28027在CCS中的ADC模块的程序改不了寄存器的值!为什么呢?
 楼主| jinpaidianzi 发表于 2013-10-31 00:08 | 显示全部楼层 |阅读模式
F28027在CCS中的ADC模块的程序在调试时改不了寄存器的值,这是为什么呢??应该已经使能ADC模块了的。
附源程序:
#include "DSP28x_Project.h"
interrupt void tim0_isr(void);
interrupt void ADC_convered(void);
Uint16 ADCINA0_Voltage_sum = 0;
Uint16 ADCINA1_Voltage_sum = 0;
Uint16 ADCINA2_Voltage_sum = 0;
Uint16 ADCINA0_Voltage = 0;
Uint16 ADCINA1_Voltage = 0;
Uint16 ADCINA2_Voltage = 0;
char convered_count = 0;
void main(void)
  InitSysCtrl();
   InitGpio();
  DINT;
  InitPieCtrl();
IER = 0x0000;    IFR = 0x0000;
InitPieVectTable();
    InitAdc();
    EALLOW;
    AdcRegs.ADCSAMPLEMODE.bit.SIMULEN0 = 0; //SOC0、SOC1单一采样
AdcRegs.ADCSAMPLEMODE.bit.SIMULEN2 = 0; //SOC2、SOC3单一采样
AdcRegs.ADCSOC0CTL.bit.CHSEL=0;   //SOC通道选择
AdcRegs.ADCSOC1CTL.bit.CHSEL=1;
AdcRegs.ADCSOC2CTL.bit.CHSEL=2;
AdcRegs.ADCSOC0CTL.bit.ACQPS = 6;  //采样时间
AdcRegs.ADCSOC1CTL.bit.ACQPS = 6;
AdcRegs.ADCSOC2CTL.bit.ACQPS = 6;
AdcRegs.ADCSOC0CTL.bit.TRIGSEL = 1;  //soc触发选择,TIM0
AdcRegs.ADCCTL1.bit.INTPULSEPOS  = 1;   //结果存入寄存器才产生中断
    PieVectTable.ADCINT1 = &ADC_convered;
AdcRegs.INTSEL1N2.bit.INT1SEL = 2;    //中断线1选择soc2
AdcRegs.INTSEL1N2.bit.INT1CONT  = 0;
AdcRegs.INTSEL1N2.bit.INT1E  = 1;    //中断使能
    PieCtrlRegs.PIEIER1.bit.INTx1 = 1;   //使能int1.1     EDIS;
/****************设置定时器,用以触发ADC*****************/
CpuTimer0Regs.TPR.bit.TDDR = 59;
CpuTimer0Regs.TPRH.bit.TDDRH = 0; //对输入时钟60分频,60M/60=1M
CpuTimer0Regs.PRD.all = 500000;//定时0.5s
CpuTimer0Regs.TCR.bit.TRB = 1; //reload
CpuTimer0Regs.TCR.bit.TIE = 1; //使能中断
CpuTimer0Regs.TCR.bit.TSS = 0; //开始计数
    EALLOW;     PieVectTable.TINT0 = &tim0_isr;
PieCtrlRegs.PIECTRL.bit.ENPIE = 1;   //使能PIE
PieCtrlRegs.PIEIER1.bit.INTx7 = 1;   //使能int1.7
IER |= 0x0001;//使能GROUP1
EINT;
EDIS;
{      //LED_toggle(LED2);
ADCINA0_Voltage_sum += AdcResult.ADCRESULT0;
ADCINA1_Voltage_sum += AdcResult.ADCRESULT1;
ADCINA2_Voltage_sum += AdcResult.ADCRESULT2;
AdcRegs.ADCINT标志寄存器CLR.bit.ADCINT1 = 1;
PieCtrlRegs.PIEACK.all = PIEACK_GROUP1;
convered_count++;
/*********转换16次,取平均值*********/
if(convered_count > 15)
{          ADCINA0_Voltage = ADCINA0_Voltage_sum >> 4;//相当于除以16
            ADCINA1_Voltage = ADCINA1_Voltage_sum >> 4;
           ADCINA2_Voltage = ADCINA2_Voltage_sum >> 4;
            convered_count = 0;      }
{     PieCtrlRegs.PIEACK.all = PIEACK_GROUP1;  }
// No more.
拿起书本 发表于 2013-11-20 15:31 | 显示全部楼层
建议楼主检查一下看看时钟打开了没有?还有个问题,楼主说的
改变不了什么寄存器???
zhangmangui 发表于 2013-11-22 00:10 | 显示全部楼层
确认一下ADC的时钟有没有使能
找一个工程对比一下
确认一下ADC的时钟有没有使能
找一个工程对比一下
