[工具和软件] K60 + L3G4200 LPLD的库
3753|20
 楼主| fhguo1990 发表于 2015-4-23 21:04 | 显示全部楼层 |阅读模式
  • #ifndef __DEV_L3G4200_H__
  • #define __DEV_L3G4200_H__
  • #include "common.h"
  • #include "HW_I2C.h"
  • /********用户可修改值 开始***********/
  • //连接L3G4200用到的I2C通道
  • #define L3G4200_I2CX    (I2C1)
  • //连接L3G4200用到的SCL引脚
  • #define L3G4200_SCLPIN  (PTC10)
  • //连接L3G4200用到的SDA引脚
  • #define L3G4200_SDAPIN  (PTC11)
  • /********用户可修改值 结束***********/
  • //定义SCL Bus Speed取值,外设总线为50Mhz时的计算结果
  • #define L3G4200_SCL_50KHZ                   (0x33)
  • #define L3G4200_SCL_100KHZ                  (0x2B)
  • #define L3G4200_SCL_150KHZ                  (0x28)
  • #define L3G4200_SCL_200KHZ                  (0x23)
  • #define L3G4200_SCL_250KHZ                  (0x21)
  • #define L3G4200_SCL_300KHZ                  (0x20)
  • #define L3G4200_SCL_400KHZ                  (0x17)
  • //=========MMA8451 功能参数==================//
  • #define L3G4200_DEV_ADDR     0x69         //定义器件地址,可根据硬件修改
  • #define L3G4200_DEV_WRITE    0xD2
  • #define L3G4200_DEV_READ     0xD3
  • #define L3G4200_DEV_ID       0xD3     //设备ID
  • //L3G4200 内部寄存器地址
  • #define WHO_AM_I               0x0F
  • #define CTRL_REG1              0x20
  • #define CTRL_REG2         0x21
  • #define CTRL_REG3         0x22
  • #define CTRL_REG4         0x23
  • #define CTRL_REG5         0x24
  • #define REFERENCE         0x25
  • #define OUT_TEMP          0x26
  • #define STATUS_REG         0x27
  • #define OUT_X_L         0x28
  • #define OUT_X_H         0x29
  • #define OUT_Y_L         0x2A
  • #define OUT_Y_H         0x2B
  • #define OUT_Z_L         0x2C
  • #define OUT_Z_H         0x2D
  • //=========L3G4200 STATUS寄存器 寄存器位==================//
  • #define L3G4200_STATUS_X_READY   0x01
  • #define L3G4200_STATUS_Y_READY   0x02
  • #define L3G4200_STATUS_Z_READY   0x04
  • #define L3G4200_STATUS_XYZ_READY 0x08
  • #define L3G4200_STATUS_X_OW      0x10
  • #define ML3G4200_STATUS_Y_OW     0x20
  • #define L3G4200_STATUS_Z_OW      0x40
  • #define L3G4200_STATUS_XYZ_OW    0x80
  • //函数声明
  • uint8  L3G4200_Init(void);
  • void  L3G4200_WriteReg(uint8, uint8);
  • uint8 L3G4200_ReadReg(uint8);
  • int16 L3G4200_GetResult(uint8, uint8);
  • #endif
  • #include "dev_l3g4200.h"
  • static void L3G4200_Delay(void);
  •   I2C_InitTypeDef i2c_init_param;
  •   uint8 device_id=0;
  •   //初始化L3G4200_I2CX
  •   i2c_init_param.I2C_I2Cx = L3G4200_I2CX ;       //在DEV_L3G4200.h中修改该值
  •   i2c_init_param.I2C_IntEnable = FALSE;
  •   i2c_init_param.I2C_ICR = L3G4200_SCL_200KHZ;  //可根据实际电路更改SCL频率
  •   i2c_init_param.I2C_SclPin = L3G4200_SCLPIN;   //在DEV_MMA8451.h中修改该值
  •   i2c_init_param.I2C_SdaPin = L3G4200_SDAPIN;   //在DEV_MMA8451.h中修改该值
