* @file DEV_L3G4200D.h
* @version 0.1[LUDSMARTCAR]
* @date 2013-11-9
* @brief L3G4200三轴陀螺仪设备驱动程序
#ifndef __DEV_L3G4200D_H__
#define __DEV_L3G4200D_H__
#include "common.h"
#include "HW_I2C.h"
/********用户可修改值 开始***********/
//连接L3G4200用到的I2C通道
#define L3G4200_I2CX (I2C1)
//连接L3G4200用到的SCL引脚
#define L3G4200_SCLPIN (PTC10)
//连接L3G4200用到的SDA引脚
#define L3G4200_SDAPIN (PTC11)
/********用户可修改值 结束***********/
//定义SCL Bus Speed取值,外设总线为50Mhz时的计算结果
#define L3G4200_SCL_50KHZ (0x33)
#define L3G4200_SCL_100KHZ (0x2B)
#define L3G4200_SCL_150KHZ (0x28)
#define L3G4200_SCL_200KHZ (0x23)
#define L3G4200_SCL_250KHZ (0x21)
#define L3G4200_SCL_300KHZ (0x20)
#define L3G4200_SCL_400KHZ (0x17)
//=========MMA8451 功能参数==================//
#define L3G4200_DEV_ADDR 0x69//0X68//0x69 //定义器件地址,可根据硬件修改
#define L3G4200_DEV_WRITE 0xD2//0XD0//0xD2
#define L3G4200_DEV_READ 0XD3//0XD1//0xD3
#define L3G4200_DEV_ID 0xD3 //设备ID
//L3G4200 内部寄存器地址
#define WHO_AM_I 0x0F
#define CTRL_REG1 0x20
#define CTRL_REG2 0x21
#define CTRL_REG3 0x22
#define CTRL_REG4 0x23
#define CTRL_REG5 0x24
#define REFERENCE 0x25
#define OUT_TEMP 0x26
#define STATUS_REG 0x27
#define OUT_X_L 0x28
#define OUT_X_H 0x29
#define OUT_Y_L 0x2A
#define OUT_Y_H 0x2B
#define OUT_Z_L 0x2C
#define OUT_Z_H 0x2D
//=========L3G4200 STATUS寄存器 寄存器位==================//
#define L3G4200_STATUS_X_READY 0x01
#define L3G4200_STATUS_Y_READY 0x02
#define L3G4200_STATUS_Z_READY 0x04
#define L3G4200_STATUS_XYZ_READY 0x08
#define L3G4200_STATUS_X_OW 0x10
#define ML3G4200_STATUS_Y_OW 0x20
#define L3G4200_STATUS_Z_OW 0x40
#define L3G4200_STATUS_XYZ_OW 0x80
//函数声明
uint8 L3G4200_Init(void);
void L3G4200_WriteReg(uint8, uint8);
uint8 L3G4200_ReadReg(uint8);
int16 L3G4200_GetResult(uint8, uint8);
#endif
* @date 2013-11-9
#include "DEV_L3G4200D.h"
static void L3G4200_Delay(void);
I2C_InitTypeDef i2c_init_param;
uint8 device_id=0;
//初始化L3G4200_I2CX
i2c_init_param.I2C_I2Cx = L3G4200_I2CX ; //在DEV_L3G4200.h中修改该值
i2c_init_param.I2C_IntEnable = FALSE;
i2c_init_param.I2C_ICR = L3G4200_SCL_200KHZ; //可根据实际电路更改SCL频率
i2c_init_param.I2C_SclPin = L3G4200_SCLPIN; //在DEV_MMA8451.h中修改该值
i2c_init_param.I2C_SdaPin = L3G4200_SDAPIN; //在DEV_MMA8451.h中修改该值
i2c_init_param.I2C_OpenDrainEnable=TRUE;
i2c_init_param.I2C_Isr = NULL;
LPLD_I2C_Init(i2c_init_param);
//读取设备ID
device_id = L3G4200_ReadReg(WHO_AM_I);
//进行寄存器配置
L3G4200_WriteReg(CTRL_REG1, 0x0f); //100hz 0xff(800hz)
L3G4200_WriteReg(CTRL_REG2, 0x00);
L3G4200_WriteReg(CTRL_REG3, 0x08);
L3G4200_WriteReg(CTRL_REG4, 0x30); //+-2000dps , Data LSB @ lower address
L3G4200_WriteReg(CTRL_REG5, 0x00);
return device_id ;
* L3G4200_WriteReg
* 该函数用于配置L3G4200的寄存器
