[AVR单片机] AVR入门求帮助
 楼主| Channe 发表于 2012-7-31 21:59 | 显示全部楼层 |阅读模式
电路图是这样
程序是这样
KS0108 128*64 LCD C语言驱动
参考ICCAVR资料和网上的资料改写
LCD引脚定义
1---GND
2---VCC
3---VLCD
4---D/I
5---R/W
6---E
7到14 D0-D7
15--CS1
16--CS2
17--RESET
18--VEE
19--SW
20--NC
#include <avr/io.h>
#include <avr/interrupt.h>
#define CLI cli
#define SEI sei
#define BIT(A) (1<<A)
/* 当前行、列存储,行高16点,列宽8点 */
unsigned char CurOffset,CurRow,CurPage,CurCol;
/*  常量定义  */
#define LCD_STATUS_BUSY 0x80
#define  START_LINE0   0xc0
#define  DISPLAY_ON    0x3f
#define  DISPLAY_OFF   0x3e
#define  PARA1         0x40
//PORTA---数据口  PORTB----控制口
#define LCD_DIR_PORT
DDRA
#define LCD_IP_PORT
PINA
#define LCD_OP_PORT
PORTA
#define LCD_EN_PORT
PORTD
#define LCD_CS2_PORT
PORTD
#define LCD_CS1_PORT
PORTD
#define LCD_RW_PORT
PORTD
#define LCD_DI_PORT
PORTD
#define LCD_DI_BIT
BIT(7)//0x80
#define LCD_RW_BIT
BIT(6)//0x40
#define LCD_EN_BIT
BIT(5)//0x20
#define LCD_CS1_BIT
BIT(4)//0x10
#define LCD_CS2_BIT
BIT(3)//0x08
#define SET_LCD_E
LCD_EN_PORT |= LCD_EN_BIT    //LCD使能
#define CLEAR_LCD_E
LCD_EN_PORT &= ~LCD_EN_BIT   //LCD禁止
#define SET_LCD_DATA
LCD_DI_PORT |= LCD_DI_BIT    //选择指令端口
#define SET_LCD_CMD
LCD_DI_PORT &= ~LCD_DI_BIT   //选择数据端口
#define SET_LCD_READ
LCD_RW_PORT |= LCD_RW_BIT    //读模式
#define SET_LCD_WRITE
LCD_RW_PORT &= ~LCD_RW_BIT   //写模式
#define SET_LCD_CS2     LCD_CS2_PORT |= LCD_CS2_BIT  //左屏选择禁止
#define CLEAR_LCD_CS2   LCD_CS2_PORT &= ~LCD_CS2_BIT //左屏选择使能
#define SET_LCD_CS1     LCD_CS1_PORT |= LCD_CS1_BIT  //左屏选择禁止
#define CLEAR_LCD_CS1   LCD_CS1_PORT &= ~LCD_CS1_BIT //左屏选择使能
#define LEFT 0
#define RIGHT 1
#define CMD 0
#define DATA 1
void LCD_BUSY(unsigned char lr) //判断忙标志
unsigned char status;
    CLI();
if(lr==LEFT)
    CLEAR_LCD_CS2; //cs2=0
SET_LCD_CS1;   //cs1=1
else
SET_LCD_CS2;   //cs2=1
CLEAR_LCD_CS1; //cs1=0
SET_LCD_CMD;
    LCD_DIR_PORT = 0x00;
    LCD_OP_PORT = 0x00;
    SET_LCD_READ;
    SET_LCD_E;
    asm("nop");
asm("nop");
    asm("nop");
asm("nop");
    while((LCD_IP_PORT) & LCD_STATUS_BUSY)
        CLEAR_LCD_E;
asm("nop");
asm("nop");
asm("nop");
asm("nop");
SET_LCD_E;
asm("nop");
asm("nop");
asm("nop");
asm("nop");
    CLEAR_LCD_E;
    SET_LCD_WRITE;
    LCD_OP_PORT = 0xff;
    SEI();
void write_LCD(unsigned char lr,unsigned char cd,unsigned char data) /*写入指令或数据*/
    CLI();
LCD_BUSY(lr);
if(cd==CMD)
SET_LCD_CMD;
else SET_LCD_DATA;
    SET_LCD_WRITE;
SET_LCD_E;
    LCD_DIR_PORT = 0xff;
    LCD_OP_PORT = data;
    asm("nop");
asm("nop");
asm("nop");
asm("nop");
    CLEAR_LCD_E;
    LCD_OP_PORT = 0xff;
    SEI();
unsigned char read_LCD(unsigned char lr)
  /*  读显示数据 */
unsigned char data;
    CLI();
LCD_BUSY(lr);
SET_LCD_DATA;
    LCD_OP_PORT = 0xff;
    SET_LCD_READ;
