使用STM32F2xx的FSMC无法写入norflash(S29NL032N)
 楼主| stonezh 发表于 2012-11-7 16:39 | 显示全部楼层 |阅读模式
一下是我的初始化,请问有什么吗?
void FSMC_NOR_Init(void)
  FSMC_NORSRAMInitTypeDef  FSMC_NORSRAMInitStructure;
  FSMC_NORSRAMTimingInitTypeDef  p;
  /* Enable GPIOs clock */
  RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOD | RCC_AHB1Periph_GPIOE | RCC_AHB1Periph_GPIOF |
                         RCC_AHB1Periph_GPIOG | RCC_AHB1Periph_GPIOB, ENABLE);
  /* Enable FSMC clock */
  RCC_AHB3PeriphClockCmd(RCC_AHB3Periph_FSMC, ENABLE);
  /*-- GPIOs Configuration -----------------------------------------------------*/
| PD0  <-> FSMC_D2  | PE0  <-> FSMC_NBL0 | PF0 <-> FSMC_A0  | PG0 <-> FSMC_A10 |
| PD1  <-> FSMC_D3  | PE1  <-> FSMC_NBL1 | PF1 <-> FSMC_A1  | PG1 <-> FSMC_A11 |
| PD4  <-> FSMC_NOE | PE2  <-> FSMC_A23  | PF2 <-> FSMC_A2  | PG2 <-> FSMC_A12 |
| PD5  <-> FSMC_NWE | PE3  <-> FSMC_A19  | PF3 <-> FSMC_A3  | PG3 <-> FSMC_A13 |
| PD8  <-> FSMC_D13 | PE4  <-> FSMC_A20  | PF4 <-> FSMC_A4  | PG4 <-> FSMC_A14 |
| PD9  <-> FSMC_D14 | PE5  <-> FSMC_A21  | PF5 <-> FSMC_A5  | PG5 <-> FSMC_A15 |
| PD10 <-> FSMC_D15 | PE6  <-> FSMC_A22  | PF12 <-> FSMC_A6 | PG9 <-> FSMC_NE2 |
| PD11 <-> FSMC_A16 | PE7  <-> FSMC_D4   | PF13 <-> FSMC_A7 | PG15 <->FSMC_RESET|
| PD12 <-> FSMC_A17 | PE8  <-> FSMC_D5   | PF14 <-> FSMC_A8 |------------------+
| PD13 <-> FSMC_A18 | PE9  <-> FSMC_D6   | PF15 <-> FSMC_A9 | PB7 <-> FSMC_NL |
| PD14 <-> FSMC_D0  | PE10 <-> FSMC_D7   |------------------+------------------+
| PD15 <-> FSMC_D1  | PE11 <-> FSMC_D8   |
| PD3 <-> FSMC_BYTE#| PE12 <-> FSMC_D9   |
| PD6 <-> FSMC_NWAIT| PE13 <-> FSMC_D10  |
| PD7 <-> FSMC_NE1  | PE14 <-> FSMC_D11  |
+-------------------| PE15 <-> FSMC_D12  |
  /* GPIOD configuration */
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
  GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
  GPIO_InitStructure.GPIO_PuPd  = GPIO_PuPd_NOPULL;
  GPIO_PinAFConfig(GPIOD, GPIO_PinSource0, GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOD, GPIO_PinSource1, GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOD, GPIO_PinSource4, GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOD, GPIO_PinSource5, GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOD, GPIO_PinSource8, GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOD, GPIO_PinSource9, GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOD, GPIO_PinSource10, GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOD, GPIO_PinSource11, GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOD, GPIO_PinSource12, GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOD, GPIO_PinSource13, GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOD, GPIO_PinSource14, GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOD, GPIO_PinSource15, GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOD, GPIO_PinSource3, GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOD, GPIO_PinSource6, GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOD, GPIO_PinSource7, GPIO_AF_FSMC);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0  | GPIO_Pin_1  | GPIO_Pin_4  | GPIO_Pin_5  |
                                GPIO_Pin_8  | GPIO_Pin_9  | GPIO_Pin_10 | GPIO_Pin_11 |
                                GPIO_Pin_12 | GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15|
                                GPIO_Pin_3  | GPIO_Pin_6  | GPIO_Pin_7;
  GPIO_Init(GPIOD, &GPIO_InitStructure);
  /* GPIOE configuration */
  //GPIO_PinAFConfig(GPIOE, GPIO_PinSource0 , GPIO_AF_FSMC);
  //GPIO_PinAFConfig(GPIOE, GPIO_PinSource1 , GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOE, GPIO_PinSource3 , GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOE, GPIO_PinSource4 , GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOE, GPIO_PinSource7 , GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOE, GPIO_PinSource8 , GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOE, GPIO_PinSource9 , GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOE, GPIO_PinSource10 , GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOE, GPIO_PinSource11 , GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOE, GPIO_PinSource12 , GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOE, GPIO_PinSource13 , GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOE, GPIO_PinSource14 , GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOE, GPIO_PinSource15 , GPIO_AF_FSMC);
