[STM8] 应将i2c发送完地址收不到数据
915|2
 楼主| aaa1125456 发表于 2015-7-28 11:14 | 显示全部楼层 |阅读模式
state_tmp102 tmp102_tmpConversion()
    while(I2C_GetFlagStatus(I2C1,I2C_FLAG_BUSY));
    I2C_GenerateSTART(I2C1,ENABLE);
    while(!I2C_CheckEvent(I2C1,I2C_EVENT_MASTER_MODE_SELECT));
    I2C_Send7bitAddress(I2C1,0x90,I2C_Direction_Transmitter);
    while(!I2C_CheckEvent(I2C1,I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED));
    I2C_SendData(I2C1,0x01);
    while(!I2C_CheckEvent(I2C1,I2C_EVENT_MASTER_BYTE_TRANSMITTING));
    I2C_SendData(I2C1,0xe0);
    I2C_SendData(I2C1,0xa0);
    while(!I2C_CheckEvent(I2C1,I2C_EVENT_MASTER_BYTE_TRANSMITTED));
    I2C_GenerateSTOP(I2C1,ENABLE);
    return SUCCESS_TMP102;
state_tmp102 tmp102_read(unsigned int *byte)
    unsigned int byte1 = 0,byte2 = 0;
    if(tmp102_tmpConversion() == ERROR_TMP102)
        return ERROR_TMP102;
    I2C_SendData(I2C1,0x00);
    I2C_Send7bitAddress(I2C1,0x91,I2C_Direction_Transmitter);
    while(!I2C_CheckEvent(I2C1,I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED));
    while(!I2C_CheckEvent(I2C1,I2C_EVENT_MASTER_BYTE_RECEIVED));  ////////////////等待收到数据
    byte1 = (unsigned char)I2C_ReceiveData(I2C1);
    byte2 = (unsigned char)I2C_ReceiveData(I2C1);
    I2C_AcknowledgeConfig(I2C1,DISABLE);
    *byte = (byte1 << 8) | byte2;
    *byte = *byte >>4;
程序卡在 ///////等待接收数据哪里    是上一步没把寄存器清理干净吗?
 楼主| aaa1125456 发表于 2015-7-28 11:18 | 显示全部楼层
真心服了 用寄存器就行  用库函数就不行  这是玩我呢
 楼主| aaa1125456 发表于 2015-7-28 11:21 | 显示全部楼层
自己解决了  原来是光复制上面的内容了 忘了改 接收地址
I2C_Send7bitAddress(I2C1,0x91,I2C_Direction_Receiver);
