发送机代码:
#include "msp430g2553.h"
unsigned char TxByte=0;
void main(void)
WDTCTL = WDTPW + WDTHOLD; // Stop WDT
BCSCTL1 = CALBC1_1MHZ; // Set DCO
DCOCTL = CALDCO_1MHZ;
P1SEL = BIT1 + BIT2 ; // P1.1 = RXD, P1.2=TXD
P1SEL2 = BIT1 + BIT2;
P1OUT = 0x00; // P1.0/6 setup for LED output
P1DIR = BIT0 + BIT6;
UCA0CTL1 |= UCSSEL_2; // SMCLK
UCA0BR0 = 8; // 1MHz 115200
UCA0BR1 = 0; // 1MHz 115200
UCA0MCTL = UCBRS2 + UCBRS0; // Modulation UCBRSx = 5
UCA0CTL1 &= ~UCSWRST; // **Initialize USCI state machine**
IE2 |= UCA0RXIE + UCA0TXIE; // Enable USCI_A0 TX/RX interrupt
__bis_SR_register(LPM3_bits + GIE); // Enter LPM3 w/ interrupts enabled
// USCI A0/B0 Transmit ISR
#pragma vector=USCIAB0TX_VECTOR
__interrupt void USCI0TX_ISR(void)
UCA0TXBUF = TxByte;
TxByte++;
__delay_cycles(500000);
#pragma vector=USCIAB0RX_VECTOR
__interrupt void USCI0RX_ISR(void)
接收机代码:
void main(void)
IE2 |= UCA0TXIE + UCA0RXIE; // Enable USCI_A0 TX/RX interrupt
// USCI A0/B0 Receive ISR
while(!(UC0IFG&UCA0RXIFG))
P1OUT = UCA0RXBUF; // Display RX'ed charater
