麻烦帮小弟一个忙
 楼主| GLJLQ 发表于 2009-3-2 16:00 | 显示全部楼层 |阅读模式
ck, TI, ce, AN, FOR
我在用xilinx的FPGA进行相关项目的设计,只有在生成编程文件的时候会有错误报告,我在前面进行布局布线的时候有个错误信息如下&nbsp;Place:848&nbsp;-&nbsp;Automatic&nbsp;clock&nbsp;placement&nbsp;failed.&nbsp;Please&nbsp;attempt&nbsp;to&nbsp;analyze&nbsp;the&nbsp;global&nbsp;clocking&nbsp;required&nbsp;for&nbsp;this<br />&nbsp;&nbsp;&nbsp;design&nbsp;and&nbsp;either&nbsp;lock&nbsp;the&nbsp;clock&nbsp;placement&nbsp;or&nbsp;area&nbsp;locate&nbsp;the&nbsp;logic&nbsp;driven&nbsp;by&nbsp;the&nbsp;clocks&nbsp;so&nbsp;that&nbsp;that&nbsp;the&nbsp;clocks&nbsp;may<br />&nbsp;&nbsp;&nbsp;be&nbsp;placed&nbsp;in&nbsp;such&nbsp;a&nbsp;way&nbsp;that&nbsp;all&nbsp;logic&nbsp;driven&nbsp;by&nbsp;them&nbsp;may&nbsp;be&nbsp;routed.&nbsp;The&nbsp;main&nbsp;restriction&nbsp;on&nbsp;clock&nbsp;placement&nbsp;is&nbsp;that<br />&nbsp;&nbsp;&nbsp;only&nbsp;one&nbsp;clock&nbsp;output&nbsp;signal&nbsp;for&nbsp;any&nbsp;competing&nbsp;Global&nbsp;/&nbsp;Side&nbsp;pair&nbsp;of&nbsp;clocks&nbsp;may&nbsp;enter&nbsp;any&nbsp;region.&nbsp;For&nbsp;further<br />&nbsp;&nbsp;&nbsp;information&nbsp;see&nbsp;the&nbsp;&quot;Quadrant&nbsp;Clock&nbsp;Routing&quot;&nbsp;section&nbsp;in&nbsp;the&nbsp;Spartan3e&nbsp;Family&nbsp;Datasheet.<br /><br />&nbsp;&nbsp;&nbsp;The&nbsp;competing&nbsp;Global&nbsp;/&nbsp;Side&nbsp;clock&nbsp;buffers&nbsp;for&nbsp;this&nbsp;device&nbsp;are&nbsp;as&nbsp;follows:&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Global&nbsp;:&nbsp;Side&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;BUFGMUX_X1Y10&nbsp;:&nbsp;&nbsp;&nbsp;&nbsp;BUFGMUX_X0Y9<br />&nbsp;&nbsp;BUFGMUX_X1Y10&nbsp;:&nbsp;&nbsp;&nbsp;&nbsp;BUFGMUX_X3Y9<br />&nbsp;&nbsp;BUFGMUX_X1Y11&nbsp;:&nbsp;&nbsp;&nbsp;&nbsp;BUFGMUX_X0Y8<br />&nbsp;&nbsp;BUFGMUX_X1Y11&nbsp;:&nbsp;&nbsp;&nbsp;&nbsp;BUFGMUX_X3Y8<br />&nbsp;&nbsp;BUFGMUX_X2Y10&nbsp;:&nbsp;&nbsp;&nbsp;&nbsp;BUFGMUX_X0Y7<br />&nbsp;&nbsp;BUFGMUX_X2Y10&nbsp;:&nbsp;&nbsp;&nbsp;&nbsp;BUFGMUX_X3Y7<br />&nbsp;&nbsp;BUFGMUX_X2Y11&nbsp;:&nbsp;&nbsp;&nbsp;&nbsp;BUFGMUX_X0Y6<br />&nbsp;&nbsp;BUFGMUX_X2Y11&nbsp;:&nbsp;&nbsp;&nbsp;&nbsp;BUFGMUX_X3Y6<br />&nbsp;&nbsp;&nbsp;BUFGMUX_X1Y0&nbsp;:&nbsp;&nbsp;&nbsp;&nbsp;BUFGMUX_X0Y5<br />&nbsp;&nbsp;&nbsp;BUFGMUX_X1Y0&nbsp;:&nbsp;&nbsp;&nbsp;&nbsp;BUFGMUX_X3Y5<br />&nbsp;&nbsp;&nbsp;BUFGMUX_X1Y1&nbsp;:&nbsp;&nbsp;&nbsp;&nbsp;BUFGMUX_X0Y4<br />&nbsp;&nbsp;&nbsp;BUFGMUX_X1Y1&nbsp;:&nbsp;&nbsp;&nbsp;&nbsp;BUFGMUX_X3Y4<br />&nbsp;&nbsp;&nbsp;BUFGMUX_X2Y0&nbsp;:&nbsp;&nbsp;&nbsp;&nbsp;BUFGMUX_X0Y3<br />&nbsp;&nbsp;&nbsp;BUFGMUX_X2Y0&nbsp;:&nbsp;&nbsp;&nbsp;&nbsp;BUFGMUX_X3Y3<br />&nbsp;&nbsp;&nbsp;BUFGMUX_X2Y1&nbsp;:&nbsp;&nbsp;&nbsp;&nbsp;BUFGMUX_X0Y2<br />&nbsp;&nbsp;&nbsp;BUFGMUX_X2Y1&nbsp;:&nbsp;&nbsp;&nbsp;&nbsp;BUFGMUX_X3Y2<br />哪位大虾帮忙解决一下告诉我是怎么回事怎么解决它,困扰了很长时间了。注我没有添加任何的约束信息。完全是软件默认设置。
