Reset_Handler <br /><br />; Setup Stack for each mode<br /> LDR R0, =Stack_Top<br /><br />; Enter Undefined Instruction Mode and set its Stack Pointer<br /> MSR CPSR_c, #Mode_UND:OR:I_Bit:OR:F_Bit ; :OR: Mode_UND,I_Bit,F_Bit之间按位作逻辑或操作,设置未定义模式,禁止FIQ,IRQ<br /> MOV SP, R0 ;堆指针指向栈顶<br /> SUB R0, R0, #UND_Stack_Size<br /><br />; Enter Abort Mode and set its Stack Pointer<br /> MSR CPSR_c, #Mode_ABT:OR:I_Bit:OR:F_Bit<br /> MOV SP, R0<br /> SUB R0, R0, #ABT_Stack_Size<br /><br />; Enter FIQ Mode and set its Stack Pointer<br /> MSR CPSR_c, #Mode_FIQ:OR:I_Bit:OR:F_Bit<br /> MOV SP, R0<br /> SUB R0, R0, #FIQ_Stack_Size<br /><br />; Enter IRQ Mode and set its Stack Pointer<br /> MSR CPSR_c, #Mode_IRQ:OR:I_Bit:OR:F_Bit<br /> MOV SP, R0<br /> SUB R0, R0, #IRQ_Stack_Size<br /><br />; Enter Supervisor Mode and set its Stack Pointer<br /> MSR CPSR_c, #Mode_SVC:OR:I_Bit:OR:F_Bit<br /> MOV SP, R0<br /> SUB R0, R0, #SVC_Stack_Size<br /><br />; Enter User Mode and set its Stack Pointer<br /> MSR CPSR_c, #Mode_USR<br /> MOV SP, R0<br /> SUB SL, SP, #USR_Stack_Size<br /> <br /> IMPORT TargetResetInit<br /> BL TargetResetInit<br /><br />; Enter the C code<br /><br /> IMPORT __main<br /> LDR R0, =__main<br /> BX R0<br /><br /><br />; User Initial Stack & Heap<br /> AREA |.text|, CODE, READONLY<br /><br /> IMPORT __use_two_region_memory<br /> EXPORT __user_initial_stackheap<br />__user_initial_stackheap<br /><br /> LDR R0, = Heap_Mem<br /> LDR R1, =(Stack_Mem + USR_Stack_Size)<br /> LDR R2, = (Heap_Mem + Heap_Size)<br /> LDR R3, = Stack_Mem<br /> BX LR<br /><br /> END<br />定义各模式堆栈的时候 为什么都有一个类似这样的减法语句<br />SUB R0, R0, #UND_Stack_Size<br />还有,定义完一个模式后,该模式下的RO的值都付给下模式的的堆栈指针?请注意下面的语句<br />Enter Abort Mode and set its Stack Pointer<br /> MSR CPSR_c, #Mode_ABT:OR:I_Bit:OR:F_Bit<br /> MOV SP, R0<br /> SUB R0, R0, #ABT_Stack_Size<br /><br />; Enter FIQ Mode and set its Stack Pointer<br /> MSR CPSR_c, #Mode_FIQ:OR:I_Bit:OR:F_Bit<br /> MOV SP, R0<br /> SUB R0, R0, #FIQ_Stack_Size<br /><br />下面语句的目的是?<br />__user_initial_stackheap<br /><br /> LDR R0, = Heap_Mem<br /> LDR R1, =(Stack_Mem + USR_Stack_Size)<br /> LDR R2, = (Heap_Mem + Heap_Size)<br /> LDR R3, = Stack_Mem<br /> BX LR<br />为什么要把堆栈的顶和底赋给不同的寄存器?<br /><br /> |
