买的板子,DSP的电路是我自己做的。程序是用C2000的例程和网上找的430的程序结合改的。然后就是我用的是自带的SPI,数据是8位写,它自带的SPI是16位,写数就得这么写。。程序比较乱,谢谢您了。
#include "DSP28x_Project.h" // Device Headerfile and Examples Include File
// Prototype statements for functions found within this file.
// interrupt void ISRTimer2(void);
void delay_loop(void);
void spi_xmit(Uint16 a);
void spi_fifo_init(void);
void spi_init(void);
void delay_loop1(long b);
void error(void);
void init_NRF24L01(void);
void nRF24L01_TxPacket();
Uint16 send_flag;
void transmit(Uint16*txbuf,Uint16 p);
void transmit2(Uint16 j,Uint16 k);
void transmit_r(Uint16 l);
void transmit_r32(Uint16*rx_buf);
void set_24l01();
Uint16 fla1;
Uint16 fla2;
Uint16 fla3;
Uint16 f1;
Uint16 f2;
Uint16 f3;
Uint16 flag1;
Uint16 flag2;
Uint16 sta;
Uint16 f;
Uint16 receive1;
Uint16 receive2;
Uint16 receive3;
Uint16 dump[4];
volatile struct SPIFFTX_BITS Spifftx;
volatile struct SPISTS_BITS SpistsaBits;
#define RF24L01_CE_0 GpioDataRegs.GPACLEAR.bit.GPIO12=1
#define RF24L01_CE_1 GpioDataRegs.GPASET.bit.GPIO12=1
#define TX_ADR_WIDTH 5 // 5 uints TX address width
#define RX_ADR_WIDTH 5 // 5 uints RX address width
#define TX_PLOAD_WIDTH 32 // 20 uints TX payload
#define RX_PLOAD_WIDTH 32 // 20 uints TX payload
char TxBuf[32];
char tx_buf[32];
Uint16 TEST1[6]={0x1000,0xf000,0xfa00,0xff00,0xa000,0xaa00};
Uint16 TEST2[12]={0x1000,0xf000,0xfa00,0xff00,0xa000,0xaa00,0x1000,0xf000,0xfa00,0xff00,0xa000,0xaa00};
Uint16 TEST3[18]=
{0x1000,0xf000,0xfa00,0xff00,0xa000,0xaa00,0x1000,0xf000,0xfa00,0xff00,0xa000,0xaa00,0x1000,0xf000,0xfa00,0xff00,0xa000,0xaa00};
Uint16 TEST4[24]=
{0x1000,0xf000,0xfa00,0xff00,0xa000,0xaa00,0x1000,0xf000,0xfa00,0xff00,0xa000,0xaa00,0x1000,0xf000,0xfa00,0xff00,0xa000,0xaa00,0x1000,0xf000
char TX_ADDRESS[TX_ADR_WIDTH]= {0x3400,0x4300,0x1000,0x1000,0x0100}; //本地地址
char RX_ADDRESS[RX_ADR_WIDTH]= {0x3400,0x4300,0x1000,0x1000,0x0100}; //接收地址
Uint16 TXADD[6]={0x3000,0x3400,0x4300,0x1000,0x1000,0x0100};
Uint16 RXADD[6]={0x2a00,0x3400,0x4300,0x1000,0x1000,0x0100};
Uint16 TXADD1[6]={0x2a00,0x3400,0x4300,0x1000,0x1000,0x0100};
Uint16 RXBUF[32];
Uint16 TEST[32]=
{0xaa00,0xf000,0xfa00,0xff00,0xa000,0xaa00,0x1000,0xf000,0xfa00,0xff00,0xa000,0xaa00,0x1000,0xf000,0xfa00,0xff00,0xa000,0xaa00,0x1000,0xf000
,0xfa00,0xff00,0xa000,0xaa00,0x1000,0xf000,0xfa00,0xff00,0xa000,0xaa00,0x1000,0xf000};
Uint16 TXADD2[33]=
