Video Interface<br />– Supports NTSC (M, J, 4.43), PAL (B, D, G, H, I, M, N, Nc), PAL-60 TV Standard Video out and<br />Progressive Scan (525P/625P, RGB/YPbPr) Component Video out (compliant with EIA770-1/2)<br />– Four built-in 54 MHZ/10-bits Video DACs Providing Video Outputs of Composite, S-Video, or<br />Component (YUV, RGB, .)<br />– Compliant with Macrovision 7.1 for Interlaced Video (NTSC, PAL); Macrovision AGC 1.2 for<br />Progressive Scan (525P, 625P)<br />– Encoder of WSS (Wide Screen Signaling) for PAL Formats<br />– Encoder of CGMS (Copy Generation Management System) for NTSC Formats<br />– Supports Close Captioning<br />– Programmable LUMA/CHROMA Filters<br />– Programmable LUMA/CHROMA Delay (Y to C or C to Y)<br />– On-chip Image / Video Enhancement Filtering, e.g. Brightness / Contrast / Saturation / Hue<br />Adjustment<br />– Automatic Detection of Video DAC Connection Presence for Power-Saving Capability<br />– Supports VGA Output Mode for PC Monitor<br />– Supports Simultaneous Interlaced Video (CVBS, S-Video) and Progressive Video (525P/625P,<br />RGB/YPbPr) Outputs<br />– Supports Direct CCIR-601/656 Digital Video Output for External TV Encoder / Video Processor<br />– Supports Direct CCIR-601/656 Digital Video Input from External video Decoder<br />– Supports Direct ITU1120 and SMPTE274M Digital Video Output for External High Definition TV<br />Encoder
