以下是电路,我要的功能很简单,按键第按一次,数码管后两位显示加1,到100后回头,看这样写能不能称作“任务调度”,如果是,那么这种方式比较好处理,因为程序执行的间隔时间都是固定的,但对于有些交互式外设,如AD,DA,LCD,必须从对方读取数据,时间间隔是离散的,应该怎样安排任务? 以上请教!
- #include <reg51.h>
- #define uchar unsigned char
- uchar code tab[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
- uchar shu=85,count;
- bit flag;
- sbit kb=P3^4;
- void sumaguan()
- static uchar i=0;
- i++;
- P0=0XFF;
- P2=~(1<<(i-1));
- if(i<3)
- P0=0XC0;
- else if(i==3)
- P0=tab[shu/10];
- else if(i==4)
- P0=tab[shu%10];
- i=0;
- void anjianchuli()
- static uchar zhuangtai=0;
- switch(zhuangtai)
- case 0:
- if(kb==0)
- zhuangtai++;
- };break;
- case 1:
- if(kb==0)
- zhuangtai++;
- else
- zhuangtai--;
- };break;
- case 2:
- if(kb==0)
- zhuangtai++;
- shu++;
- if(shu==100)
- shu=0;
- else
- zhuangtai--;
- };break;
- case 3:
- if(kb==1)
- zhuangtai=0;
- };break;
- main()
- TMOD = 0x01;
- TH0 = 0x0E8;
- TL0 = 0x90;
- EA = 1;
- ET0 = 1;
- TR0 = 1;
- while(1)
- if(flag==1)
- flag=0;
- sumaguan();
- if(count>=3)
- anjianchuli();
- count=0;
- void timer0() interrupt 1
- flag=1;
- count++;
- TH0 = 0x0E8;
- TL0 = 0x90;