{0xa000,0x1000,0xf000,0xfa00,0xff00,0xa000,0xaa00,0x1000,0xf000,0xfa00,0xff00,0xa000,0xaa00,0x1000,0xf000,0xfa00,0xff00,0xa000,0xaa00,0x1000
,0xf000,0xfa00,0xff00,0xa000,0xaa00,0x1000,0xf000,0xfa00,0xff00,0xa000,0xaa00,0x1000,0xf000};
Uint16 TXADD3[3]={0xa000,0x1000,0xff00};
//***************************************NRF24L01寄存器指令*******************************************************
#define READ_REG 0x0000 // 读寄存器指令
#define WRITE_REG 0x2000 // 写寄存器指令
#define RD_RX_PLOAD 0x6100 // 读取接收数据指令
#define WR_TX_PLOAD 0xA000 // 写待发数据指令
#define FLUSH_TX 0xE100 // 冲洗发送 FIFO指令
#define FLUSH_RX 0xE200 // 冲洗接收 FIFO指令
#define REUSE_TX_PL 0xE300 // 定义重复装载数据指令
#define NOP 0xFF00 // 保留
//*************************************SPI(nRF24L01)寄存器地址****************************************************
#define CONFIG 0x0000 // 配置收发状态,CRC校验模式以及收发状态响应方式
#define EN_AA 0x0100 // 自动应答功能设置
#define EN_RXADDR 0x0200 // 可用信道设置
#define SETUP_AW 0x0300 // 收发地址宽度设置
#define SETUP_RETR 0x0400 // 自动重发功能设置
#define RF_CH 0x0500 // 工作频率设置
#define RF_SETUP 0x0600 // 发射速率、功耗功能设置
#define STATUS 0x0700 // 状态寄存器
#define OBSERVE_TX 0x0800 // 发送监测功能
#define CD 0x0900 // 地址检测
#define RX_ADDR_P0 0x0A00 // 频道0接收数据地址
#define RX_ADDR_P1 0x0B00 // 频道1接收数据地址
#define RX_ADDR_P2 0x0C00 // 频道2接收数据地址
#define RX_ADDR_P3 0x0D00 // 频道3接收数据地址
#define RX_ADDR_P4 0x0E00 // 频道4接收数据地址
#define RX_ADDR_P5 0x0F00 // 频道5接收数据地址
#define TX_ADDR 0x1000 // 发送地址寄存器
#define RX_PW_P0 0x1100 // 接收频道0接收数据长度
#define RX_PW_P1 0x1200 // 接收频道0接收数据长度
#define RX_PW_P2 0x1300 // 接收频道0接收数据长度
#define RX_PW_P3 0x1400 // 接收频道0接收数据长度
#define RX_PW_P4 0x1500 // 接收频道0接收数据长度
#define RX_PW_P5 0x1600 // 接收频道0接收数据长度
#define FIFO_STATUS 0x1700 // FIFO栈入栈出状态寄存器设置
void main(void)
// Step 1. Initialize System Control:
// PLL, WatchDog, enable Peripheral Clocks
// This example function is found in the DSP2802x_SysCtrl.c file.
InitSysCtrl();
// Step 2. Initalize GPIO:
// This example function is found in the DSP2802x_Gpio.c file and
// illustrates how to set the GPIO to it's default state.
// InitGpio(); // Skipped for this example
// Setup only the GP I/O only for SPI-A functionality
// This function is found in DSP2802x_Spi.c
InitSpiaGpio();
// Step 3. Clear all interrupts and initialize PIE vector table:
// Disable CPU interrupts
DINT;
// Initialize PIE control registers to their default state.
// The default state is all PIE interrupts disabled and flags
// are cleared.
// This function is found in the DSP2802x_PieCtrl.c file.
