[应用方案] 格林威治时间转北京时间+根据日期计算星期几 C语言程序
 楼主| mnynt121 发表于 2025-3-26 07:00 | 显示全部楼层 |阅读模式
  1. #include <stdint.h>
  2. #include <stdio.h>
  3. typedef struct
  4. {
  5.         int year;
  6.         int month;
  7.         int day;
  8.         int hours;
  9.         int minutes;
  10.         int seconds;
  11.         int weekday;
  12. }mytime_t;
  13. mytime_t utctime;
  14. unsigned int     Year,Mon,Day,Shi,Fen,Miao,Zhou;
  15. /// 返回值:1-7,对应周一到周天
  16. uint8_t GetWeekDayNum(uint32_t year, uint8_t month, uint8_t day)
  17. {
  18.   uint32_t weekday = 0U;
  19.   if (month < 3U)
  20.   {
  21.         /*D = { [(23 x month)/9] + day + 4 + year + [(year-1)/4] - [(year-1)/100] + [(year-1)/400] } mod 7*/
  22.         weekday = (((23U * month) / 9U) + day + 4U + year + ((year - 1U) / 4U) - ((year - 1U) / 100U) + ((year - 1U) / 400U)) % 7U;
  23.   }
  24.   else
  25.   {
  26.         /*D = { [(23 x month)/9] + day + 4 + year + [year/4] - [year/100] + [year/400] - 2 } mod 7*/
  27.         weekday = (((23U * month) / 9U) + day + 4U + year + (year / 4U) - (year / 100U) + (year / 400U) - 2U) % 7U;
  28.   }
  29.   if(weekday == 0)
  30.   {
  31.           weekday = 7;
  32.   }
  33.   return (uint8_t)weekday;
  34. }
  35. void UTCToBeijing(mytime_t* time)
  36. {
  37.         uint8_t days = 0;
  38.         if (time->month == 1 || time->month == 3 || time->month == 5 || time->month == 7 || time->month == 8 || time->month == 10 || time->month == 12)
  39.         {
  40.                 days = 31;
  41.         }
  42.         else if (time->month == 4 || time->month == 6 || time->month == 9 || time->month == 11)
  43.         {
  44.                 days = 30;
  45.         }
  46.         else if (time->month == 2)
  47.         {
  48.                 if ((time->year % 400 == 0) || ((time->year % 4 == 0) && (time->year % 100 != 0))) /* 判断平年还是闰年 */
  49.                 {
  50.                         days = 29;
  51.                 }
  52.                 else
  53.                 {
  54.                         days = 28;
  55.                 }
  56.         }
  57.         time->hours += 8;                 /* 北京时间比格林威治时间快8小时 */
  58.         if (time->hours >= 24)            /* 跨天 */
  59.         {
  60.                 time->hours -= 24;
  61.                 time->day++;
  62.                 if (time->day > days)        /* 跨月 */
  63.                 {
  64.                         time->day = 1;
  65.                         time->month++;
  66.                         if (time->month > 12)    /* 跨年 */
  67.                         {
  68.                                 time->year++;
  69.                         }
  70.                 }
  71.         }
  72.         time->weekday = GetWeekDayNum(time->year, time->month, time->day);  /* 重新计算周 */
  73. }
  74. void GMT_time()
  75. {
  76.         //第一步:输入对应UTC时间
  77.         utctime.year = 2021;
  78.         utctime.month = 12;
  79.         utctime.day =27;
  80.         utctime.hours = 18;
  81.         utctime.minutes = 2;
  82.         utctime.seconds = 10;
  83.         utctime.weekday = 1;
  84.         //第二步:处理
  85.         UTCToBeijing(&utctime);//处理
  86.
  87.        //第三步:下面就是北京时间
  88.         Year   =utctime.yea;
  89.         Mon   =utctime.mont;
  90.         Day   =utctime.da;
  91.         Shi    =utctime.hour;
  92.         Fen   =utctime.minutes;
  93.         Miao  =utctime.second;
  94.         Zhou =utctime.weekda;
  95. }
  96. 原文链接:https://blog.csdn.net/qq153471503/article/details/107157470
复制代码
yangxiaor520 发表于 2025-3-26 21:23 来自手机 | 显示全部楼层
直接转载代码,这帖子越来越水了
呐咯密密 发表于 2025-3-28 16:31 | 显示全部楼层
加一点解读就好了
shenxiaolin 发表于 2025-3-28 20:54 | 显示全部楼层
学习一下
地瓜patch 发表于 2025-3-28 22:54 | 显示全部楼层
做称文件上传附在后边更换
