- /* Copyright(c) 2009 Nuvoton Technology Corp. All rights reserved. */
- #include <stdio.h>
- #include "NUC1xx.h"
- #include "Driver\DrvGPIO.h"
- #include "Driver\DrvI2C.h"
- #include "Driver\DrvSYS.h"
- #include "EEPROM_I2C_24LC64.h"
- void Write_24LC64(uint32_t address,uint8_t data )
- uint32_t i;
- SystemCoreClock = DrvSYS_GetHCLKFreq();
- //Open I2C1 and set clock = 50Kbps
- DrvI2C_Open(I2C_PORT1, 50000);
- //send i2c start
- DrvI2C_Ctrl(I2C_PORT1, 1, 0, 0, 0); //set start
- while (I2C1->I2CON.SI == 0); //poll si flag
- //send writer command
- I2C1->I2CDAT = 0XA0; //send writer command
- DrvI2C_Ctrl(I2C_PORT1, 0, 0, 1, 0); //clr si flag
- while( I2C1->I2CON.SI == 0 ); //poll si flag
- //send address high
- I2C1->I2CDAT = (address>>8)&0XFF;
- DrvI2C_Ctrl(I2C_PORT1, 0, 0, 1, 1); //clr si and set ack
- //send address low
- I2C1->I2CDAT = address&0XFF;
- //send data
- I2C1->I2CDAT = data; //write data to
- //send i2c stop
- DrvI2C_Ctrl(I2C_PORT1, 0, 1, 1, 0); //send stop
- while( I2C1->I2CON.STO);
- //while( I2C1->CON.SI == 0 );
- for(i=0;i<60;i++);
- DrvI2C_Close(I2C_PORT1);
- for(i=0;i<6000;i++);
- uint8_t Read_24LC64(uint32_t address)
- uint8_t TEMP;
- //send i2c start
- DrvI2C_Ctrl(I2C_PORT1, 1, 0, 1, 0); //set start
- DrvI2C_Ctrl(I2C_PORT1, 0, 0, 1, 0); //clr si and set ack
- //send start flag
- DrvI2C_Ctrl(I2C_PORT1, 1, 0, 1, 0); //clr si and send start
- //send read command
- I2C1->I2CDAT = 0XA1;
- //resive data
- I2C1->I2CDAT = 0XFF;
- TEMP= I2C1->I2CDAT;
- //send i2c stop
- DrvI2C_Ctrl(I2C_PORT1, 0, 1, 1, 0); //clr si and set stop
- return TEMP;
