[ZLG-ARM] magicarm2200
1946|3
 楼主| douglas816 发表于 2009-7-24 18:18 | 显示全部楼层 |阅读模式
请教:<br />h-jtag在zlg的试验箱magic2200上<br />那个配置文件怎么写哦<br /><br />买时自带的是easyjtag<br />我现在想用h-jtag试试<br />就要配置hfc文件啊<br />自己搞了几次没有成功<br />到底咋个配置啊<br />谢谢大侠指点!
孤独行者 发表于 2009-7-24 21:40 | 显示全部楼层
可以参考一下
H-JTAG烧写Flash-SST39VF1601的配置文件(LPC2210MCU)<br /><br />以下为.hfc文件的内容<br /><br />FLASH&nbsp;SECTION:<br />SST<br />SST39VF1601<br />MEMORY&nbsp;SECTION:<br />16<br />0x80000000<br />0x40000000<br />XTAL&nbsp;SECTION:<br />NULL<br />SCRIPT&nbsp;SECTION:<br />Setmem+32-Bit+0xE002C014+0x0F814914<br />Setmem+32-Bit+0xFFE00000+0x10007DE7<br />Setmem+32-Bit+0xFFE00004+0x10000400<br />&nbsp;<br /><br />
孤独行者 发表于 2009-7-24 21:42 | 显示全部楼层
还有
H-JTAG发布V0.4.0版本<br />欢迎到我的BLOG下载:http://twentyone.blogchina.com<br /><br />1.&nbsp;Improve&nbsp;the&nbsp;SUPPORT&nbsp;to&nbsp;ARM9E-S&nbsp;and&nbsp;ARM9EJ-S.<br />2.&nbsp;Add&nbsp;TAP&nbsp;configuration&nbsp;to&nbsp;SUPPORT&nbsp;complex&nbsp;TAP/JTAG<br />3.&nbsp;Add&nbsp;the&nbsp;SUPPORT&nbsp;for&nbsp;initialization&nbsp;script,&nbsp;which&nbsp;can&nbsp;be&nbsp;used&nbsp;for&nbsp;auto&nbsp;initialization<br />4.&nbsp;Add&nbsp;the&nbsp;PROGRAMMING&nbsp;of&nbsp;NOR&nbsp;FLASH&nbsp;and&nbsp;AT91SAM.&nbsp;But&nbsp;ONLY&nbsp;a&nbsp;few&nbsp;chips&nbsp;are&nbsp;SUPPORTed&nbsp;currently.I&nbsp;will&nbsp;upgrade&nbsp;H-Flasher&nbsp;to&nbsp;SUPPORT&nbsp;more&nbsp;NOR&nbsp;FLASH&nbsp;chip&nbsp;step&nbsp;by&nbsp;step.&nbsp;The&nbsp;PROGRAMMING&nbsp;of&nbsp;AT91SAM&nbsp;chips&nbsp;may&nbsp;have&nbsp;some&nbsp;problem.&nbsp;I&nbsp;am&nbsp;looking&nbsp;for&nbsp;some&nbsp;BOARDS&nbsp;for&nbsp;testing.&nbsp;I&nbsp;will&nbsp;correct<br />the&nbsp;problem&nbsp;asap.<br />
 楼主| douglas816 发表于 2009-7-25 08:23 | 显示全部楼层
magicarm2200
谢谢大侠指点<br />多谢!
