跑1ghz的am335x,直接emmc启动,完全兼容beaglebone
 楼主| 盈鹏飞科技 发表于 2014-6-27 11:45 | 显示全部楼层 |阅读模式
emmc启动速度很快!!10s内启动完毕!比nand启动要速度快!
U-Boot SPL 2014.04-rc2 (Jun 24 2014 - 14:05:00)
reading u-boot.img
reading u-boot.img
U-Boot 2014.04-rc2 (Jun 24 2014 - 14:05:00)
I2C:   ready
DRAM:  512 MiB
MMC:   OMAP SD/MMC: 0, OMAP SD/MMC: 1
Net:   cpsw
Hit any key to stop autoboot:  0
1152054 bytes read in 77 ms (14.3 MiB/s)
Card did not respond to voltage select!
mmc0(part 0) is current device
mmc1(part 0) is current device
SD/MMC found on device 1
reading uEnv.txt
239 bytes read in 4 ms (57.6 KiB/s)
Loaded environment from uEnv.txt
Importing environment from mmc ...
reading uImage
3015344 bytes read in 188 ms (15.3 MiB/s)
## Booting kernel from Legacy Image at 82000000 ...
   Image Name:   Linux-3.2.0
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    3015280 Bytes = 2.9 MiB
   Load Address: 80008000
   Entry Point:  80008000
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
Starting kernel ...
[    0.000000] Linux version 3.2.0 (Vic@EAC) (gcc version 4.7.3 20130226 (prerel
ease) (crosstool-NG linaro-1.13.1-4.7-2013.03-20130313 - Linaro GCC 2013.03) ) #
2 Wed Jun 18 17:13:26 CST 2014
[    0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instructio
n cache
[    0.000000] Machine: com335x
[    0.000000] Memory policy: ECC disabled, Data cache writeback
[    0.000000] AM335X ES2.1 (sgx neon )
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pag
es: 130048
consoleblank=0070TN94aitk0p2 rwne: console=ttyO0,115200n8
[    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Memory: 512MB = 512MB total
[    0.000000] Memory: 513604k/513604k available, 10684k reserved, 0K highmem
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     vmalloc : 0xe0800000 - 0xff000000   ( 488 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xe0000000   ( 512 MB)
[    0.000000]     modules : 0xbf000000 - 0xc0000000   (  16 MB)
[    0.000000]       .text : 0xc0008000 - 0xc0546000   (5368 kB)
[    0.000000]       .init : 0xc0546000 - 0xc057f000   ( 228 kB)
[    0.000000]       .data : 0xc0580000 - 0xc05d1a08   ( 327 kB)
[    0.000000]        .bss : 0xc05d1a2c - 0xc0600024   ( 186 kB)
[    0.000000] NR_IRQS:396
[    0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrup
ts
[    0.000000] Total of 128 interrupts on 1 active controller
[    0.000000] OMAP clockevent source: GPTIMER2 at 24000000 Hz
[    0.000000] OMAP clocksource: GPTIMER1 at 32768 Hz
[    0.000000] sched_clock: 32 bits at 32kHz, resolution 30517ns, wraps every 13
1071999ms
[    0.000000] Console: colour dummy device 80x30
[    0.000091] Calibrating delay loop... 795.44 BogoMIPS (lpj=3977216)
[    0.089050] pid_max: default: 32768 minimum: 301
[    0.089172] Security Framework initialized
[    0.089294] Mount-cache hash table entries: 512
[    0.089660] CPU: Testing write buffer coherency: ok
[    0.090332] devtmpfs: initialized
[    0.109741] omap_hwmod: pruss: failed to hardreset
[    0.110778] print_constraints: dummy:
[    0.111114] NET: Registered protocol family 16
[    0.113250] OMAP GPIO hardware version 0.1
[    0.115447] omap_mux_init: Add partition: #1: core, flags: 0
[    0.117553]  omap_i2c.1: alias fck already exists
[    0.117950]  omap_hsmmc.0: alias fck already exists
[    0.118194]  omap_hsmmc.1: alias fck already exists
[    0.119689]  omap_i2c.2: alias fck already exists
[    0.119873] com335x: mcasp1 init
[    0.119964]  davinci-mcasp.1: alias fck already exists
[    0.120391]  da8xx_lcdc.0: alias fck already exists
[    0.121063]  omap_i2c.3: alias fck already exists