  •   i2c_init_param.I2C_Isr = NULL;
  •   LPLD_I2C_Init(i2c_init_param);
  •     //读取设备ID
  •   device_id = L3G4200_ReadReg(WHO_AM_I);
  •   //进行寄存器配置
  •   L3G4200_WriteReg(CTRL_REG1, 0x0f);   //100hz    0xff(800hz)
  •   L3G4200_WriteReg(CTRL_REG2, 0x00);
  •   L3G4200_WriteReg(CTRL_REG3, 0x08);
  •   L3G4200_WriteReg(CTRL_REG4, 0x30);  //+-2000dps , Data LSB @ lower address
  •   L3G4200_WriteReg(CTRL_REG5, 0x00);
  •   return device_id ;
  • *   L3G4200_WriteReg
  • *   该函数用于配置L3G4200的寄存器
  • *   参数:
  • *   RegisterAddress
  • *    |__ L3G4200寄存器地址
  • *   Data
  • *    |__ 具体写入的字节型数据
  • void  L3G4200_WriteReg(uint8 RegisterAddress, uint8 Data)
  •    //发送从机地址
  •   LPLD_I2C_StartTrans(L3G4200_I2CX,L3G4200_DEV_ADDR, I2C_MWSR);
  •   LPLD_I2C_WaitAck(L3G4200_I2CX, I2C_ACK_ON);
  •   //写L3G4200寄存器地址
  •   LPLD_I2C_WriteByte(L3G4200_I2CX, RegisterAddress);
  •   //向寄存器中写具体数据
  •   LPLD_I2C_WriteByte(L3G4200_I2CX, Data);
  •   LPLD_I2C_Stop(L3G4200_I2CX);
  •   L3G4200_Delay();
  • *   L3G4200_ReadReg
  • *   该函数用于读取L3G4200的数据
  • *   参数:
  • *     RegisterAddress
  • *        |__ MMA8451寄存器地址
  • *   返回值
  • *      加速传感器的测量值
  • uint8 L3G4200_ReadReg(uint8 RegisterAddress)
  •   uint8 result=0;
  •   //发送从机地址
  •   //写L3G4200_I2CX寄存器地址
  •   //再次产生开始信号
  •   LPLD_I2C_ReStart(L3G4200_I2CX);
  •   //发送从机地址和读取位
  •   LPLD_I2C_WriteByte(L3G4200_I2CX , L3G4200_DEV_READ);
  •   //转换主机模式为读
  •   LPLD_I2C_SetMasterWR(L3G4200_I2CX, I2C_MRSW);
  •   //关闭应答ACK
  •   LPLD_I2C_WaitAck(L3G4200_I2CX, I2C_ACK_OFF);//关闭ACK
  •   // Dummy read 虚假读取
  •   result =LPLD_I2C_ReadByte(L3G4200_I2CX);
  •   //发送停止信号
  •   //读IIC数据
  •   result = LPLD_I2C_ReadByte(L3G4200_I2CX);
  •   L3G4200_Delay();
  •   return result;
  • * 函数功能:读L3G4200加速度输出
  • * 参数
  • *       Status - 数据寄存器状态
  • *       Regs_Addr - 数据寄存器地址
  • * 函数返回值:加速度值(int16)
  • int16 L3G4200_GetResult(uint8 Status, uint8 Regs_Addr)
  •   uint8 ret=0;
  •   uint16 cnt=0;
  •   int16 result,temp;
  •   // 等待转换完成并取出值
  •   while(!(ret&Status))
  •     ret = L3G4200_ReadReg( STATUS_REG);
  •     if(++cnt>500)
  •     //  break;
  •   temp= L3G4200_ReadReg( Regs_Addr);        //低字节数据
  •   result  = L3G4200_ReadReg( Regs_Addr+1);  //高字节
  •   result=result<<8;
  •   result=result|temp;
  •   return result;
  • * 延时函数
  • static void L3G4200_Delay(void){
  •   int n;
  •   for(n=1;n<200;n++) {
  •     asm("nop");
求救啊,为嘛我读出来的数据,全是0xFF ,
器件地址应该是对啊,LPLD 底层库有进行移位操作啊,器件也是好的
CS 和SA 都接的高
为嘛我读MMA8451可以读出来,读L3G4200 就读不出来
我是MT 发表于 2015-4-23 21:05 | 显示全部楼层
你可以参考一下L3G4200 的相关应用,检查一下不代码和这款芯片对应应用的区别。
看到其他地方一个建议操作,不过那边后来也没有回应,你可以试试看其他网友的建议操作。
“请将SDA管脚配置为open drain输出试试看看。
PortxPCR寄存器中ODE位。”
 楼主| fhguo1990 发表于 2015-4-23 21:06 | 显示全部楼层
“请将SDA管脚配置 ...
