程序疑惑
 楼主| zhenykun 发表于 2014-6-3 19:55 | 显示全部楼层 |阅读模式
/***************   writer:shopping.w   ******************/
#include <reg52.h>
#define uint unsigned int
#define uchar unsigned char
uchar code FFW[]=          //正转
         0x01,0x03,0x02,0x06,0x04,0x0c,0x08,0x09
uchar code REV[]=        //反转
         0x09,0x08,0x0c,0x04,0x06,0x02,0x03,0x01
sbit K1 = P3^0;
sbit K2 = P3^1;
sbit K3 = P3^2;
void DelayMS(uint ms)  //延时
         uchar i;
         while(ms--)
                  for(i=0;i<120;i++);
void SETP_MOTOR_FFW(uchar n)   //正转
         uchar i,j;
         for(i=0;i<1*n;i++)
                  for(j=0;j<8;j++)
                          if(K3 == 0)        break;
                         P1 = FFW[j];
                         DelayMS(25);
void SETP_MOTOR_REV(uchar n)  //反转
         uchar i,j;
         for(i=0;i<1*n;i++)
                  for(j=0;j<8;j++)
                          if(K3 == 0)        break;
                         P1 = REV[j];
                         DelayMS(25);
void main()
         uchar N = 1;
         while(1)
                  if(K1 == 0)
                 {  while(K1==0);
                          P0 = 0xfe; //正转LED指示
                         SETP_MOTOR_FFW(N);
                         if(K3 == 0) break;
                 else if(K2 == 0)
                 {        while(K2==0);
                          P0 = 0xfd;        //反转LED指示
                         SETP_MOTOR_REV(N);
                         if(K3 == 0) break;
                 else
                          P0 = 0xfb;          //停LED指示
                         P1 = 0x03;
当按下K1(K2)时怎么每次都正转72°(反转72°)?
怎么改让它只转9°
wyjie 发表于 2014-6-3 19:56 | 显示全部楼层
不懂,帮顶吧
 楼主| zhenykun 发表于 2014-6-3 19:56 | 显示全部楼层
多谢,已解决,还是亲自问人来的快
wyjie 发表于 2014-6-3 19:57 | 显示全部楼层
怎么解决的?
 楼主| zhenykun 发表于 2014-6-3 19:58 | 显示全部楼层
很简答,都不好意思说了