SET_LCD_E;
asm("nop");
asm("nop");
    asm("nop");
asm("nop");
    data=LCD_IP_PORT;
    CLEAR_LCD_E;
    SET_LCD_WRITE;
LCD_BUSY(lr);
SET_LCD_DATA;
    LCD_OP_PORT = 0xff;
    SET_LCD_READ;
SET_LCD_E;
    asm("nop");
asm("nop");
asm("nop");
asm("nop");
    data=LCD_IP_PORT;
    CLEAR_LCD_E;
    SET_LCD_WRITE;
    SEI();
return data;
void set_start_line_L(unsigned char line) /*设置显示起始行*/ //0-63
write_LCD(LEFT,CMD,0xc0|line);
void set_start_line_R(unsigned char line) /*设置显示起始行*/ //0-63
write_LCD(RIGHT,CMD,0xc0|line);
void set_page_L(unsigned char page)
/*设置X地址 设置页*/  //0-7
write_LCD(LEFT,CMD,0xb8|page);
void set_page_R(unsigned char page)
/*设置X地址 设置页*/ //0-7
write_LCD(RIGHT,CMD,0xb8|page);
void set_col_addr_L(unsigned char col) /*设置Y地址*/ //0-63
write_LCD(LEFT,CMD,0x40|col);
void set_col_addr_R(unsigned char col) /*设置Y地址*/ //0-63
write_LCD(RIGHT,CMD,0x40|col);
void init_lcd(void) /*初始化函数*/
set_start_line_L(0); /*显示起始行为0*/
set_start_line_R(0); /*显示起始行为0*/
write_LCD(LEFT,CMD,DISPLAY_ON); /*  开显示  */
write_LCD(RIGHT,CMD,DISPLAY_ON); /*  开显示  */
void clr_lcd(void) /*清屏函数*/
unsigned char pages,i;
for(pages=0;pages<8;pages++)
set_page_L(pages);  /* X 页地址 */
set_page_R(pages);  /* X 页地址 */
for(i=0;i<64;i++)
set_col_addr_L(i);//Y
set_col_addr_R(i);//Y
write_LCD(LEFT,DATA,0x0);
write_LCD(RIGHT,DATA,0x0);
/*             绘点函数              */
void pixel(unsigned char xx,unsigned char yy,unsigned char flag)
unsigned int y,ch;
ch=yy%8;  //余数
y=1;
for(;ch!=0;)
y=y*2;
ch--;
if(xx<64)
set_page_L(yy/8);
set_col_addr_L(xx);
ch=read_LCD(LEFT);
set_col_addr_L(xx);
if(flag)
write_LCD(LEFT,DATA,ch|y);
else
y=~y;
ch&=y;
else
set_page_R(yy/8);
set_col_addr_R(xx-64);
ch=read_LCD(RIGHT);
if(flag)
write_LCD(RIGHT,DATA,ch|y);
else
y=~y;
ch&=y;
//ASCII 字模宽度及高度
#define ASC_CHR_WIDTH
#define ASC_CHR_HEIGHT
struct typFNT_ASC16
/* 汉字字模显示数据结构 */
unsigned char Index[1];
char Msk[16];
struct typFNT_ASC16 const ASC_16[] = {
/* 显示为8*16  Curier 10 常规*/
{'1',0x00,0x00,0x08,0x08,0xFC,0x00,0x00,0x00,0x00,0x00,0x04,0x04,0x07,0x04,0x04,0x00},
{'2',0x00,0x00,0x08,0x04,0x84,0x44,0x38,0x00,0x00,0x00,0x06,0x05,0x04,0x04,0x04,0x00},
{'3',0x00,0x00,0x08,0x04,0x44,0x44,0xB8,0x00,0x00,0x00,0x02,0x04,0x04,0x04,0x03,0x00},
{'4',0x00,0x00,0x80,0x60,0x18,0xFC,0x00,0x00,0x00,0x00,0x01,0x01,0x05,0x07,0x05,0x00},
{'5',0x00,0x00,0x7C,0x44,0x44,0x44,0x84,0x00,0x00,0x00,0x02,0x04,0x04,0x04,0x03,0x00},
{'6',0x00,0x00,0xF0,0x48,0x44,0x44,0x80,0x00,0x00,0x00,0x03,0x04,0x04,0x04,0x03,0x00},
{'7',0x00,0x00,0x0C,0x04,0x84,0x64,0x1C,0x00,0x00,0x00,0x00,0x06,0x01,0x00,0x00,0x00},
{'8',0x00,0x00,0xB8,0x44,0x44,0x44,0xB8,0x00,0x00,0x00,0x03,0x04,0x04,0x04,0x03,0x00},