[    0.121948]  edma.0: alias fck already exists
[    0.121978]  edma.0: alias fck already exists
[    0.139312] bio: create slab <bio-0> at 0
[    0.141265] SCSI subsystem initialized
[    0.141937] usbcore: registered new interface driver usbfs
[    0.142211] usbcore: registered new interface driver hub
[    0.142395] usbcore: registered new device driver usb
[    0.142730] registerd cppi-dma Intr @ IRQ 17
[    0.142730] Cppi41 Init Done Qmgr-base(e087a000) dma-base(e0878000)
[    0.142761] musb-ti81xx musb-ti81xx: musb0, board_mode=0x13, plat_mode=0x3
[    0.143066] musb-ti81xx musb-ti81xx: musb1, board_mode=0x13, plat_mode=0x1
[    0.144134] omap_i2c omap_i2c.1: bus 1 rev2.4.0 at 400 kHz
[    0.145019] pca953x 1-0074: interrupt support not compiled in
[    0.299896] tps65217 1-0024: TPS65217 ID 0xe version 1.2
[    0.300781] print_constraints: DCDC1: 900 <--> 1800 mV at 1500 mV
[    0.301696] print_constraints: DCDC2: 900 <--> 3300 mV at 1275 mV
[    0.302612] print_constraints: DCDC3: 900 <--> 1500 mV at 1125 mV
[    0.303497] print_constraints: LDO1: 1000 <--> 3300 mV at 1800 mV
[    0.304382] print_constraints: LDO2: 900 <--> 3300 mV at 3300 mV
[    0.305267] print_constraints: LDO3: 1800 <--> 3300 mV at 1800 mV
[    0.306182] print_constraints: LDO4: 1800 <--> 3300 mV at 3300 mV
[    0.306976] omap_i2c omap_i2c.2: bus 2 rev2.4.0 at 400 kHz
[    0.319061] omap_i2c omap_i2c.3: bus 3 rev2.4.0 at 400 kHz
[    0.320770] Advanced Linux Sound Architecture Driver Version 1.0.24.
[    0.321929] Switching to clocksource gp timer
[    0.338287] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
[    0.338470] musb-hdrc musb-hdrc.0: dma type: dma-cppi41
[    0.338806] MUSB0 controller's USBSS revision = 4ea20800
[    0.338836] musb0: Enabled SW babble control
[    0.339721] musb-hdrc musb-hdrc.0: USB OTG mode controller at e083c000 using
DMA, IRQ 18
[    0.339874] musb-hdrc musb-hdrc.1: dma type: dma-cppi41
[    0.340148] MUSB1 controller's USBSS revision = 4ea20800
[    0.340179] musb1: Enabled SW babble control
[    0.340576] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
[    0.340667] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus numbe
r 1
[    0.340789] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    0.340820] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=
[    0.340820] usb usb1: Product: MUSB HDRC host driver
[    0.340820] usb usb1: Manufacturer: Linux 3.2.0 musb-hcd
[    0.340850] usb usb1: SerialNumber: musb-hdrc.1
[    0.341705] hub 1-0:1.0: USB hub found
[    0.341735] hub 1-0:1.0: 1 port detected
[    0.342346] musb-hdrc musb-hdrc.1: USB Host mode controller at e083e800 using
DMA, IRQ 19
[    0.342773] NET: Registered protocol family 2
[    0.342956] IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
[    0.343261] TCP established hash table entries: 16384 (order: 5, 131072 bytes
[    0.343536] TCP bind hash table entries: 16384 (order: 4, 65536 bytes)
[    0.343688] TCP: Hash tables configured (established 16384 bind 16384)
[    0.343719] TCP reno registered
[    0.343719] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.343750] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.343933] NET: Registered protocol family 1
[    0.344177] RPC: Registered named UNIX socket transport module.
[    0.344177] RPC: Registered udp transport module.
[    0.344207] RPC: Registered tcp transport module.
[    0.344207] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.344421] NetWinder Floating Point Emulator V0.97 (double precision)
[    0.344421] Error: Driver 'omap-gpmc' is already registered, aborting...
