程序:
- #include<REG2051.H>
- code senen_seg[10]={0x81,0xe7,0x92,0xa2,0xe4,0xa8,0x88,0xe3,0x80,0xa0};
- bit key1_enter=0,key2_enter=0,key3_enter=0,countdown_mark=0,stopwatch_mark=0,count_mark=0,bell_mark=0;
- unsigned char program=0,program_variable=0,count_bit=0,count=0;
- unsigned char hour=10,minute=10,second=0;
- unsigned char delayed_hour=22,delayed_minute=10,delayed_second=0;
- unsigned char count_hour=0,count_minute=0,count_second=0;
- unsigned int count_time=0,count_count=0;
- void delay(unsigned int t)
- unsigned int i,j;
- for(i=0;i<t;i++)
- for(j=0;j<10;j++)
- void time0_init(void){
- EA=0;
- TR0=0;
- TMOD=0x02;
- TH0=0x4;
- TL0=0x4;
- ET0=1;
- TR0=1;
- EA=1;
- static void timer0_isr(void) interrupt TF0_VECTOR using 1
- count_time++;
- if(count_time>=4020){
- count_time=0;
- second++;
- if(second>=60){
- second=0;
- minute++;
- if(minute>=60){
- minute=0;
- hour++;
- if(hour>=24)hour=0;
- if(delayed_hour==hour && delayed_minute==minute && second<4) P3_7=0;
- else P3_7=1;
- if(countdown_mark==1){
- count_count++;
- if(count_count>=4000 && (count_second!=0|count_minute!=0|count_hour!=0)){
- count_count=0;
- count_second--;
- if(count_second>=60){
- count_second=59;
- count_minute--;
- if(count_minute>=60){
- count_minute=59;
- count_hour--;
- if(count_hour>=100) count_hour=99;
- if(count_second==0&&count_minute==0&&count_hour==0&&count_count<=12000) P3_7=0;
- else P3_7=1;
- if(count_count>=15000) count_count=14000;
- if(stopwatch_mark==1){ count_count++;
- if(count_count>=40){
- count_count=0;
- count_second++;
- if(count_second>=100){
- count_second=0;
- count_minute++;
- count_minute=0;
- count_hour++;
- if(count_hour>=60) count_hour=0;
- unsigned char show_key (void){
- unsigned char x=0,y=0;
- switch (program){
- case 0: P1&=senen_seg[second%10];
- break;
- case 1: if(count_time>=2000) P1&=senen_seg[second%10];
- break;
- case 2: if(delayed_hour==24) P1=0xfe;
- else P1&=senen_seg[delayed_second%10];
- break;
- case 3: if(count_bit>=0) P1&=senen_seg[count_second%10];
- else P1=0xff;
- break;
- case 4: P1&=senen_seg[count_second%10];
- break;
- case 5: P1&=senen_seg[count_second%10];
- break;
- P3_3=0;
- delay(10);
- if(P3_5==0){
- key1_enter=1;
- if(count<=254)count++;
- if(P3_4==0) key2_enter=1;
- if(P3_2==0) key3_enter=1;
- P3_3=1;
- P1|=0xff;
- switch (program){
- case 0: P1&=senen_seg[second/10];
- break;
- case 1: if(count_time>=2000) P1&=senen_seg[second/10];
- break;
- else P1&=senen_seg[delayed_second/10];
- break;
- case 3: if(count_bit>=1) P1&=senen_seg[count_second/10];
- else P1=0xff;
- break;
- case 4: P1&=senen_seg[count_second/10];
- break;
- case 5: P1&=senen_seg[count_second/10];
- break;
- P3_1=0;
- delay(10);
- P3_1=1;
- P1|=0xff;
- switch (program){
- case 0: P1&=senen_seg[minute%10];
- break;
- case 1: if(count_time>=2000) P1&=senen_seg[minute%10];
- break;
- else P1&=senen_seg[delayed_minute%10];
- break;
- case 3: if(count_bit>=2) P1&=senen_seg[count_minute%10];
- else P1=0xff;
- break;
- case 4: P1&=senen_seg[count_minute%10];
- break;
- case 5: P1&=senen_seg[count_minute%10];
- break;
- P3_2=0;
- delay(10);
- P3_2=1;
- P1|=0xff;
- switch (program){
- case 0: P1&=senen_seg[minute/10];
- break;
- case 1: if(count_time>=2000) P1&=senen_seg[minute/10];
- break;
- else P1&=senen_seg[delayed_minute/10];
- break;
- case 3: if(count_bit>=3) P1&=senen_seg[count_minute/10];
- else P1=0xff;
- break;
