44b0 烧写出问题,请教,请教
 楼主| gugou 发表于 2008-6-19 14:26 | 显示全部楼层 |阅读模式
cpu&nbsp;44b0&nbsp;&nbsp;&nbsp;flash&nbsp;&nbsp;am29lv160db&nbsp;&nbsp;bank0<br />1.flash&nbsp;program&nbsp;始终不能进入arm,出现如下提示:(点flash&nbsp;id&nbsp;测试)&nbsp;<br /><br />unknow&nbsp;error<br />bus&nbsp;error&nbsp;<br />process&nbsp;is&nbsp;running<br />unable&nbsp;into&nbsp;...<br />held&nbsp;in&nbsp;reset&nbsp;<br />等提示错误<br /><br />2.好不容易进去几次成功(点30,进一次)<br />一次点察除,察到一半,出错,(里面原带的uboot&nbsp;,给察掉了,重新上电,Ulinux&nbsp;不运行了)<br />一次,察除成功,点program,始终未烧写成功?&nbsp;<br /><br /><br />3.我重新调试,用jtag调试运行还是可以的<br /><br />我想问下各位,是哪出问题了?有碰过类是的吗?&nbsp;<br />我的flash&nbsp;芯片有问题吗?昨天搞到12点多还是一团乱?希望大家指点一下
 楼主| gugou 发表于 2008-6-19 14:54 | 显示全部楼层
有时也有如下错误
Unable&nbsp;to&nbsp;put&nbsp;Target&nbsp;into&nbsp;Background&nbsp;Mode
Again_gyf 发表于 2008-6-19 16:04 | 显示全部楼层
你用啥烧写软件啦?
用HFLASHER试试!<br />下面是我的配置,照样改<br />FLASH&nbsp;SECTION:<br />SST<br />SST39VF160<br />MEMORY&nbsp;SECTION:<br />16<br />0x00000000<br />0x0C000000<br />XTAL&nbsp;SECTION:<br />NULL<br />SCRIPT&nbsp;SECTION:<br />SoftReset+++<br />Delay+++1<br />Setmem+32-Bit+0x01D30000+0x0<br />Setmem+32-Bit+0x01E0000C+0x07FFFFFF<br />Setmem+32-Bit+0x01D8000C+0xFFF<br />Setmem+32-Bit+0x01D80000+0x5C081<br />Setmem+32-Bit+0x01D80004+0x7FF8<br />Setmem+32-Bit+0x1F80008+0x40000000<br />Setmem+32-Bit+0x1F80028+0x40000000<br />Setmem+32-Bit+0x01C80000+0x11100000<br />Setmem+32-Bit+0x01C80004+0x00002E50<br />Setmem+32-Bit+0x01C80008+0x00007FFC<br />Setmem+32-Bit+0x01C8000C+0x00007FFC<br />Setmem+32-Bit+0x01C80010+0x00007FFC<br />Setmem+32-Bit+0x01C80014+0x00007FFC<br />Setmem+32-Bit+0x01C80018+0x00000C40<br />Setmem+32-Bit+0x01C8001C+0x00018000<br />Setmem+32-Bit+0x01C80020+0x00018000<br />Setmem+32-Bit+0x01C80024+0x00820460<br />Setmem+32-Bit+0x01C80028+0x00000010<br />Setmem+32-Bit+0x01C8002C+0x00000020<br />Setmem+32-Bit+0x01C80030+0x00000020<br />
 楼主| gugou 发表于 2008-6-19 16:11 | 显示全部楼层
我用的是flash pgm