[    0.364379] VFS: Disk quotas dquot_6.5.2
[    0.364471] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.365203] msgmni has been set to 1003
[    0.365905] io scheduler noop registered
[    0.365936] io scheduler deadline registered
[    0.365997] io scheduler cfq registered (default)
[    0.367431] da8xx_lcdc da8xx_lcdc.0: GLCD: Found AUO_AT070TN94 panel
[    0.378234] Console: switching to colour frame buffer device 100x30
[    0.384979] omap_uart.0: ttyO0 at MMIO 0x44e09000 (irq = 72) is a OMAP UART0
[    1.070617] console [ttyO0] enabled
[    1.074981] omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
[    1.082885] omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
[    1.090698] omap_uart.3: ttyO3 at MMIO 0x481a6000 (irq = 44) is a OMAP UART3
[    1.098541] omap_uart.4: ttyO4 at MMIO 0x481a8000 (irq = 45) is a OMAP UART4
[    1.106384] omap_uart.5: ttyO5 at MMIO 0x481aa000 (irq = 46) is a OMAP UART5
[    1.123840] brd: module loaded
[    1.131805] loop: module loaded
[    1.135894] at24 1-0050: 1024 byte 24c08 EEPROM, writable, 16 bytes/write
[    1.145874] CAN device driver interface
[    1.149902] CAN bus driver for Bosch D_CAN controller 1.0
[    1.202575] davinci_mdio davinci_mdio.0: davinci mdio revision 1.6
[    1.209045] davinci_mdio davinci_mdio.0: detected phy mask ffffffef
[    1.216552] davinci_mdio.0: probed
[    1.220092] davinci_mdio davinci_mdio.0: phy[4]: device 0:04, driver unknown
[    1.227691] PPP generic driver version 2.4.2
[    1.232635] PPP BSD Compression module registered
[    1.237579] PPP Deflate Compression module registered
[    1.243072] usbcore: registered new interface driver zd1201
[    1.249084] usbcore: registered new interface driver cdc_ether
[    1.255340] usbcore: registered new interface driver cdc_eem
[    1.261383] usbcore: registered new interface driver dm9601
[    1.267272] cdc_ncm: 04-Aug-2011
[    1.270874] usbcore: registered new interface driver cdc_ncm
[    1.276977] usbcore: registered new interface driver cdc_acm
[    1.282928] cdc_acm: USB Abstract Control Model driver for USB modems and ISD
N adapters
[    1.291290] Initializing USB Mass Storage driver...
[    1.296539] usb 1-1: new high-speed USB device number 2 using musb-hdrc
[    1.303741] usbcore: registered new interface driver usb-storage
[    1.310028] USB Mass Storage support registered.
[    1.315277] usbcore: registered new interface driver usbserial
[    1.321502] USB Serial support registered for generic
[    1.452758] usb 1-1: New USB device found, idVendor=0424, idProduct=2514
[    1.459777] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    1.468200] hub 1-1:1.0: USB hub found
[    1.472229] hub 1-1:1.0: 4 ports detected
[    1.477478] usbcore: registered new interface driver usbserial_generic
[    1.484344] usbserial: USB Serial Driver core
[    1.489044] USB Serial support registered for GSM modem (1-port)
[    1.495635] usbcore: registered new interface driver option
[    1.501464] option: v0.7.2:USB Driver for GSM modems
[    1.507232] mousedev: PS/2 mouse device common for all mice
[    1.514373] input: gpio-keys-polled as /devices/platform/gpio-keys-polled.0/i
nput/input0
[    1.524871] input: ti-tsc as /devices/platform/omap/ti_tscadc/tsc/input/input
[    1.533264] rtc-ds1307: probe of 1-0068 failed with error -5
[    1.539733] rtc-rx8025 3-0032: Unable to read registers #14..#15
[    1.546051] i2c i2c-3: probing for rx8025 failed
[    1.550903] rtc-rx8025: probe of 3-0032 failed with error -121
[    1.557159] i2c /dev entries driver
[    1.564361] cpuidle: using governor ladder
[    1.569091] cpuidle: using governor menu
[    1.579956] usbcore: registered new interface driver usbhid
[    1.585845] usbhid: USB HID core driver
[    1.590515] tiadc tiadc: attached adc driver
[    1.597534] _regulator_get: 1-001b supply IOVDD not found, using dummy regula
tor
[    1.605407] _regulator_get: 1-001b supply DVDD not found, using dummy regulat
or
[    1.613098] _regulator_get: 1-001b supply AVDD not found, using dummy regulat
or
[    1.620788] _regulator_get: 1-001b supply DRVDD not found, using dummy regula
tor
[    1.631195] asoc: tlv320aic3x-hifi <-> davinci-mcasp.1 mapping ok
[    1.645202] ALSA device list:
[    1.648345]   #0: COM335X EVM
[    1.651428] oprofile: hardware counters not available
[    1.656738] oprofile: using timer interrupt.
