- #include "SmartM_M0.h"
- //0 1 2 3 4 5 6 7 8 9
- const uint8_t TM1637_CODE[16]={0x3F, 0x06, 0x5B, 0x4F, 0x66, 0x6D, 0x7D, 0x07, 0x7F, 0x6F,
- //A B C D E F
- 0x77, 0X7F, 0x39, 0x3F, 0x79, 0x71};
- #define I2C_CLOCK 13
- VOID I2CInit(VOID)
- P3_PMD &= ~(Px4_PMD | Px5_PMD | Px2_PMD);
- P3_PMD |= (Px4_OD | Px5_OD | Px2_OUT); //使能I2C0引脚
- P3_MFP &= ~(P34_T0_I2CSDA | P35_T1_I2CSCL);
- P3_MFP |= (I2CSDA | I2CSCL); //选择P3.4,P3.5作为I2C0功能引脚
- APBCLK |= I2C0_CLKEN; //使能I2C0时钟
- I2CLK = I2C_CLOCK;
- I2CON |= ENSI; //使能I2C
- void TM1637_Write(UINT8 led)
- UINT8 i, ge, shi, bai, qian;
- I2CON |= STA; //启动
- /* 40H地址自动加1模式,44H固定地址模式,本程序采用自加1模式 */
- I2DAT = 0x40;
- I2CON &= (~AA); //发送ACK
- I2CON |= STO; //停止
- /*写起始地址命令(0C0H),地址从00H单元开始。*/
- I2DAT = 0xc0;
- /*写数据,显示4位数码管,地址自动加1*/
- for(i=0; i<4; i++)
- if(i==0) //第一位数码管
- ge = led%10;
- I2DAT = TM1637_CODE[ge];
- // I2CON |= SI;
- // while ((I2CON & SI) != SI);
- if(i==1) //第二位数码管
- shi = led%100/10;
- I2DAT = TM1637_CODE[shi];
- // I2CON |= SI;
- if(i==2) //第三位数码管
- bai = led%1000/100;
- I2DAT = TM1637_CODE[bai];
- // I2CON |= SI;
- if(i==3) //第四位数码管
- qian = led/1000;
- I2DAT = TM1637_CODE[qian];
- void TM1637_Read(u8 Rkey)
- UINT8 i;
- I2CON |= SI;
- while ((I2CON & SI) != SI);
- I2CON &= ((~STA)&(~SI));
- //写入读地址
- I2DAT = 0x42;
- I2CON |= SI;
- //读取数据
- I2CON |= AA;
- for(i=0; i<8; i++)
- I2CON |= SI;
- I2DAT = Rkey>>1;
- //发送NACK到TM1637,执行断开连接操作
- I2CON &= (~AA);
- I2CON |= SI;
- // I2CON |= SI;
- // while (I2CON & STO);
- // return TRUE;
- INT32 main(VOID)
- UINT8 i, dadt = 128, key;
- Un_Lock_Reg(); //ISP下载时保护FLASH存储器
- PWRCON |= OSC22M_EN; //默认时钟源为外部晶振
- while((CLKSTATUS & OSC22M_STB) == 0); //等待12MHz时钟稳定
- CLKSEL0 = (CLKSEL0 & (~HCLK)) | HCLK_22M; //设置外部晶振为系统时钟
- I2CInit();
- while(1)
- TM1637_Write(dadt); //执行写操作
- Delayms(500);
- TM1637_Read(key); //执行读操作
- if(key != 0xff)
- switch(key)
- case 0xf7:
- P2_DOUT &= 0X01;
- break;
- case 0xf6:
- if(dadt<255)
- dadt++;
- break;
- case 0xf5:
- if(dadt>0)
- dadt--;
- break;
- case 0xf4:
- P2_DOUT |= 0x01;
- break;
- default:
- break;
- Delayms(500);
