touch
 楼主| tomitomi 发表于 2007-8-27 09:39 | 显示全部楼层 |阅读模式
unsigned char Touch_data_process(unsigned char touch_command)
    unsigned int idata temp;
    I2CWriteByte_noAddrsss(Touch_tsc2003_address,touch_command);
    temp = I2CReadByte_TK2003(Touch_tsc2003_address);
    return((temp>>8)&0xff);
unsigned char I2CWriteByte_noAddrsss(unsigned char cDevAddr,unsigned char cData)
    /* start condition */
    StartCondition();
      cDevAddr &= 0xFE;   /*Force WRITE address*/
    /* send device ID and write data */
    if(!Send_Byte(cDevAddr))
        if(!Send_Byte(cData))
            StopCondition();
            return(0);      /* success */
    StopCondition();
    return(1);
unsigned int I2CReadByte_TK2003(unsigned char cDevAddr)
    unsigned int temp;
    StartCondition();
    if(Send_Byte(cDevAddr | 0x01))
        return 0;  /*Write address*/
    temp = Read_Byte(1);
    temp<<=8;
    temp |= Read_Byte(1);
    StopCondition();
    return(temp);
#define X_POSITION_COMMAND        0xc6    //8bit ADC
#define Y_POSITION_COMMAND        0xd6    //8bit ADC
datax = Touch_data_process(X_POSITION_COMMAND);
    datay = Touch_data_process(Y_POSITION_COMMAND);
