[Atmel] 用AtmelStudio6.2跑mega16例程(62)74C922扩展按键
 楼主| ddllxxrr 发表于 2014-12-1 19:49 | 显示全部楼层 |阅读模式
74C922为16按键,键盘扩展芯片。工作电压3-5V可直接跟单片机相连。
本例十分简单在按下键时,数码管显示哪个键子被按下。
Proteus仿真截图:
Atmel Studio6.2编译通过截图:
程序清单:
  1. /*
  2. * GccApplication25.c
  3. *
  4. * Created: 2014-12-1 19:10:48
  5. *  Author: Administrator
  6. */
  7. #define F_CPU 6000000UL
  8. #include <avr/io.h>
  9. #include <util/delay.h>
  10. #include <stdint.h>
  11. #define BEEP() PORTD ^= _BV(PD7)
  12. #define  Key_Pressed ((PINA&0x80) == 0x80)
  13. #define Key_NO (PINA&0x0F)
  14. const uint8_t SEG_CODE[] = {0x3F,0x06,0x5b,0x4F,0x66,0x6d,0x70,0x07,
  15. 0x7F,0x6F,0x77,0x7c,0x39,0x5E,0x79,0x71};
  16. void Sounder()
  17. {
  18.         uint8_t i;
  19.         for(i=0;i<100;i++)
  20.         {
  21.                 _delay_us(190); BEEP();
  22.         }
  23. }
  24. int main(void)
  25. {
  26.     DDRA = 0x00;PORTA = 0xFF;
  27.         DDRC = 0xFF;PORTC = 0x00;
  28.         DDRD = 0xFF;PORTD = 0xFF;
  29.
  30.
  31.         while(1)
  32.     {
  33.         //TODO:: Please write your application code
  34.                 if(Key_Pressed)
  35.                 {
  36.                      PORTC = SEG_CODE[Key_NO];
  37.                          Sounder();
  38.                 }
  39.     }
  40. }
2403
