[STM32F1] 为什么USART3口可以接收到数据,但没数据发送?
 楼主| gzzcq 发表于 2014-5-20 14:48 | 显示全部楼层 |阅读模式
这段是IO配置
/* Configure USART3 Tx (PB.10) as alternate function push-pull */
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
        GPIO_Init(GPIOB, &GPIO_InitStructure);
        /* Configure USART3 Rx (PB.11) as input floating */
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
下面一段是USART3端口初始化
void USART_Configuration(u16 port, u32 bandrate)
        USART_InitTypeDef USART_InitStructure;
        USART_StructInit(&USART_InitStructure);
        USART_InitStructure.USART_BaudRate = bandrate;
        if(port == 1)
                USART_Init(USART1, &USART_InitStructure);
                USART_Cmd(USART1, ENABLE);
                USART_ITConfig(USART1,USART_IT_RXNE,ENABLE);
        else if(port == 2)
                USART_Init(USART2, &USART_InitStructure);
                USART_Cmd(USART2, ENABLE);
                USART_ITConfig(USART2,USART_IT_RXNE,ENABLE);
        else if(port == 3)
                USART_Init(USART3, &USART_InitStructure);
                USART_Cmd(USART3, ENABLE);
                USART_ITConfig(USART3,USART_IT_RXNE,ENABLE);
        else if(port == 4)
                USART_Init(UART4, &USART_InitStructure);
                USART_Cmd(UART4, ENABLE);
                USART_ITConfig(UART4,USART_IT_RXNE,ENABLE);
        else if(port == 5)
                USART_Init(UART5, &USART_InitStructure);
                USART_Cmd(UART5, ENABLE);
                USART_ITConfig(UART5,USART_IT_RXNE,ENABLE);
}//void USART_Configuration(u16 port, u32 bandrate)
会有这句调用:USART_Configuration(3, 9600);
下面是中断处理函数
void USART3_IRQHandler(void)
        if(USART_GetFlagStatus(USART3, USART_FLAG_RXNE))
                Uart3_ucReceLen = Uart3_ucReceLen & (UART_BUFF_LEN - 1);
                Uart3_ucReceBuff[Uart3_ucReceLen++] = USART_ReceiveData(USART3);
                Uart3_udTimeOut = udTickCount + 10;
        else if(USART_GetFlagStatus(USART3, USART_FLAG_TC))
                if(Uart3_ucSendPosi < Uart3_ucSendLen) USART_SendData(USART3,Uart3_ucSendBuff[Uart3_ucSendPosi++]);
                else {USART_ITConfig(USART3,USART_IT_TC,DISABLE);
                Uart3_udTimeOut = udTickCount + 10;         }
采用MODBUS协议,能顺利接收到数据,通过检测知道,也能进发送中断,并将数据发送出去,但TXD3口没有电平变化,以为是芯片的这个口坏了,换了一个也是这样,用的芯片是STM32F105VCT6
求牛人指导
airwill 发表于 2014-5-20 15:00 | 显示全部楼层
既然能接收了, 时钟和外设选择没有问题了
发送不了,
1. 端口设置
2. 发送允许
用调试器进去, 在运行状态看看, 外设寄存器是不是你要的设置, 有没有被其他模块给错误地改掉了?
 楼主| gzzcq 发表于 2014-5-20 16:25 | 显示全部楼层
发送不了,
1. 端口设置
重新对比了一下,很奇怪,同样的代码,USART1和USART2都能正常工作,就是USART3不行(能接收,也能发送,但就是PB10口没数据出来)
mmuuss586 发表于 2014-5-20 17:05 | 显示全部楼层
重新对比了一下,很奇怪,同样的代码,USART1和USART2都能正常工作,就是USART3不行(能接收,也能发送, ...
看程序没啥问题;
可能你其它地方有冲突吧;
先查查看,实在解决不了,发个工程上来(不相干的可以去掉),帮你测试下
 楼主| gzzcq 发表于 2014-5-20 18:49 | 显示全部楼层
@mmuuss586
这是工程,麻烦帮我看一些,谢谢:handshake
基础程序21.rar
805.54 KB, 阅读权限: 100, 下载次数: 2
mmuuss586 发表于 2014-5-20 18:54 | 显示全部楼层
@mmuuss586
这是工程,麻烦帮我看一些,谢谢
:D
明天吧,家里没板子呢;
 楼主| gzzcq 发表于 2014-5-21 09:48 | 显示全部楼层
明天吧,家里没板子呢;
有发现没?:handshake
mmuuss586 发表于 2014-5-21 09:48 | 显示全部楼层
有发现没?