InitPieCtrl();
// Disable CPU interrupts and clear all CPU interrupt flags:
IER = 0x0000;
IFR = 0x0000;
// Initialize the PIE vector table with pointers to the shell Interrupt
// Service Routines (ISR).
// This will populate the entire table, even if the interrupt
// is not used in this example. This is useful for debug purposes.
// The shell ISR routines are found in DSP2802x_DefaultIsr.c.
// This function is found in DSP2802x_PieVect.c.
InitPieVectTable();
// Step 4. Initialize all the Device Peripherals:
// This function is found in DSP2802x_InitPeripherals.c
// InitPeripherals(); // Not required for this example
spi_fifo_init(); // Initialize the Spi FIFO
spi_init(); // init SPI
EALLOW;
SpiaRegs.SPICTL.bit.TALK=1;
EDIS;
EALLOW;
GpioCtrlRegs.GPAMUX1.bit.GPIO12=0;
GpioCtrlRegs.GPADIR.bit.GPIO12=1;
EDIS;
// Step 5. User specific code:
// Interrupts are not used in this example.
set_24l01();
for (;;)
transmit2(WRITE_REG+STATUS,0XFF00);
transmit_r(STATUS);
f2=receive2;
transmit_r(STATUS);
send_flag=receive2&0x0020;
delay_loop1(2000);
// Step 7. Insert all local Interrupt Service Routines (ISRs) and functions here:
long i;
for (i = 0; i < b; i++) {}
void delay_loop()
long i;
for (i = 0; i < 1000000; i++) {}
void error(void)
asm(" ESTOP0"); // Test failed!! Stop!
for (;;);
void spi_init()
SpiaRegs.SPICCR.all =0x0007; // Reset on, rising edge, 16-bit char bits
SpiaRegs.SPICTL.all =0x000E; // Enable master mode, normal phase,
// enable talk, and SPI int disabled.
SpiaRegs.SPIBRR =0x001F;
SpiaRegs.SPICCR.all =0x0087; // Relinquish SPI from Reset
SpiaRegs.SPIPRI.bit.FREE = 1; // Set so breakpoints don't disturb xmission
SpiaRegs.SPITXBUF=a;
void spi_fifo_init()
// Initialize SPI FIFO registers
SpiaRegs.SPIFFTX.all=0xE040;
SpiaRegs.SPIFFRX.all=0x2044;
SpiaRegs.SPIFFCT.all=0x0;
// No more.
RF24L01_CE_0 ;
delay_loop1(2000);
transmit(TXADD,6);// 写本地地址
transmit(RXADD,6); // 写接收端地址
transmit2(WRITE_REG + EN_AA,0x0000);// 频道0自动 ACK应答允许
transmit2(WRITE_REG + EN_RXADDR,0x0100); // 允许接收地址只有频道0,如果需要多频道可以参考Page21
transmit2(WRITE_REG + RF_CH,0);// 设置信道工作为2.4GHZ,收发必须一致
transmit2(WRITE_REG + RX_PW_P0,0x0200); //设置接收数据长度,本次设置为32字节
transmit2(WRITE_REG + SETUP_RETR,0x0000);
transmit2(WRITE_REG + RF_SETUP,0x0700); //设置发射速率为1MHZ,发射功率为最大值0dB
transmit2(WRITE_REG + CONFIG,0x0E00);// IRQ收发完成中断响应,16位CRC ,主接收}
void nRF24L01_TxPacket(void)
RF24L01_CE_0 ;