[    1.661224] nf_conntrack version 0.5.0 (8025 buckets, 32100 max)
[    1.668090] ip_tables: (C) 2000-2006 Netfilter Core Team
[    1.673797] TCP cubic registered
[    1.677185] NET: Registered protocol family 17
[    1.681823] can: controller area network core (rev 20090105 abi 8)
[    1.688415] NET: Registered protocol family 29
[    1.693084] can: raw protocol (rev 20090105)
[    1.697540] can: broadcast manager protocol (rev 20090105 t)
[    1.703491] Registering the dns_resolver key type
[    1.708496] VFP support v0.3: implementor 41 architecture 3 part 30 variant c
rev 3
[    1.716522] ThumbEE CPU extension supported.
[    1.721069] mux: Failed to setup hwmod io irq -22
[    1.726654] Power Management for AM33XX family
[    1.731292] pm: Err (-22) setting core voltage setting
[    1.736907] Trying to load am335x-pm-firmware.bin (60 secs timeout)
[    1.743591] Copied the M3 firmware to UMEM
[    1.747924] Cortex M3 Firmware Version = 0x184
[    1.755920] clock: disabling unused clocks to save power
[    1.763244] Detected MACID=88:33:14:ed:c7:42
[    1.769226] drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
[    1.776214] Waiting for root device /dev/mmcblk0p2...
[    1.838684] mmc1: new high speed MMC card at address 0001
[    1.845031] mmcblk0: mmc1:0001 SEM02G 1.82 GiB
[    1.849884] mmcblk0boot0: mmc1:0001 SEM02G partition 1 1.00 MiB
[    1.856231] mmcblk0boot1: mmc1:0001 SEM02G partition 2 1.00 MiB
[    1.868469]  mmcblk0: p1 p2
[    1.874847]  mmcblk0boot1: unknown partition table
[    1.882080]  mmcblk0boot0: unknown partition table
[    2.073883] EXT4-fs (mmcblk0p2): recovery complete
[    2.080627] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. O
pts: (null)
[    2.089202] VFS: Mounted root (ext4 filesystem) on device 179:2.
[    2.096435] devtmpfs: mounted
[    2.099914] Freeing init memory: 228K
[    2.226867] EXT4-fs (mmcblk0p2): re-mounted. Opts: user_xattr,barrier=1,data=
ordered
Starting logging: OK
Populating /dev using udev: [    2.439270] udevd[599]: starting version 182
done
Initializing random number generator... done.
Starting network...
[    3.217864] net eth0: CPSW phy found : id is : 0x4dd072
[    3.224151] PHY 0:01 not found
Starting sshd: OK
Starting vsftpd: OK
Welcome to EVB335X
EVB335X login: numid=28,iface=MIXER,name='HP DAC Playback Volume'
  ; type=INTEGER,access=rw---R--,values=2,min=0,max=118,step=0
  : values=50,50
  | dBscale-min=-59.00dB,step=0.50dB,mute=1
[    5.213562] PHY: 0:04 - Link is Up - 1000/Full
Welcome to EVB335X
EVB335X login: root
Password:
[root@EVB335X ~]# ?
双盈科技 发表于 2015-8-3 15:24 | 显示全部楼层
这个板不错,底版呢?我正在找这样的模块!
支持debian吗?支持debian开发更方便了.
个人签名:ARM工控开发板,10年定制开发经验 QQ:593404073 artcor.taobao.com info@embedall.com
45
