ST的工程师和一些客户使用评估版调试STM32时都遇到下面这个问题。<br />我找到KEIL网站的相关问题:<br />http://www.keil.com/support/man/docs/license/license_errors.htm<br />还有是否和评估版的限制有关系:<br />The restrictions for the MDK-ARM Evaluation Version are:<br />The image ROM size of the generated application is limited to 16KB maximum.<br />The linker does not accept scatter-loading description files for sophisticated memory layouts.<br />The base address for code/constants is restricted to 0xXX000000, 0xXX800000, or 0x00080000 whereby XX stands for 00, 01, ..., FF. This allows memory start address like 0x00000000, 0x12800000 and so on.<br />It is not possible to generate position independent code or data.<br />The compiler does not generate a listing file.<br />The linker generates an output file that can only be loaded with the μVision Debugger. Only the full version of MDK-ARM generates a standard ELF/DWARF image as output file.<br />You cannot use the Evaluation Version to create commercial products.<br /> |