刚看了下,那个引脚的开漏输出已经使能了啊在底层库里面
boolean ode = i2c_init_structure.I2C_OpenDrainEnable;
我是MT 发表于 2015-4-23 21:06 | 显示全部楼层
boolean ode = i2c_init_structure.I2C_OpenDrai ...
只是其他网友的建议,
我没有用过LPLD库,既然飞思的加速度传感器可以使用,
建议你还是去看看这个L3G4200的一些典型应用,是不是外围,或者控制时序方面有差异。
只是其他网友的建议,
建议你还是去看看这个L3G420 ...
之前拿M3的板子,用IO口模拟IIC,都可以读出来,现在不管是用M3的硬件IIC,还是K60的硬件IIC,配置的都可以读出其它IIC器件,就是读不出来L3G4200
 楼主| fhguo1990 发表于 2015-4-23 21:07 | 显示全部楼层
求解决方案啊
我思故我在12345 发表于 2015-4-23 21:08 | 显示全部楼层
楼主现在怎么样; ,期待你能够采集出信号,分享经验。。我的也是不行啊,NEC-03 温漂的厉害啊。。
我是MT 发表于 2015-4-23 21:09 | 显示全部楼层
之前拿M3的板子,用IO口模拟IIC,都可以读出来,现在不管是用M3的硬件IIC,还是K60的硬件IIC,配置的都可 ...
建议你可以把你的通信波形抓出来,然后资讯一下L3G4200公司的技术支持!
 楼主| fhguo1990 发表于 2015-4-23 21:09 | 显示全部楼层
现在搞定了,当时有人提出是SDA管脚要开漏,
我没仔细看,就以为它默认的是开漏
过了两天,我再仔细看,发现默认的是FALSE
改成TRUE就行了
我没仔细看,就以为它默认的是开漏
过了两天,我再仔细看, ...
恭喜楼主解决问题,同时也感谢你分享经验!
另外楼主如果问题解决了,请将标题加上“已解决”
我思故我在12345 发表于 2015-4-23 21:10 | 显示全部楼层
我没仔细看,就以为它默认的是开漏
过了两天,我再仔细看, ...
一个不小心给烧了,哎。。你的程序仅仅只是加了一句   i2c_init_param.I2C_OpenDrainEnable=TRUE;  对吧。。谢谢了。
 楼主| fhguo1990 发表于 2015-4-23 21:11 | 显示全部楼层
一个不小心给烧了,哎。。你的程序仅仅只是加了一句   i2c_init_param.I2C_OpenDrainEnable=TRUE;  对吧 ...
额,有钱人啊,烧一个一百多啊!!
是的,就加那一句话就可以了
我思故我在12345 发表于 2015-4-23 21:11 | 显示全部楼层
额,有钱人啊,烧一个一百多啊!!
是的,就加那一句话就可以了
我的这个没有那多,也心疼啊
我思故我在12345 发表于 2015-4-23 21:12 | 显示全部楼层
之前我测VCC和GND他们是导通的 ,现在又,没有问题了,可以我的CS 一接3.3V 就冒烟,你遇到这样的问题了吗?
 楼主| fhguo1990 发表于 2015-4-23 21:12 | 显示全部楼层
之前我测VCC和GND他们是导通的 ,现在又,没有问题了,可以我的CS 一接3.3V 就冒烟,你遇到这样的问题了吗 ...