马上看
mmuuss586 发表于 2014-5-21 10:13 | 显示全部楼层
有发现没?
没看出来,串口部分,对了下我自己的程序,和你的一样的。
我用的107,开了3个串口;
你单独写个串口3通讯程序测试下,是不是哪里改写了;
 楼主| gzzcq 发表于 2014-5-21 11:33 | 显示全部楼层
我用的107,开了3个串口;
你单独写个串口3 ...
这个是完整的程序(当然不包含用户程序,用户程序就是根据DI来执行DO动作,纯粹C语言的,不会与硬件关联,通讯口就是和触摸屏连接)。就是在这个程序基础上,USART1和2都OK,4和5也是OK的,就是3的TXD不出数据,昨天你建议我看寄存器,我和1和2比较过,是相同的。
卡在这,郁闷呀!
这个是完整的程序(当然不包含用户程序,用户程序就是根据DI来执行DO动作,纯粹C语言的,不会与硬件关联 ...
用你的板测试,USART3工作正常码?
mmuuss586 发表于 2014-5-21 11:34 | 显示全部楼层
恩,所以你就先写个单独的串口3程序测试下,慢慢查,急不来的;
mmuuss586 发表于 2014-5-21 11:41 | 显示全部楼层
用你的板测试,USART3工作正常码?
我的板测试了下,运行不了;
先去吃饭,等会继续;
mmuuss586 发表于 2014-5-21 13:46 | 显示全部楼层
void NVIC_Configuration(void)
    NVIC_InitTypeDef NVIC_InitStructure;
    /* Configure the NVIC Preemption Priority Bits */
    NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
/* Enable the USART3 Interrupt */
    NVIC_InitStructure.NVIC_IRQChannel = 39;
    NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
    NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
    NVIC_Init(&NVIC_InitStructure);
  * @brief   Main program
  * @param  None
  * @retval None
void USART_Configuration(void)
//ʹÄܸßËÙ×ÜÏßÉϵÄÍâÉèʱÖÓ
RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOB , ENABLE);
RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART3 , ENABLE);
USART_InitStructure.USART_BaudRate = 9600;
USART_InitStructure.USART_WordLength = USART_WordLength_8b;
USART_InitStructure.USART_StopBits = USART_StopBits_1;
USART_InitStructure.USART_Parity = USART_Parity_No;
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
USART_ITConfig(USART3, USART_IT_RXNE, ENABLE);
          ´Ó USART3 ·¢ËÍÒ»¸ö×Ö½Ú
void USART3_SendByte(unsigned char temp)
    USART_SendData(USART3, temp);
    while(USART_GetFlagStatus(USART3, USART_FLAG_TXE) == RESET);
int main(void)
  /*!< At this stage the microcontroller clock setting is already configured,
       this is done through SystemInit() function which is called from startup
       file (startup_stm32f10x_md.s) before to branch to application main.
       To reconfigure the default setting of SystemInit() function, refer to
       system_stm32f10x.c file
  /* SysTick end of count event each 1ms */
  RCC_GetClocksFreq(&RCC_Clocks);
  SysTick_Config(RCC_Clocks.HCLK_Frequency / 1000);
USART_Configuration();
NVIC_Configuration();
  /* Infinite loop */
  while (1)
  USART3_SendByte(0x55);
mmuuss586 发表于 2014-5-21 13:49 | 显示全部楼层
初始化肯定是没问题的;
你查下,发送程序,还有其它什么地方是否有问题;
main.rar (2.27 KB, 下载次数: 11)
 楼主| gzzcq 发表于 2014-5-21 15:56 | 显示全部楼层
初始化肯定是没问题的;
你给我的这个程序是可以的?
mmuuss586 发表于 2014-5-21 16:02 | 显示全部楼层
你给我的这个程序是可以的?
恩,我107,103的板子都有,一直在用的;
接的也是PB10,11;
实际测试,串口3一直发数据(PB10,11短接),每次都能进入中断的
 楼主| gzzcq 发表于 2014-5-27 10:57 | 显示全部楼层
都没遇到这样的问题?
 楼主| gzzcq 发表于 2014-5-27 11:07 | 显示全部楼层
谁有ST技术支持的电话,给个我,谢谢!
一点都不会 发表于 2016-1-6 17:27 | 显示全部楼层
我现在也在做UART3的收发,我的发送和接受都不行。我用的是STM32F103C8T6的板子
