请各位专家指点一下:- DMA_InitTypeDef DMA_InitStructure; //DMA³õʼ»¯½á¹¹ÌåÉùÃ÷
- void DMA_Config(void)
- //ADC_InitTypeDef ADC_InitStructure;
- //ADC_CommonInitTypeDef ADC_CommonInitStructure;
- //DMA_InitTypeDef DMA_InitStructure;
- //GPIO_InitTypeDef GPIO_InitStructure;
- /* Enable ADC1, DMA2 and GPIO clocks ****************************************/
- RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2 | RCC_AHB1Periph_GPIOC, ENABLE);
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);
- DMA_DeInit(DMA2_Stream0);
- /* DMA2 Stream0 channel2 configuration **************************************/
- DMA_InitStructure.DMA_Channel = DMA_Channel_0;
- DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)ADC1_DR_ADDRESS;
- DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)&ADC1ConvertedValue;
- DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory;
- DMA_InitStructure.DMA_BufferSize = SAMPLEING_POINTS;
- DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
- DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;//DMA_MemoryInc_Disable;
- DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
- DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
- DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;//DMA_Mode_Normal;//
- DMA_InitStructure.DMA_Priority = DMA_Priority_High;
- DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;
- DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull;
- DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
- DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
- DMA_Init(DMA2_Stream0, &DMA_InitStructure);
- DMA_Cmd(DMA2_Stream0, ENABLE);
- DMA_ITConfig(DMA2_Stream0, DMA_IT_TC, ENABLE);
- void DMA2_Stream0_IRQHandler(void)
- //if (DMA_GetFlagStatus(DMA2_Stream0, DMA_IT_TCIF0) != RESET)
- if (DMA_GetITStatus(DMA2_Stream0, DMA_IT_TCIF0) != RESET)
- DMA_ClearITPendingBit(DMA2_Stream0, DMA_IT_TCIF0);
- //DMA_ClearFlag(DMA2_Stream0,DMA_FLAG_TCIF0);
- //DMA_Cmd(DMA2_Stream0, DISABLE);
- ADC_SoftwareStartConvCmd(ADC1,DISABLE);
- DMA_Cmd(DMA2_Stream0, DISABLE);
- DMARecFlag=1;
- void DMAReConfig(void)
- while (1)
- #ifdef PRINT_ON_LCD
- /* Display ADC converted value on LCD */
- Display(max,max_position);
- #endif
- //ADC_Cmd(ADC1, ENABLE);
- if (ADCStartFlag==1)
- //DMA_Config();
- //DMA2_Stream0->CNDTR = 0x00000064;
- //ADC_Config();
- //DMA_Cmd(DMA2_Stream0, ENABLE);
- //ADC_DMACmd(ADC1, ENABLE);
- ADC_SoftwareStartConvCmd(ADC1,ENABLE);//¿ªÊ¼²É¼¯
- ADCStartFlag=0;
- while(DMARecFlag==1) //´«Êä½áÊø£¬½øÐмÆËã
- DMARecFlag=0;
- //ADC_Cmd(ADC1, DISABLE);
- //ADC_SoftwareStartConvCmd(ADC1,DISABLE);
- DMAReConfig();
- // DMA_Config();
- max=0;
- for(i=0;i<SAMPLEING_POINTS ;i++)
- if (ADC1ConvertedValue[i]>max)
- { max=ADC1ConvertedValue[i];
- max_position=i;
- j=max;
- //break;