{'9',0x00,0x00,0x38,0x44,0x44,0x44,0xF8,0x00,0x00,0x00,0x00,0x04,0x04,0x02,0x01,0x00},
{'0',0x00,0x00,0xF8,0x04,0x04,0x04,0xF8,0x00,0x00,0x00,0x03,0x04,0x04,0x04,0x03,0x00},
{'.',0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x06,0x06,0x00,0x00,0x00},
{':',0x00,0x00,0x00,0x0C,0x0C,0x00,0x00,0x00,0x00,0x00,0x00,0x03,0x03,0x00,0x00,0x00},
{' ',0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},
{'(',0x00,0x00,0x00,0xE0,0x18,0x04,0x00,0x00,0x00,0x00,0x00,0x03,0x0C,0x10,0x00,0x00},
{')',0x00,0x00,0x00,0x04,0x18,0xE0,0x00,0x00,0x00,0x00,0x00,0x10,0x0C,0x03,0x00,0x00},
#define ASC_HZ_WIDTH
//#define ASC_HZ_HEIGHT
struct typFNT_GB16
/*12*16 汉字字模显示数据结构 */
unsigned char Index[2];
char Msk[24];
struct typFNT_GB16 const GB_16[] = {
/* 宋体 9小五 显示为12*16 */
"液",0x19,0xE2,0x14,0x42,0xF2,0x2E,0x72,0x8F,0xAA,0x7A,0x02,0x00,0x01,0x07,0x00,0x00,0x07,0x04,0x04,0x02,0x01,0x02,0x04,0x00,
"晶",0x00,0xC0,0x40,0x5F,0xD5,0x15,0xD5,0x55,0x5F,0x40,0xC0,0x00,0x00,0x07,0x05,0x05,0x07,0x00,0x07,0x05,0x05,0x05,0x07,0x00,
"显",0x00,0x40,0x9F,0x15,0xD5,0x15,0xD5,0x15,0x1F,0xC0,0x00,0x00,0x04,0x04,0x05,0x04,0x07,0x04,0x07,0x06,0x05,0x04,0x04,0x00,
"示",0x10,0x12,0x92,0x52,0x12,0xF2,0x12,0x12,0x53,0x92,0x10,0x00,0x02,0x01,0x00,0x04,0x04,0x07,0x00,0x00,0x00,0x00,0x03,0x00,
"的",0xFC,0x44,0x46,0x45,0xFC,0x10,0x2C,0xC7,0x04,0x04,0xFC,0x00,0x07,0x02,0x02,0x02,0x07,0x00,0x00,0x04,0x04,0x04,0x03,0x00,
"第",0x04,0xEA,0xAB,0xAE,0xAA,0xFC,0xAA,0xAB,0xAE,0xBA,0x82,0x00,0x04,0x04,0x02,0x01,0x00,0x07,0x00,0x02,0x02,0x02,0x01,0x00,
"一",0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x30,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
"行",0x48,0x24,0xF3,0x08,0x09,0x09,0x09,0x09,0xF9,0x09,0x08,0x00,0x00,0x00,0x07,0x00,0x00,0x04,0x04,0x04,0x07,0x00,0x00,0x00,
"二",0x00,0x04,0x04,0x04,0x04,0x04,0x04,0x04,0x06,0x04,0x00,0x00,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x00,
"三",0x00,0x02,0x22,0x22,0x22,0x22,0x22,0x22,0x23,0x02,0x00,0x00,0x04,0x04,0x04,0x04,0x04,0x04,0x04,0x04,0x04,0x06,0x04,0x00,
"四",0x00,0xFF,0x81,0x41,0x3F,0x01,0x01,0xFF,0x81,0x81,0xFF,0x00,0x00,0x07,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x07,0x00,
"五",0x00,0x11,0x11,0x91,0x7F,0x11,0x11,0x11,0xF1,0x01,0x00,0x00,0x04,0x04,0x04,0x07,0x04,0x04,0x04,0x04,0x07,0x04,0x04,0x00,
unsigned char GetPage(void) /*得到当前页*/
return CurPage;
unsigned char GetCol(void) /*得到当前列*/
return CurCol;
void SetPageCol(unsigned char upage, unsigned char ucol) /* 设置液晶的页和列 */
CurPage = upage;
CurCol = ucol;
if(ucol<64)
set_page_L(upage);
set_col_addr_L(ucol);
else
set_page_R(upage);
set_col_addr_R(ucol-64);
/* 设置当前显示的页和列 */
void SetRowCol(unsigned char urow, unsigned char ucol)
unsigned char page;
CurRow = urow;
CurCol = ucol;
switch(urow)