* 参数:
* RegisterAddress
* |__ L3G4200寄存器地址
* Data
* |__ 具体写入的字节型数据
void L3G4200_WriteReg(uint8 RegisterAddress, uint8 Data)
//发送从机地址
LPLD_I2C_StartTrans(L3G4200_I2CX,L3G4200_DEV_ADDR, I2C_MWSR);
LPLD_I2C_WaitAck(L3G4200_I2CX, I2C_ACK_ON);
//写L3G4200寄存器地址
LPLD_I2C_WriteByte(L3G4200_I2CX, RegisterAddress);
//向寄存器中写具体数据
LPLD_I2C_WriteByte(L3G4200_I2CX, Data);
LPLD_I2C_Stop(L3G4200_I2CX);
L3G4200_Delay();
* L3G4200_ReadReg
* 该函数用于读取L3G4200的数据
* 参数:
* RegisterAddress
* |__ MMA8451寄存器地址
* 返回值
* 加速传感器的测量值
uint8 L3G4200_ReadReg(uint8 RegisterAddress)
uint8 result=0;
//发送从机地址
//写L3G4200_I2CX寄存器地址
//再次产生开始信号
LPLD_I2C_ReStart(L3G4200_I2CX);
//发送从机地址和读取位
LPLD_I2C_WriteByte(L3G4200_I2CX , L3G4200_DEV_READ);
//转换主机模式为读
LPLD_I2C_SetMasterWR(L3G4200_I2CX, I2C_MRSW);
//关闭应答ACK
LPLD_I2C_WaitAck(L3G4200_I2CX, I2C_ACK_OFF);//关闭ACK
// Dummy read 虚假读取
result =LPLD_I2C_ReadByte(L3G4200_I2CX);
//发送停止信号
//读IIC数据
result = LPLD_I2C_ReadByte(L3G4200_I2CX);
L3G4200_Delay();
L3G4200_Delay();
L3G4200_Delay();
return result;
* 函数功能:读L3G4200加速度输出
* 参数
* Status - 数据寄存器状态
* Regs_Addr - 数据寄存器地址
* 函数返回值:加速度值(int16)
int16 L3G4200_GetResult(uint8 Status, uint8 Regs_Addr)
uint8 ret=0;
uint16 cnt=0;
int16 result,temp;
// 等待转换完成并取出值
while(!(ret&Status))
ret = L3G4200_ReadReg( STATUS_REG);
if(++cnt>500)
// break;
temp= L3G4200_ReadReg( Regs_Addr); //低字节数据
result = L3G4200_ReadReg( Regs_Addr+1); //高字节
result=result<<8;
result=result|temp;
return result;
* 延时函数
static void L3G4200_Delay(void){
int n;
for(n=1;n<200;n++) {
asm("nop");
* --------------基于"拉普兰德K60底层库V3"的工程(L3G4200D)-----------------
* @file L3G4200D.c
* @version 0.0
* @date 2013-9-29
* @brief 关于该工程的描述
* 版权所有:北京拉普兰德电子技术有限公司
* http://www.lpld.cn
* mail:support@lpld.cn
* 硬件平台: LPLD K60 Card / LPLD K60 Nano
* 本工程基于"拉普兰德K60底层库V3"开发,
* 所有开源代码均在"lib"文件夹下,用户不必更改该目录下代码,
* 所有用户工程需保存在"project"文件夹下,以工程名定义文件夹名,
* 底层库使用方法见相关文档。
#include "common.h"
int16 resultx,resulty,resultz;
uint8 device_id ;
void delay(void) ;
void main (void)
//初始化L3G4200D底层驱动及寄存器
device_id=L3G4200_Init();
if(device_id==L3G4200_DEV_ID)
printf("L3G4200D init succeed!\r\n");
printf("Device ID :0x%X\r\n,device_id") ;
else
printf("L3G4200D Init failed !\r\n");
printf("Device ID :0x%x\r\n,device_id");
while(1);
while(1)
resultx=L3G4200_GetResult(L3G4200_STATUS_X_READY,OUT_X_L);
resulty=L3G4200_GetResult(L3G4200_STATUS_Y_READY,OUT_Y_L) ;
resultz=L3G4200_GetResult(L3G4200_STATUS_Z_READY,OUT_Z_L);
printf("XYZ:\t%d\t%d\t%d\r\n", resultx, resulty, resultz);
void delay(void)
int16 i,n;
for (i=0;i<30000;i++)
for (n=0;n<200;n++)
asm("nop");
能给测试一下L3G4200D吗?我这里使用你的代码还是读不出ID 啊。新来的传感器。,。帮忙测一下,代码能否读取ID 吧,顺便给来张截图
