了解并掌握GPIO口的使用是硬件开发的基本功,利用板载的LED与KEY可以省去配接这些器件的过程,其电路如图1所示。
图1 LED与KEY电路
要实现按键对LED的控制,需要对KEY和LED进行配置,所用到的函数为:
BOARD_LED_Config()和BOARD_BUTTON_Config()
其中,函数BOARD_LED_Config()的内容为:
- void BOARD_LED_Config(BOARD_LED_T led)
- GPIO_Config_T GPIO_ConfigStruct = {0U};
- RCM_EnableAPB2PeriphClock(LED_CLK[led]);
- GPIO_ConfigStruct.pin = LED_PIN[led];
- GPIO_ConfigStruct.mode = GPIO_MODE_OUT_PP;
- GPIO_ConfigStruct.speed = GPIO_SPEED_50MHz;
- GPIO_Config(LED_PORT[led], &GPIO_ConfigStruct);
- LED_PORT[led]->BC = LED_PIN[led];
函数BOARD_BUTTON_Config()的内容为:
- void BOARD_BUTTON_Config(BOARD_BUTTON_T button, BOARD_BUTTON_MODE_T mode)
- EINT_Config_T EINT_ConfigStruct = {0U};
- RCM_EnableAPB2PeriphClock(BUTTON_CLK[button] | RCM_APB2_PERIPH_AFIO);
- GPIO_ConfigStruct.mode = GPIO_MODE_IN_PU;
- GPIO_ConfigStruct.pin = BUTTON_PIN[button];
- GPIO_Config(BUTTON_PORT[button], &GPIO_ConfigStruct);
- if (mode == BUTTON_MODE_EINT)
- GPIO_ConfigEINTLine(BUTTON_PORT_SOURCE[button], BUTTON_PIN_SOURCE[button]);
- EINT_ConfigStruct.line = BUTTON_EINT_LINE[button];
- EINT_ConfigStruct.mode = EINT_MODE_INTERRUPT;
- EINT_ConfigStruct.trigger = EINT_TRIGGER_FALLING;
- EINT_ConfigStruct.lineCmd = ENABLE;
- EINT_Config(&EINT_ConfigStruct);
- NVIC_EnableIRQRequest(BUTTON_IRQn[button], 0x0F, 0x0F);
此外,为检测按键的状态及控制LED,还需使用的函数有:
BOARD_BUTTON_GetState()和BOARD_LED_Toggle()
函数BOARD_BUTTON_GetState()的内容为:
- void BOARD_LED_Toggle(BOARD_LED_T led)
- LED_PORT[led]->ODATA ^= LED_PIN[led];
函数BOARD_LED_Toggle的内容为:
- uint32_t BOARD_BUTTON_GetState(BOARD_BUTTON_T button)
- return GPIO_ReadInputBit(BUTTON_PORT[button], BUTTON_PIN[button]);
实现按键控制LED的主程序为:
- int main(void)
- BOARD_LED_Config(LED2);
- BOARD_LED_Config(LED3);
- BOARD_BUTTON_Config(BUTTON_KEY1, BUTTON_MODE_GPIO);
- while (1)
- if(BOARD_BUTTON_GetState(BUTTON_KEY1)==0)
- BOARD_LED_Toggle(LED2);
- BOARD_LED_Toggle(LED3);
经程序的编译和下载,该程序的功能正确,即每按一次按键,则LED灯变换一次状态。