case 1:
page=0;
CurOffset=1;
break;
case 2:
page=1;
CurOffset=2;
break;
case 3:
page=3;
CurOffset=1;
break;
case 4:
page=4;
CurOffset=2;
break;
case 5:
page=6;
CurOffset=1;
break;
SetPageCol(page,ucol);
void disp_char(unsigned char c)
unsigned char k,j,uPage,uCol,ch_r,ch_w;
unsigned char width;
unsigned char len;
uPage = GetPage();
uCol = GetCol();
len=sizeof(ASC_16)/sizeof(ASC_16[0]);
for(k=0;k<len;k++)
if(c == ASC_16[k].Index[0] ) break;
if(k<len)
if(c=='-'||c==':')
width=ASC_CHR_WIDTH-2;
else if(c=='|')
width=ASC_HZ_WIDTH-ASC_CHR_WIDTH;
else
width=ASC_CHR_WIDTH;
if(CurOffset==1) //下半部是写半个字节
for(j=0;j<width;j++)
SetPageCol(uPage,uCol+j);
ch_w=ASC_16[k].Msk[j];
if(uCol+j<64)
write_LCD(LEFT,DATA,ch_w);
else write_LCD(RIGHT,DATA,ch_w);
SetPageCol(uPage+1,uCol);
SetPageCol(uPage+1,uCol+j);
if(uCol+j<64) ch_r=read_LCD(LEFT);
else ch_r=read_LCD(RIGHT);
ch_r&=0xf0;
ch_w=ASC_16[k].Msk[ASC_CHR_WIDTH+j]&0x0f;
ch_w|=ch_r;
if(uCol+j<64)
else //上半部是写半个字节
ch_r&=0x0f;
ch_w=ch_w<<4;
ch_w|=ch_r;
if(uCol+j<64)
ch_r=ASC_16[k].Msk[j];
ch_w=ASC_16[k].Msk[ASC_CHR_WIDTH+j];
ch_r=ch_r>>4;
ch_w=ch_w<<4;
ch_w|=ch_r;
if(uCol+j<64)
SetPageCol(uPage,uCol+width);
void disp_hz(unsigned char const *hz)
uPage = GetPage();
uCol = GetCol();
for(k=0;k<sizeof(GB_16)/sizeof(GB_16[0]);k++)
if(hz[0] == GB_16[k].Index[0] && hz[1] == GB_16[k].Index[1])
break;
if(CurOffset==1)
for(j=0;j<ASC_HZ_WIDTH;j++)
ch_w=GB_16[k].Msk[j];
if(uCol+j<64)
ch_r&=0xf0;
ch_w=GB_16[k].Msk[ASC_HZ_WIDTH+j]&0x0f;
ch_w|=ch_r;
if(uCol+j<64)
SetPageCol(uPage,uCol+ASC_HZ_WIDTH);
else //汉字上半部是写半个字节
ch_r&=0x0f;
ch_w=ch_w<<4;
ch_w|=ch_r;
if(uCol+j<64)
ch_r=GB_16[k].Msk[j];
ch_w=GB_16[k].Msk[ASC_HZ_WIDTH+j];
ch_r=ch_r>>4;
ch_w=ch_w<<4;
ch_w|=ch_r;
if(uCol+j<64)
void disp_str(unsigned char *p)
unsigned char i=0;
while(p>0)
if(p < 127)
/* ASCII */
disp_char(p);
else
/* 中文 */
disp_hz(&p);
i++;
i++;
void main()
unsigned char i;
DDRD=0xFF;
DDRA=0xFF;
init_lcd();
clr_lcd();
for(i=0;i<128;i++) pixel(i,63,1);
for(i=0;i<64;i++) pixel(127,i,1);
for(i=0;i<128;i++) pixel(i,0,1);
for(i=0;i<64;i++) pixel(0,i,1);
SetRowCol(1,1);
disp_str("液晶显示的第二行123");
SetRowCol(2,1);
disp_str("液晶显示的第二行345");
SetRowCol(3,1);
disp_str("液晶显示的第三行456");
SetRowCol(4,1);
disp_str("液晶显示的第四行678");
SetRowCol(5,1);
disp_str("液晶显示的第五行789");
while(1)
asm("nop");
AVR stdio 编译 调试
程序一直等待在Busy 那里
求帮助
 楼主| Channe 发表于 2012-7-31 22:00 | 显示全部楼层
仿真是可以用的
申小林一号 发表于 2012-8-1 00:19 | 显示全部楼层
我也好想学,可惜没有板子……有没有啥活动啊?
 楼主| Channe 发表于 2012-8-1 20:49 | 显示全部楼层
没有人做过么
09电气 发表于 2012-8-12 12:27 | 显示全部楼层
不建议把这么长的程序贴上来,没什么人会全看的。贴程序的话就贴关键的部分吧
NE5532 发表于 2012-8-12 21:30 | 显示全部楼层
1.用仿真,对初学者不利,要用实物。
2.写这么长的程序才来调试?我都不敢。
楼主搜“侃单片机”精华帖里的“程序调试黑宝书”,看看程序应该怎么写。
个人签名:axb.me
