[51单片机] C8051F9x内部SmaRTClock问题
 楼主| huhaomcu 发表于 2013-11-17 09:48 | 显示全部楼层 |阅读模式
想利用C8051内部的SmaRTClock的闹钟事件,但不知道驱动那里写的不对!还请大家帮我看一下!!
void SysInit( void )
FLSCL     = 0x40;
OSCICN    = 0x8F;
CLKSEL    = 0x00;
PCA0MD    &= ~0x40;        // disable WDT
XBR2      = 0x40;        // enable crossbar
unsigned char SmaRTClockRead( unsigned char add )
        RTC0ADR = (0x90 | add);
        NOP();
        NOP();
        NOP();
        return RTC0DAT;
void SmaRTClockWrite( unsigned char add,unsigned char val )
        RTC0ADR = (0x10 | add);
        RTC0DAT = val;
void SmaRTClockWriteAlarm( unsigned long val )
        unsigned char temp;
        RTC0ADR = (0x10 | RTC0CN);
        RTC0DAT &= ~RTC0AEN;        //SamRTClock alarm disable
        NOP();
        //Write the value to the alarm registers
        RTC0ADR = (0x10 | ALARM0);
       RTC0DAT = val;
        NOP();
        RTC0DAT = (val>>8);
        NOP();
        RTC0DAT = (val>>16);
        NOP();
        RTC0DAT = (val>>24);
        NOP();
      temp = SmaRTClockRead(RTC0CN);
     RTC0DAT = (temp | RTC0AEN | RTC0TR);        // SamRTClock alarm enable
void SmaRTClockInit( void )
        // If the interface is locked
        if(RTC0KEY == 0x00)
                RTC0KEY = 0xA5;                  // Unlock the smaRTClock interface
                RTC0KEY = 0xF1;
        #ifdef CRYSTALMODE
        #endif
        #ifdef SELFOSC
          SmaRTClockWrite(RTC0PIN, 0xE7);       // Short XTAL3 and XTAL4 together
          SmaRTClockWrite(RTC0XCN, 0x00);       // Configure smaRTClock in
          SmaRTClockWrite(RTC0XCF, 0x80);       // enable Automatic Load Capacitiance
          SmaRTClockWrite(RTC0CN, 0x80);        // Enable smaRTClock oscillator
          SmaRTClockWrite(RTC0CN, 0xC0);
void main( void )
        unsigned char temp;
        SysInit();
        SmaRTClockInit();
        //SmaRTClockWriteAlarm(0x30d40);
        SmaRTClockWriteAlarm(0x4E20);
        while(1)
                if( temp & 0x04 )
                        P2_0 = !P2_0;
            temp &= ~0x08;        // clear alarm interrupt flag
            SmaRTClockWrite(RTC0CN,temp);
            temp |= 0x08;        // clear alarm interrupt flag
hnkf118 发表于 2015-8-24 22:45 | 显示全部楼层
还行的把。你什么问题?
