LaunchPad 德州仪器的在线资源,很丰富的。
 楼主| wghmycl1985 发表于 2012-6-14 19:30 | 显示全部楼层 |阅读模式
Online ResourcesLaunchPad DocumentationMSP430 LaunchPad One Day WorkshopThe
Getting Started with the MSP430 LaunchPad Workshop
is free, on-line, in-depth introduction into MSP430 basics including:
  • An introduction to the Value Line series of products
  • An overview of Code Composer Studio 4.1
  • Initialization of the MSP430 and programming the GPIO
  • Use of the ADC10 analog-to-digital converter
  • Working with interrupts and the timer
  • Optimizing your code for low-power operation
  • Using serial communications
Each of these sections includes an in-depth lab that will step you through the usage, programming and testing of the peripherals(s) covered.
Check it out!
MSP430 Code ExamplesCode examples are available for all MSP430 devices! You can msp430 code examples
HERE!
Provided are zip files that includes code examples for all MSP430G2xx devices. These zip files can be imported into your active projects, and .C and .ASM files are provided. Use these zip files to get a head start with your applications!
u880 发表于 2012-6-14 21:00 | 显示全部楼层
谢谢楼主!
gaochy1126 发表于 2012-6-14 21:30 | 显示全部楼层
感谢楼主分享资料!
tianm 发表于 2012-6-15 11:52 | 显示全部楼层
TI的文档资料做的是很好的
lattice1 发表于 2012-6-15 13:30 | 显示全部楼层
