发表于 2012-6-1 10:42 | 显示全部楼层
I2C协议 只允许在发了8bits+ack后,才能发stop。
但其它源自I2C的协议,比如CBUS 允许(misplaced Stop on the bus )。【Other derived protocols like CBUS allow it】
且慢,CBUS 是什么?是不是写错了?
个人签名:学海无涯,回头是岸!
101
