基本定时器TIM6的使用 1、设置一个定时器,100ms一次去开关LED灯
2、tim6的初始化代码:
大部分代码来自官方demo - /*****************************************************************************
- * Copyright (c) 2019, Nations Technologies Inc.
- * All rights reserved.
- * Redistribution and use in source and binary forms, with or without
- * modification, are permitted provided that the following conditions are met:
- * - Redistributions of source code must retain the above copyright notice,
- * this list of conditions and the disclaimer below.
- * Nations' name may not be used to endorse or promote products derived from
- * this software without specific prior written permission.
- * DISCLAIMER: THIS SOFTWARE IS PROVIDED BY NATIONS "AS IS" AND ANY EXPRESS OR
- * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
- * MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE
- * DISCLAIMED. IN NO EVENT SHALL NATIONS BE LIABLE FOR ANY DIRECT, INDIRECT,
- * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
- * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA,
- * OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF
- * LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING
- * NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
- * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
- *\*\file timer_common.c
- *\*\author Nations
- *\*\version v1.0.0
- *\*\copyright Copyright (c) 2019, Nations Technologies Inc. All rights reserved.
- #include "timer.h"
- #include "main.h"
- #include "type.h"
- static TIM_TimeBaseInitType TIM_TimeBaseStructure;
- *\*\name Common_TIM_Base_Initialize.
- *\*\param TIMx :
- *\*\ - TIM1
- *\*\ - TIM2
- *\*\ - TIM3
- *\*\ - TIM4
- *\*\ - TIM5
- *\*\ - TIM6
- *\*\param period
- *\*\ - [1, 0xffff]
- *\*\param prescaler
- *\*\ - [0, 0xffff]
- *\*\return none
- static void Common_TIM_Base_Initialize(TIM_Module *TIMx, uint16_t period, uint16_t prescaler)
- TIM_Base_Struct_Initialize(&TIM_TimeBaseStructure);
- TIM_TimeBaseStructure.Period = period;
- TIM_TimeBaseStructure.Prescaler = prescaler;
- TIM_TimeBaseStructure.ClkDiv = 0;
- TIM_TimeBaseStructure.CntMode = TIM_CNT_MODE_UP;
- TIM_Base_Initialize(TIMx, &TIM_TimeBaseStructure);
- *\*\name Common_TIM_NVIC_Initialize.
- *\*\param IRQ_number :
- *\*\ - TIM1_BRK_IRQn
- *\*\ - TIM1_UP_IRQn
- *\*\ - TIM1_TRG_COM_IRQn
- *\*\ - TIM1_CC_IRQn
- *\*\ - TIM2_IRQn
- *\*\ - TIM3_IRQn
- *\*\ - TIM4_IRQn
- *\*\ - TIM8_BRK_IRQn
- *\*\ - TIM8_UP_IRQn
- *\*\ - TIM8_TRG_COM_IRQn
- *\*\ - TIM8_CC_IRQn
- *\*\ - TIM5_IRQn
- *\*\ - TIM6_IRQ
- *\*\param command
- *\*\ - ENABLE
- *\*\ - DISABLE
- *\*\return none
- static void Common_TIM_NVIC_Initialize(IRQn_Type IRQ_number, FunctionalState command)
- NVIC_InitType NVIC_InitStructure;
- NVIC_InitStructure.NVIC_IRQChannel = IRQ_number;
- NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
- NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
- if(ENABLE == command)
- NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
- else
- NVIC_InitStructure.NVIC_IRQChannelCmd = DISABLE;
- NVIC_Initializes(&NVIC_InitStructure);
- *\*\name Common_TIM_DMA_Config.
- *\*\param chan_handle
- *\*\param dma_param
- *\*\param req_remap
- *\*\ - DMA_REMAP_TIM1_CH1
- *\*\ - DMA_REMAP_TIM1_CH2
- *\*\ - DMA_REMAP_TIM1_CH3
- *\*\ - DMA_REMAP_TIM1_CH4
- *\*\ - DMA_REMAP_TIM1_COM
- *\*\ - DMA_REMAP_TIM1_UP
- *\*\ - DMA_REMAP_TIM1_TRIG
- *\*\ - DMA_REMAP_TIM2_CH1
- *\*\ - DMA_REMAP_TIM2_CH2
- *\*\ - DMA_REMAP_TIM2_CH3
- *\*\ - DMA_REMAP_TIM2_CH4
- *\*\ - DMA_REMAP_TIM2_UP
- *\*\ - DMA_REMAP_TIM3_CH1
- *\*\ - DMA_REMAP_TIM3_CH3
- *\*\ - DMA_REMAP_TIM3_CH4
- *\*\ - DMA_REMAP_TIM3_UP
- *\*\ - DMA_REMAP_TIM3_TRIG
- *\*\ - DMA_REMAP_TIM4_CH1
- *\*\ - DMA_REMAP_TIM4_CH2
- *\*\ - DMA_REMAP_TIM4_CH3
- *\*\ - DMA_REMAP_TIM4_UP
- *\*\ - DMA_REMAP_TIM5_CH1
- *\*\ - DMA_REMAP_TIM5_CH2
- *\*\ - DMA_REMAP_TIM5_CH3
- *\*\ - DMA_REMAP_TIM5_CH4
- *\*\ - DMA_REMAP_TIM5_UP
- *\*\ - DMA_REMAP_TIM5_TRIG
- *\*\ - DMA_REMAP_TIM6_UP
- *\*\ - DMA_REMAP_TIM8_CH1
- *\*\ - DMA_REMAP_TIM8_CH2
- *\*\ - DMA_REMAP_TIM8_CH3
- *\*\ - DMA_REMAP_TIM8_CH4
- *\*\ - DMA_REMAP_TIM8_COM
- *\*\ - DMA_REMAP_TIM8_UP
- *\*\ - DMA_REMAP_TIM8_TRIG
- *\*\return none
- static void Common_TIM_DMA_Config(DMA_ChannelType *chan_handle, DMA_InitType *dma_param, uint32_t req_remap)
- RCC_AHB_Peripheral_Clock_Enable(RCC_AHB_PERIPH_DMA);
- DMA_Reset(chan_handle);
- DMA_Initializes(chan_handle, dma_param);
- DMA_Channel_Request_Remap(chan_handle, req_remap);
- *\*\param src_addr
- *\*\param dst_addr
- *\*\param len
- *\*\return none
- static void Common_TIM_DMA_Start(DMA_ChannelType *chan_handle, uint32_t src_addr, uint32_t dst_addr, uint32_t len)
- DMA_Channel_Disable(chan_handle);
- chan_handle->TXNUM = len;
- if(chan_handle->CHCFG & DMA_DIR_PERIPH_DST)
- chan_handle->PADDR = dst_addr;
- chan_handle->MADDR = src_addr;
- else
- chan_handle->PADDR = src_addr;
- chan_handle->MADDR = dst_addr;
- DMA_Channel_Enable(chan_handle);
- *\*\name Common_BSTIM_RCC_Initialize.