- case 4: P1&=senen_seg[count_minute/10];
- break;
- case 5: P1&=senen_seg[count_minute/10];
- break;
- P3_5=0;
- delay(10);
- P3_5=1;
- P1|=0xff;
- switch (program){
- case 0: P1&=senen_seg[hour%10];
- break;
- case 1: if(count_time>=2000) P1&=senen_seg[hour%10];
- break;
- else P1&=senen_seg[delayed_hour%10];
- break;
- case 3: if(count_bit>=4) P1&=senen_seg[count_hour%10];
- else P1=0xff;
- break;
- case 4: P1&=senen_seg[count_hour%10]; break;
- case 5: P1&=senen_seg[count_hour%10];
- break;
- P3_0=0;
- delay(10);
- if(P3_4==1 && key2_enter==1){
- x=3; key2_enter=0;
- P3_0=1;
- P1|=0xff;
- switch (program){
- case 0: P1&=senen_seg[hour/10]; break;
- case 1: if(count_time>=2000) P1&=senen_seg[hour/10]; break;
- case 2: if(delayed_hour==24) P1=0xfe; else P1&=senen_seg[delayed_hour/10];
- break;
- case 3: if(count_bit>=5)P1&=senen_seg[count_hour/10]; else P1=0xff;
- break;
- case 4: P1&=senen_seg[count_hour/10];
- break;
- case 5: P1&=senen_seg[count_hour/10]; break;
- P3_4=0;
- delay(10);
- if(P3_5==1 && key1_enter==1){
- if(count>=127) x=1; else x=2; key1_enter=0;
- count=0;
- if(P3_2==1 && key3_enter==1){
- x=4;
- key3_enter=0;
- P3_4=1;
- P1|=0xff;
- if(program<=1 && count_time>=2000) P1&=0xff;
- if(program<=1 && count_time<=2000) P1&=0x7f;
- if(program==2) P1&=0x7f;
- if(program==3) P1&=0xff;
- if(program==4) P1&=0x7f;
- if(program==5) P1&=0xff;
- y=x;
- x=0;
- return y;
- void main(){
- P1=0xff;
- P3=0xff;
- time0_init();
- while(1){
- switch(program){
- case 0: while(program==0){
- switch(show_key()){
- case 0: break;
- case 1: program=0;
- break;
- case 2: program=1;
- break;
- break;
- case 1: while(program==1){
- case 0: break;
- break;
- case 2: program=2;
- break;
- case 3: hour++;
- break;
- case 4: minute++;
- if(minute>=60)minute=0;
- break;
- break;
- case 2: while(program==2){
- case 0: break;
- break;
- case 2: program=3;
- break;
- case 3: delayed_hour++;
- if(delayed_hour>=25)delayed_hour=0;
- break;
- case 4: delayed_minute++;
- if(delayed_minute>=60)delayed_minute=0;
- break;
- break;
- case 3: while(program==3){
- case 0: break;
- break;
- case 2: program=4;
- break;
- case 3: count_bit++;
- if(count_bit>=7)count_bit=0;
- break;
- case 4: switch(count_bit){
- case 0: count_second+=1;
- break;
- case 1: count_second+=10;
- break;
- case 2: count_minute+=1;
- break;
- case 3: count_minute+=10;
- break;
- case 4: count_hour+=1;
- break;
- case 5: count_hour+=10;
- break;
- case 6: break;
- if(count_hour>=100) count_hour-=100;
- if(count_minute>=60) count_minute-=60;
- if(count_second>=60) count_second-=60;
- break;
- if(count_bit==6) countdown_mark=1;
- else countdown_mark=0;
- break;
- case 4: count_hour=0;
- count_minute=0;
- count_second=0;
- while(program==4){
- case 0: break;
- break;
- case 2: program=5;
- break;
- case 3: stopwatch_mark=~stopwatch_mark;
- break;
- case 4: if(stopwatch_mark==0){
- count_hour=0;
- count_minute=0;
- count_second=0;
- break;
- break;
- case 5: count_hour=0;
- count_minute=0;
- count_second=0;
- while(program==5){
- case 0: break;
- break;
- case 2: program=0;
- break;
- case 3: count_second++;
- count_second=0;
- count_minute++;
- if(count_minute>=100){
- count_minute=0;
- count_hour++;
- if(count_hour>=100)count_hour=0;
- break;
- count_minute=0;
- count_second=0;
- break;
- if(P3_7==0){
- while(P3_7==0) show_key();
- count_second++;
- count_second=0;
- count_minute++;
- count_minute=0;
