C8051F410编写程序1602无法显示
 楼主| xunzhaokaixin 发表于 2012-7-6 15:03 | 显示全部楼层 |阅读模式
#include  <C8051F410.h>
#include  <math.h>    //Keil library
#include  <stdio.h>   //Keil library
#include  <INTRINS.H>
#define   uchar unsigned char
#define   uint unsigned int
unsigned char xdata Netdata[14]={0x77,0x77,0x77,0x2e,0x78,0x68,0x6c,0x2e
                                 ,0x63,0x6f,0x6d,0x2e,0x63,0x6e};
unsigned char xdata NCDdata[14]={0x57,0x65,0x6c,0x63,0x6f,0x6d,0x65,0x20
                                 ,0x74,0x6f,0x20,0x4e,0x43,0x44};
sbit LCM_EN=P1^0;
sbit LCM_RW=P1^1;
sbit LCM_RS=P1^2;
#define   DataPort P0
void delay(int i)
     int j,k;
     for(j=0;j<i;j++)
     for(k=0;k<1000;k++);
void WaitForEnable(void)
DataPort=0xff;
LCM_RS=0;
LCM_RW=1;
_nop_();
LCM_EN=1;
_nop_();
_nop_();
while(DataPort&0x80);
LCM_EN=0;
void WriteCommandLCM(uchar CMD,uchar Attribc)
if(Attribc)WaitForEnable();
LCM_RS=0;LCM_RW=0;
_nop_();
DataPort=CMD;
_nop_();
LCM_EN=1;
_nop_();
_nop_();
LCM_EN=0;
void WriteDataLCM(uchar dataW)
WaitForEnable();
LCM_RS=1;LCM_RW=0;
_nop_();
DataPort=dataW;
_nop_();
LCM_EN=1;
_nop_();
_nop_();
LCM_EN=0;
void InitLcd()
WriteCommandLCM(0x38,1);
WriteCommandLCM(0x08,1);
WriteCommandLCM(0x01,1);
WriteCommandLCM(0x06,1);
WriteCommandLCM(0x0c,1);
void SYSCLK_Init(void)
        OSCICN    = 0x87;
void PORT_Init(void)
    P0MDOUT   = 0xFF;
    P1MDOUT   = 0xFF;
    XBR1      = 0x40;
void main()
   unsigned int i;
    PCA0MD    &= ~0x40;
SYSCLK_Init();
PORT_Init();
InitLcd();
//write_com(0x80);
//write_data('H');
while(1)  //最后程序停留在while语句中
for(i=0;i<14;i++)
    WriteDataLCM(Netdata[i]);
delay(20);
    WriteCommandLCM(0x80+0x51,1);
    for(i=0;i<14;i++)
    WriteDataLCM(NCDdata[i]);
    delay(20);
    for(i=0;i<14;i++)
   //整屏左移
    WriteCommandLCM(0x18,1);  //整屏左移一个字节
    delay(400);
InitLcd();
  /*unsigned int n;
for(n=0;n<14;n++)
write_data(NCDdata[n]);
delay(5);
LCD_Init();*/
ayb_ice 发表于 2012-7-6 16:21 | 显示全部楼层
NOP太少了吧
M_sky300 发表于 2012-7-6 17:40 | 显示全部楼层
你这个程序没什么没什么问题,要看一下你的外围硬件电路是否有问题
ningling_21 发表于 2012-7-6 21:52 | 显示全部楼层
硬件又没问题?
zxq1234508 发表于 2012-7-7 13:36 | 显示全部楼层
端口设置是开漏输出还是推挽输出?可以重新设置试试。
单车骑士 发表于 2012-7-17 21:39 | 显示全部楼层
硬件没初始化吧
328553323 发表于 2012-7-17 23:05 | 显示全部楼层
应该是初始化那里延时不够,导致程序死在检测忙标志位那个WHILE那里了。
阮天宇00 发表于 2012-7-27 13:17 | 显示全部楼层
1# xunzhaokaixin
液晶启动似乎要等一段时间才能稳定。
你在初始化程序前面延时个几秒看看。
 楼主| xunzhaokaixin 发表于 2012-8-2 10:29 | 显示全部楼层
嗯,已经解决了,是延时问题