transmit(TXADD1,6);// 装载接收地址
transmit(TXADD2,33); // 装载数据
transmit2(WRITE_REG + CONFIG,0x3E00);//IRQ收发完成中断响应,16位CRC ,发送
transmit_r(STATUS);
fla1=receive2;
RF24L01_CE_1;
delay_loop1(60);
RF24L01_CE_0 ;
transmit_r(STATUS);
fla3=receive2;
f=0;
for (f = 0; f < p; f++)
spi_xmit(txbuf[f]);
for (;;)
flag2=SpiaRegs.SPIFFTX.bit.TXFFST;
if(flag2==0)
flag2=1;
break;
delay_loop1(2000);
spi_xmit(j);
spi_xmit(k);
for (;;)
if(flag2==0)
flag2=1;
break;
delay_loop1(2000);
Uint16 i;
for (i=0;i<4;i++)
flag1=SpiaRegs.SPIFFRX.bit.RXFFST;
if(flag1!=0)
dump[i]=SpiaRegs.SPIRXBUF;
else
break;
spi_xmit(l);
spi_xmit(0xff00);
for (;;)
if(flag2==0)
flag2=1;
break;
while(SpiaRegs.SPIFFRX.bit.RXFFST !=2) { }
receive1=SpiaRegs.SPIRXBUF;
receive2=SpiaRegs.SPIRXBUF;
//receive3=SpiaRegs.SPIRXBUF;
delay_loop1(2000);
void SetRX_Mode(void)
RF24L01_CE_0;
transmit2(WRITE_REG + CONFIG, 0x0f); // IRQ收发完成中断响应,16位CRC,主接收
RF24L01_CE_1;
delay_loop1(2000); //注意不能太小
//函数:unsigned char nRF24L01_RxPacket(unsigned char* rx_buf)
//功能:数据读取后放如rx_buf接收缓冲区中
void nRF24L01_RxPacket()
RX_flag=0;
transmit_r(STATUS); // 读取状态寄存其来判断数据接收状况
sta=receive2;
if(sta&0x4000) // 判断是否接收到数据
RF24L01_CE_0 ; //SPI使能
// SPI_Read_Buf(RD_RX_PLOAD,rx_buf,TX_PLOAD_WIDTH); // read receive payload from RX_FIFO buffer
spi_xmit(RD_RX_PLOAD);
transmit_r32(RXBUF);
RX_flag =1; //读取数据完成标志
transmit2(WRITE_REG+STATUS,sta); //接收到数据后RX_DR,TX_DS,MAX_PT都置高为1,通过写1来清楚中断标志
Uint16 i,j;
for (i=0;i<4;i++)
if(flag1!=0)
else
break;
for (j=0;j<32;j++)
spi_xmit(0xff00);
for(;;)
flag1=SpiaRegs.SPIFFTX.all;
flag2=flag1&0x1F;
if(flag2==0)
flag2=1;
break;
while(SpiaRegs.SPIFFRX.bit.RXFFST !=1) { }
rx_buf[i]=SpiaRegs.SPIRXBUF;
delay_loop1(2000);
void LEDSET()
EALLOW;
GpioCtrlRegs.GPAMUX1.bit.GPIO5=0;
GpioCtrlRegs.GPBMUX1.bit.GPIO34=0;
GpioCtrlRegs.GPADIR.bit.GPIO5=1;
GpioCtrlRegs.GPBDIR.bit.GPIO34=1;
EDIS;
void LED_blink()
GpioDataRegs.GPASET.bit.GPIO5=1;
GpioDataRegs.GPBSET.bit.GPIO34=1;
delay_loop1(200000);
GpioDataRegs.GPACLEAR.bit.GPIO5=1;
GpioDataRegs.GPBCLEAR.bit.GPIO34=1;
void set_24l01()
RF24L01_CE_0 ;
delay_loop1(2000);
transmit2(WRITE_REG + SETUP_AW,0x0300);
transmit2(WRITE_REG + RX_PW_P0,0x2000); //设置接收数据长度,本次设置为32字节
transmit2(WRITE_REG + RX_PW_P1,0x0000);
transmit2(WRITE_REG + RX_PW_P2,0x0000);
transmit2(WRITE_REG + RX_PW_P3,0x0000);
transmit2(WRITE_REG + RX_PW_P4,0x0000);
transmit2(WRITE_REG + RX_PW_P5,0x0000);
