STM32刹车功能怎么配置和使用
4222|6
紫蕴箫剑|  楼主 | 2015-7-15 20:32 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
airwill| | 2015-7-16 07:53 | 只看该作者
软件上带刹车功能的 PWM 定时器有个总的使能位,
硬件上使用刹车功能, 外部刹车(低有效)信号应该接 TIMx_BKIN 引脚.
紫蕴箫剑|  楼主 | 2015-7-16 21:47 | 只看该作者
软件刹车就是直接利用定时器使能吗,如TIM_Cmd(TIM1, ENABLE);
硬件使能就是通过刹车接 TIMx_BKIN 引脚来控制吗?
只是我的大致代码,我刹车不会配置,能帮我看一下吗。给我指点一下刹车的配置。谢谢,
void TIM1_Config(void)
        TIM_OCInitTypeDef        TIM_OCInitStructure;
        TIM_BDTRInitTypeDef      TIM_BDTRInitStructure;
        TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
        GPIO_InitTypeDef         GPIO_InitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1 | RCC_APB2Periph_GPIOA |
                         RCC_APB2Periph_GPIOB |RCC_APB2Periph_AFIO, ENABLE);
  /* GPIOA Configuration: Channel 1, 2 and 3 as alternate function push-pull */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8 ;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
  /* GPIOB Configuration: BKIN pin */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;
  GPIO_InitStructure.GPIO_Mode =GPIO_Mode_IN_FLOATING;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
        GPIO_SetBits(GPIOB, GPIO_Pin_12);
  TIM_TimeBaseStructure.TIM_Prescaler = 100;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  TIM_TimeBaseStructure.TIM_Period = 4095;
  TIM_TimeBaseStructure.TIM_ClockDivision =0;
  TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;
  TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure);
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1 ;
  TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  TIM_OCInitStructure.TIM_Pulse = 2047;
  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
  TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Reset;
  TIM_OC1Init(TIM1, &TIM_OCInitStructure);
  TIM_BDTRInitStructure.TIM_OSSRState = TIM_OSSRState_Enable;
  TIM_BDTRInitStructure.TIM_OSSIState = TIM_OSSIState_Enable;
  TIM_BDTRInitStructure.TIM_LOCKLevel = TIM_LOCKLevel_OFF;
  TIM_BDTRInitStructure.TIM_DeadTime = 48;
  TIM_BDTRInitStructure.TIM_Break = TIM_Break_Enable;
        TIM_BDTRInitStructure.TIM_BreakPolarity = TIM_BreakPolarity_High;
  TIM_BDTRInitStructure.TIM_AutomaticOutput = TIM_AutomaticOutput_Enable;
  TIM_BDTRConfig(TIM1, &TIM_BDTRInitStructure);
  TIM_CCPreloadControl(TIM1, ENABLE);
  TIM_ARRPreloadConfig(TIM1, ENABLE);
  TIM_CtrlPWMOutputs(TIM1, ENABLE);
airwill| | 2015-7-17 09:54 | 只看该作者
我记得外设库有这方面的例程, 去参考一下
紫蕴箫剑|  楼主 | 2015-7-17 10:34 | 只看该作者
谢谢了,我刚刚解决了。是刹车管脚的模式设置的不对,手册上手刹车管脚的模式是浮空输入,但是要在外部接上拉电阻才行,我改成上拉模式了,就可以直接用了。最后很感谢你的指点,谢谢。
陌路绝途| | 2015-7-18 13:40 | 只看该作者
很不错的解决方案
紫蕴箫剑|  楼主 | 2015-7-19 08:43 | 只看该作者
