STM32F207使用SWD无法下载程序
 楼主| zchong 发表于 2013-11-9 20:12 | 显示全部楼层 |阅读模式
仅留了SWD口,无法下载程序,求助!MDK下出错信息如下:
DLL: V4.68a, compiled Apr 12 2013 13:26:50
Firmware: J-Link ARM-OB STM32 compiled Aug 22 2012 19:52:04
Hardware: V7.00
S/N : 305760245
Feature(s) : RDI,FlashDL,FlashBP,JFlash,GDBFull
* JLink Info: Found SWD-DP with ID 0x2BA01477
* JLink Info: TPIU fitted.
* JLink Info: ETM fitted.
* JLink Info: FPUnit: 6 code (BP) slots and 2 literal slots
* JLink Info: Found Cortex-M3 r2p0, Little endian.
ROMTableAddr = 0xE00FF003
* JLink Info: Core is locked-up, trying to disable WDT.
**JLink Warning: T-bit of XPSR is 0 but should be 1. Changed to 1.
Target info:
Device: STM32F207ZG
VTarget = 3.300V
State of Pins:
TCK: 0, TDI: 0, TDO: 1, TMS: 0, TRES: 1, TRST: 1
Hardware-Breakpoints: 6
Software-Breakpoints: 8192
Watchpoints:          4
JTAG speed: 2000 kHz
Erase Failed!
 楼主| zchong 发表于 2013-11-14 20:29 | 显示全部楼层
设置成从内部bootloader启动,然后连接仿真器,使用unlock工具解锁,再重新烧写即可!