- *\*\param TIMx :
- *\*\ - TIM6
- *\*\param hclk_division
- *\*\ - RCC_HCLK_DIV1
- *\*\ - RCC_HCLK_DIV2
- *\*\ - RCC_HCLK_DIV4
- *\*\ - RCC_HCLK_DIV8
- *\*\ - RCC_HCLK_DIV16
- *\*\return uint32_t
- static MI_BOOL Common_BSTIM_RCC_Initialize(TIM_Module *TIMx, uint32_t hclk_division)
- uint32_t BSTIM_clock;
- RCC_ClocksType RCC_Clocks;
- // RCC_AHB_Peripheral_Clock_Enable(RCC_AHB_PERIPH_GPIOA | RCC_AHB_PERIPH_GPIOB| RCC_AHB_PERIPH_GPIOC
- // | RCC_AHB_PERIPH_GPIOD);
- // RCC_APB2_Peripheral_Clock_Enable(RCC_APB2_PERIPH_AFIO);
- // RCC 配置 RCC_HCLK_DIV1 频率为128M RCC_HCLK_DIV4 为64M
- // 多个预分频器可用于配置 AHB、高速 APB(APB2)和低速 APB(APB1)的频率。AHB、APB2 和 APB1 的最大 频率分别为 128MHz、64MHz 和 32MHz。
- // APB 低速(APB1)预分频器
- // 由软件置位和清零,配置 APB1 时钟(PCLK1)的分频系数。需确保 PCLK1 不 超过 32MHz。
- // 0xx:HCLK 不分频
- // 100:HCLK 2 分频
- // 101:HCLK 4 分频
- // 110:HCLK 8 分频
- // 111:HCLK 16 分频
- //RCC_Pclk1_Config(hclk_division);
- RCC_APB1_Peripheral_Clock_Enable(RCC_APB1_PERIPH_TIM6);
- RCC_Clocks_Frequencies_Value_Get(&RCC_Clocks);
- return MI_TRUE;
- // 基本定时器的使用
- void timer6_init()
- Common_BSTIM_RCC_Initialize(TIM6, RCC_HCLK_DIV1);
- /* NVIC Configuration */
- Common_TIM_NVIC_Initialize(TIM6_IRQn, ENABLE);
- /* Time base configuration, period = 1000-1, prescaler = 6400-1 */
- /* 100ms 触发中断一次 64000000 /(1000-1+1)* (6400-1+1) = 10HZ */
- Common_TIM_Base_Initialize(TIM6, 1000-1, 6400-1);
- TIM_Base_Reload_Mode_Set(TIM6, TIM_PSC_RELOAD_MODE_IMMEDIATE);
- TIM_Interrupt_Enable(TIM6, TIM_INT_UPDATE);
- TIM_On(TIM6);
- // timer1 当作通用定时器的使用
- void timer1_common_init()
- //RCC配置
- RCC_APB2_Peripheral_Clock_Enable(RCC_APB2_PERIPH_TIM1);
- // 中断配置
- Common_TIM_NVIC_Initialize(TIM1_UP_IRQn, ENABLE);
- /* Time base configuration, period = 65535, prescaler = prescaler */
- Common_TIM_Base_Initialize(TIM1, 1000-1, 12800-1);
- TIM_Base_Reload_Mode_Set(TIM1, TIM_PSC_RELOAD_MODE_IMMEDIATE);
- TIM_Interrupt_Enable(TIM1, TIM_INT_UPDATE);
- TIM_On(TIM1);
复制代码3、中断处理函数 - void TIM6_IRQHandler(void)
- if (TIM_Interrupt_Status_Get(TIM6, TIM_INT_UPDATE) != RESET)
- TIM_Interrupt_Status_Clear(TIM6, TIM_INT_UPDATE);
- /* Pin PC.06 toggling */
- GPIO_Pin_Toggle(LED2_GPIO_PORT, LED1_GPIO_PIN);
复制代码4、main.cpp引用time6_init()后,重新烧录,即可看到led1 100ms闪烁。
注意:
/* Time base configuration, period = 1000-1, prescaler = 6400-1 / / 100ms 触发中断一次 64000000 /(1000-1+1)* (6400-1+1) = 10HZ */
N32G430C8L7的时钟配置为 HCLK = 128M APB2 = 64M APB1 = 32M
