请求帮助
 楼主| armfan 发表于 2008-1-28 16:22 | 显示全部楼层 |阅读模式
Error&nbsp;&nbsp;&nbsp;:&nbsp;A1150E:&nbsp;Bad&nbsp;symbol<br />start.s&nbsp;line&nbsp;635&nbsp;&nbsp;&nbsp;<br /><br />&nbsp;&nbsp;635&nbsp;00000000&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;^&nbsp;&nbsp;&nbsp;_ISR_STARTADDRESS<br /><br />1&nbsp;Error,&nbsp;0&nbsp;Warnins<br />&nbsp;&nbsp;<br />&nbsp;&nbsp;这是什么错误?
ruiwei0201 发表于 2008-1-28 17:39 | 显示全部楼层
这个看下吧
A1150E:&nbsp;Bad&nbsp;symbol<br />This&nbsp;typically&nbsp;occurs&nbsp;in&nbsp;two&nbsp;cases:<br />1)&nbsp;when&nbsp;the&nbsp;current&nbsp;file&nbsp;requires&nbsp;another&nbsp;file&nbsp;to&nbsp;be&nbsp;INCLUDEed&nbsp;to&nbsp;define&nbsp;some&nbsp;symbols,&nbsp;for&nbsp;example:<br />&quot;init.s&quot;,&nbsp;line&nbsp;2:&nbsp;Error:&nbsp;A1150E:&nbsp;Bad&nbsp;symbol<br />2&nbsp;00000000&nbsp;DCD&nbsp;EBI_CSR_0<br />typically&nbsp;requires&nbsp;a&nbsp;definitions&nbsp;file&nbsp;to&nbsp;be&nbsp;included,&nbsp;e.g:<br />INCLUDE&nbsp;targets/eb40.inc<br />2)&nbsp;when&nbsp;the&nbsp;current&nbsp;file&nbsp;requires&nbsp;some&nbsp;symbols&nbsp;to&nbsp;be&nbsp;IMPORTed,&nbsp;for&nbsp;example:<br />&quot;init.s&quot;,&nbsp;line&nbsp;4:&nbsp;Error:&nbsp;A1150E:&nbsp;Bad&nbsp;symbol<br />4&nbsp;00000000&nbsp;LDR&nbsp;r0,&nbsp;=||Image$$RAM$$ZI$$Limit||<br />typically&nbsp;requires&nbsp;the&nbsp;symbol&nbsp;to&nbsp;be&nbsp;imported,&nbsp;e.g:<br />IMPORT&nbsp;||Image$$RAM$$ZI$$Limit||
 楼主| armfan 发表于 2008-1-28 18:30 | 显示全部楼层
谢谢
谢谢你。你从哪里多到的这些东西。我刚刚使用ADS对此还不熟悉,请告知
ruiwei0201 发表于 2008-1-29 10:12 | 显示全部楼层
下载
你到网上按错误号码搜索就有一个ads1.2相关错误信息的pdf文档.要不你可以把邮箱给我,我可以给你发一个.
 楼主| armfan 发表于 2008-1-29 10:26 | 显示全部楼层
xiexie
谢谢,我的邮箱是npuazm@126.com<br /><br />非常感谢,太热心了。
ruiwei0201 发表于 2008-1-29 10:38 | 显示全部楼层
不用谢
邮件已发,去你邮箱里看吧.
zjutjsj1004 发表于 2013-3-17 12:49 | 显示全部楼层
刚刚遇到这个问题