木有发现这个问题额,我还以为你是主控板烧了呢,传感器烧了是小事
我思故我在12345 发表于 2015-4-23 21:13 | 显示全部楼层
int16 resultx,resulty,resultz;
uint8 device_id  ;
  void delay(void)  ;
void main (void)
   //初始化L3G4200D底层驱动及寄存器
device_id=L3G4200_Init();
  if(device_id==L3G4200_DEV_ID)
    printf("L3G4200D init succeed!\r\n");
    printf("Device ID :0x%X\r\n,device_id") ;
  else
    printf("L3G4200D Init failed !\r\n");
    printf("Device ID :0x%x\r\n,device_id");
    while(1);
  while(1)
    resultx=L3G4200_GetResult(L3G4200_STATUS_X_READY,OUT_X_L);
    resulty=L3G4200_GetResult(L3G4200_STATUS_Y_READY,OUT_Y_L) ;
    resultz=L3G4200_GetResult(L3G4200_STATUS_Z_READY,OUT_Z_L);
    printf("XYZ:\t%d\t%d\t%d\r\n", resultx, resulty, resultz);
void delay(void)
   int16 i,n;
   for (i=0;i<30000;i++)
      for (n=0;n<200;n++)
        asm("nop");
在CS 端接10K电阻后接3.3V没有冒烟,不接就会冒烟的,现在还是不能正确的读取ID
给看看是不是这里有问题呢,
我刚刚测了一下CS端的电压,电压比较低。但是如果我不在电路中串入电阻的话,传感器就会冒烟的,我是使用的lm117-3.3 V的稳压芯片。
 楼主| fhguo1990 发表于 2015-4-23 21:13 | 显示全部楼层
uint8 device_id  ;
  void delay(void)  ;
悬空试试? 理论上直接接3.3V 是没有问题的,或者是你那块板子有问题
我思故我在12345 发表于 2015-4-23 21:14 | 显示全部楼层
等我的传感器到了,如果不行的话。在请教一下你哈。。
我思故我在12345 发表于 2015-4-23 21:15 | 显示全部楼层
* @file DEV_L3G4200D.h
* @version 0.1[LUDSMARTCAR]
* @date 2013-11-9
* @brief L3G4200三轴陀螺仪设备驱动程序
#ifndef __DEV_L3G4200D_H__
#define __DEV_L3G4200D_H__
#include "common.h"
#include "HW_I2C.h"
//连接L3G4200用到的I2C通道
//连接L3G4200用到的SCL引脚
//连接L3G4200用到的SDA引脚
#define L3G4200_DEV_ADDR     0x69//0X68//0x69         //定义器件地址,可根据硬件修改
#define L3G4200_DEV_WRITE    0xD2//0XD0//0xD2
#define L3G4200_DEV_READ     0XD3//0XD1//0xD3
//L3G4200 内部寄存器地址
//函数声明
#endif
* @date 2013-11-9
#include "DEV_L3G4200D.h"
  uint8 device_id=0;
  //初始化L3G4200_I2CX
    //读取设备ID
  //进行寄存器配置
  return device_id ;
*   L3G4200_WriteReg
*   参数:
*   RegisterAddress
*    |__ L3G4200寄存器地址
*   Data
*    |__ 具体写入的字节型数据
   //发送从机地址
  //写L3G4200寄存器地址
  //向寄存器中写具体数据
   L3G4200_Delay();
*   L3G4200_ReadReg
*   该函数用于读取L3G4200的数据
*   参数:
*     RegisterAddress
*        |__ MMA8451寄存器地址
*   返回值
*      加速传感器的测量值
  uint8 result=0;
  //发送从机地址
  //再次产生开始信号
  //发送从机地址和读取位
  //转换主机模式为读
  //关闭应答ACK
  // Dummy read 虚假读取
  //发送停止信号
  //读IIC数据
  L3G4200_Delay();
  L3G4200_Delay();
  L3G4200_Delay();
  return result;
* 参数
*       Status - 数据寄存器状态
* 函数返回值:加速度值(int16)
  uint8 ret=0;
  uint16 cnt=0;
  int16 result,temp;
  // 等待转换完成并取出值
    if(++cnt>500)
    //  break;
  result=result<<8;
  result=result|temp;
  return result;
* 延时函数
  int n;
    asm("nop");
* --------------基于"拉普兰德K60底层库V3"的工程(L3G4200D)-----------------
* @file L3G4200D.c
* @version 0.0
* @date 2013-9-29
* @brief 关于该工程的描述
* 版权所有:北京拉普兰德电子技术有限公司
* http://www.lpld.cn
* mail:support@lpld.cn
* 硬件平台:  LPLD K60 Card / LPLD K60 Nano
* 本工程基于"拉普兰德K60底层库V3"开发,
* 所有开源代码均在"lib"文件夹下,用户不必更改该目录下代码,
* 所有用户工程需保存在"project"文件夹下,以工程名定义文件夹名,
* 底层库使用方法见相关文档。
#include "common.h"
uint8 device_id  ;
  void delay(void)  ;
void main (void)
  else
    while(1);
  while(1)
void delay(void)
   int16 i,n;
      for (n=0;n<200;n++)
        asm("nop");
能给测试一下L3G4200D吗?我这里使用你的代码还是读不出ID 啊。新来的传感器。,。帮忙测一下,代码能否读取ID 吧,顺便给来张截图
