[STM32F1] 遇到代码运行与退出调试模式的问题
 楼主| 梧桐uuu 发表于 2025-8-3 23:06 | 显示全部楼层 |阅读模式
在使用SEGGER JLink和STM32CubeIDE时遇到代码运行与退出调试模式的问题。调试器请求暂停目标设备......目标设备已暂停。
我的环境:Windows10系统,STM32CubeIDE v1.5.1,SEGGER JLink调试器,硬件为STM32F103C8T6,固件为默认的HAL库闪烁灯程序。该问题在所有项目中均出现。
SEGGER J-Link GDB Server V6.82g Command Line Version
JLinkARM.dll V6.82g (DLL compiled Aug 28 2020 16:57:23)
Command line: -port 2331 -s -device STM32F103C8 -endian little -speed 4000 -if swd -vd
-----GDB Server start settings-----
GDBInit file:                  none
GDB Server Listening port:     2331
SWO raw output listening port: 2332
Terminal I/O port:             2333
Accept remote connection:      localhost only
Generate logfile:              off
Verify download:               on
Init regs on start:            off
Silent mode:                   off
Single run mode:               on
Target connection timeout:     0 ms
------J-Link related settings------
J-Link Host interface:         USB
J-Link script:                 none
J-Link settings file:          none
------Target related settings------
Target device:                 STM32F103C8
Target interface:              SWD
Target interface speed:        4000kHz
Target endian:                 little
Connecting to J-Link...
J-Link is connected.
Firmware: J-Link V9 compiled Dec 13 2019 11:14:50
Hardware: V9.60
S/N: XXXXXXXXX
Feature(s): GDB, RDI, FlashBP, FlashDL, JFlash, RDDI
Checking target voltage...
Target voltage: 3.28 V
Listening on TCP/IP port 2331
Connecting to target...
Connected to target
Waiting for GDB connection...Connected to 127.0.0.1
Reading all registers
Read 4 bytes @ address 0x0800048E (Data = 0x002C4770)
Read 2 bytes @ address 0x0800048E (Data = 0x4770)
Received monitor command: WriteDP 0x2 0xF0
O.K.
Received monitor command: ReadAP 0x2
O.K.:0xE00FF003
Reading 32 bytes @ address 0xE00FFFD0
Received monitor command: reset
Resetting target
Downloading 268 bytes @ address 0x08000000 - Verified OK
Downloading 4368 bytes @ address 0x0800010C - Verified OK
Downloading 32 bytes @ address 0x0800121C - Verified OK
Downloading 4 bytes @ address 0x0800123C - Verified OK
Downloading 4 bytes @ address 0x08001240 - Verified OK
Downloading 12 bytes @ address 0x08001244 - Verified OK
Writing register (PC = 0x 8000384)
Starting target CPU...
GDB closed TCP/IP connection (Socket 1008)
Debugger requested to halt target...
...Target halted (PC = 0x08000486)
GDB closed TCP/IP connection (Socket 1036)
