1.首先这运放的正输入端为什么要接一个50欧的电阻, 手册是这么说的: Notice that both inverting and noninverting inputs are connected to ground with a resistor (RS and RT). Matching the dc source impedance looking out of each input will minimize input offset voltage error.
说明这是阻抗匹配的
2. 电压孔数输入端接了一个Rc电阻到地,手册是这么说的:
A gain control voltage, VC, controls the amplifier gain magnitude through a high-speed control circuit. Gain polarity can be either inverting or noninverting, depending upon the amplifier input driven by the input signal. The gain control circuit presents the high-input impedance of a noninverting op amp connection. The control voltage pin is referred to ground as shown in Figure 29. The control voltage VC varies the amplifier gain according to the exponential relationship:
说明这是调节增益的, 下面还有个增益计算的公式.
这个器件的确有点怪, 建议楼主再仔细啃一啃手册吧
