新手:CCS下的CPU load graph的问题
 楼主| yannyksr 发表于 2007-5-22 16:59 | 显示全部楼层 |阅读模式
帮助文件上是这样来的:<br />1.Choose&nbsp;DSP/BIOS瓹PU&nbsp;Load&nbsp;Graph.&nbsp;A&nbsp;blank&nbsp;CPU&nbsp;Load&nbsp;Graph&nbsp;appears.<br /><br />2.Right-click&nbsp;on&nbsp;the&nbsp;RTA&nbsp;Control&nbsp;Panel&nbsp;and&nbsp;choose&nbsp;Property&nbsp;Page&nbsp;from&nbsp;the&nbsp;shortcut&nbsp;menu.&nbsp;<br />3.&nbsp;&nbsp;&nbsp;&nbsp;Change&nbsp;the&nbsp;Refresh&nbsp;Rate&nbsp;for&nbsp;Statistics&nbsp;View/CPU&nbsp;Load&nbsp;Graph&nbsp;to&nbsp;0.5&nbsp;seconds&nbsp;and&nbsp;click&nbsp;OK.&nbsp;<br /><br />&nbsp;Notice&nbsp;that&nbsp;the&nbsp;CPU&nbsp;load&nbsp;is&nbsp;currently&nbsp;very&nbsp;low.<br />我按着做了,但没有出现帮助文件上的黑底蓝线的CPU负载图,只是一个灰色的表格,里面什么都没有。这是为什么?<br />编译运行都没错。