  GPIO_InitStructure.GPIO_Pin = /*GPIO_Pin_0  | GPIO_Pin_1  |*/ GPIO_Pin_3 |
                                GPIO_Pin_4  | GPIO_Pin_7 |
                                GPIO_Pin_8  | GPIO_Pin_9  | GPIO_Pin_10 | GPIO_Pin_11|
                                GPIO_Pin_12 | GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15;
  GPIO_Init(GPIOE, &GPIO_InitStructure);
  /* GPIOF configuration */
  GPIO_PinAFConfig(GPIOF, GPIO_PinSource0 , GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOF, GPIO_PinSource1 , GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOF, GPIO_PinSource2 , GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOF, GPIO_PinSource3 , GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOF, GPIO_PinSource4 , GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOF, GPIO_PinSource5 , GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOF, GPIO_PinSource12 , GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOF, GPIO_PinSource13 , GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOF, GPIO_PinSource14 , GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOF, GPIO_PinSource15 , GPIO_AF_FSMC);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0  | GPIO_Pin_1  | GPIO_Pin_2  | GPIO_Pin_3  |
                                GPIO_Pin_4  | GPIO_Pin_5  | GPIO_Pin_12 | GPIO_Pin_13 |
  GPIO_Init(GPIOF, &GPIO_InitStructure);
  /* GPIOG configuration */
  GPIO_PinAFConfig(GPIOG, GPIO_PinSource0 , GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOG, GPIO_PinSource1 , GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOG, GPIO_PinSource2 , GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOG, GPIO_PinSource3 , GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOG, GPIO_PinSource4 , GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOG, GPIO_PinSource5 , GPIO_AF_FSMC);
  //GPIO_PinAFConfig(GPIOG, GPIO_PinSource9 , GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOG, GPIO_PinSource15 , GPIO_AF_FSMC);
                                GPIO_Pin_4  | GPIO_Pin_5  |/*GPIO_Pin_9|*/
                                GPIO_Pin_15;
  GPIO_Init(GPIOG, &GPIO_InitStructure);
   /* GPIOB configuration */
  GPIO_PinAFConfig(GPIOB, GPIO_PinSource7 , GPIO_AF_FSMC);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
  /*-- FSMC Configuration ----------------------------------------------------*/
  p.FSMC_AddressSetupTime = 0x05;
  p.FSMC_AddressHoldTime = 0x02;
  p.FSMC_DataSetupTime = 0x07;
  p.FSMC_BusTurnAroundDuration = 0x00;
  p.FSMC_CLKDivision = 0x00;
  p.FSMC_DataLatency = 0x00;
  p.FSMC_AccessMode = FSMC_AccessMode_B;
  FSMC_NORSRAMInitStructure.FSMC_Bank = FSMC_Bank1_NORSRAM1;
  FSMC_NORSRAMInitStructure.FSMC_DataAddressMux = FSMC_DataAddressMux_Disable;
  FSMC_NORSRAMInitStructure.FSMC_MemoryType = FSMC_MemoryType_NOR;
  FSMC_NORSRAMInitStructure.FSMC_MemoryDataWidth = FSMC_MemoryDataWidth_16b;
  FSMC_NORSRAMInitStructure.FSMC_BurstAccessMode = FSMC_BurstAccessMode_Disable;
  FSMC_NORSRAMInitStructure.FSMC_WaitSignalPolarity = FSMC_WaitSignalPolarity_Low;
  FSMC_NORSRAMInitStructure.FSMC_WrapMode = FSMC_WrapMode_Disable;
  FSMC_NORSRAMInitStructure.FSMC_WaitSignalActive = FSMC_WaitSignalActive_BeforeWaitState;
  FSMC_NORSRAMInitStructure.FSMC_WriteOperation = FSMC_WriteOperation_Enable;
  FSMC_NORSRAMInitStructure.FSMC_WaitSignal = FSMC_WaitSignal_Disable;
  FSMC_NORSRAMInitStructure.FSMC_ExtendedMode = FSMC_ExtendedMode_Disable;
  FSMC_NORSRAMInitStructure.FSMC_WriteBurst = FSMC_WriteBurst_Disable;
  FSMC_NORSRAMInitStructure.FSMC_ReadWriteTimingStruct = &p;
  FSMC_NORSRAMInitStructure.FSMC_WriteTimingStruct = &p;
  FSMC_NORSRAMInit(&FSMC_NORSRAMInitStructure);
  /* Enable FSMC Bank1_NOR Bank */
  FSMC_NORSRAMCmd(FSMC_Bank1_NORSRAM1, ENABLE);
IJK 发表于 2012-11-7 17:27 | 显示全部楼层
建议LZ先读NOR 的ID,看是否正确。
 楼主| stonezh 发表于 2012-11-7 19:30 | 显示全部楼层
NOR的ID读的是正确的。也能从编译环境中看到映射的NOR地址,也能将映射地址中的数据读出,但就是无法写数据
IJK 发表于 2012-11-8 09:43 | 显示全部楼层
如果NOR的读是正确的,那就好办了:
用示波器检查,检查一下/WR信号在写操作时是否正确,检查写数据的流程是否符合文档的要求。
还有容易忘记的一点:检查要写的那个block是否 lock住,或者不管它先unlock要写的那个block。
