[ZLG-ARM] keil mdk3.5编译的问题
2695|8
 楼主| mon51 发表于 2009-4-8 20:23 | 显示全部楼层 |阅读模式
为何选择微型库编译,就出错?
 楼主| mon51 发表于 2009-4-8 20:24 | 显示全部楼层
附图
https://bbs.21ic.com/upfiles/img/20094/200948202240524.jpg
zcying 发表于 2009-4-9 10:18 | 显示全部楼层
这个不清楚。以前也遇到过这样的问题。
胡刚 发表于 2009-4-14 15:58 | 显示全部楼层
建议不要使用微库,特别是初学者
jlwg 发表于 2009-4-19 12:25 | 显示全部楼层
同感,不是空间不够用的话,最好不要使用微库。
qingfengyishi 发表于 2009-4-20 13:27 | 显示全部楼层
楼主看看帮助文件中的说明就明白了
3.1.&nbsp;About&nbsp;microlib<br />Microlib&nbsp;is&nbsp;an&nbsp;alternative&nbsp;library&nbsp;to&nbsp;the&nbsp;default&nbsp;C&nbsp;library.&nbsp;It&nbsp;is&nbsp;intended&nbsp;for&nbsp;use&nbsp;with&nbsp;deeply&nbsp;embedded&nbsp;applications&nbsp;that&nbsp;need&nbsp;to&nbsp;fit&nbsp;into&nbsp;extremely&nbsp;small&nbsp;amounts&nbsp;of&nbsp;memory.&nbsp;These&nbsp;applications&nbsp;do&nbsp;not&nbsp;run&nbsp;under&nbsp;an&nbsp;operating&nbsp;system.<br /><br />Note<br />Microlib&nbsp;does&nbsp;not&nbsp;attempt&nbsp;to&nbsp;be&nbsp;a&nbsp;standards-compliant&nbsp;ISO&nbsp;C&nbsp;library.<br />Microlib&nbsp;is&nbsp;highly&nbsp;optimized&nbsp;for&nbsp;small&nbsp;code&nbsp;size.&nbsp;It&nbsp;has&nbsp;less&nbsp;functionality&nbsp;than&nbsp;the&nbsp;default&nbsp;C&nbsp;library&nbsp;and&nbsp;some&nbsp;ISO&nbsp;C&nbsp;features&nbsp;are&nbsp;completely&nbsp;missing.&nbsp;Some&nbsp;library&nbsp;functions&nbsp;will&nbsp;also&nbsp;be&nbsp;slower,&nbsp;for&nbsp;example,&nbsp;memcpy().<br />&nbsp;&nbsp;<br /><br />3.3.&nbsp;Using&nbsp;microlib<br />To&nbsp;begin,&nbsp;you&nbsp;must&nbsp;specify&nbsp;a&nbsp;starting&nbsp;pointer&nbsp;for&nbsp;the&nbsp;stack.&nbsp;This&nbsp;must&nbsp;be&nbsp;aligned&nbsp;to&nbsp;a&nbsp;multiple&nbsp;of&nbsp;eight&nbsp;bytes.&nbsp;To&nbsp;use&nbsp;the&nbsp;heap&nbsp;functions,&nbsp;for&nbsp;example,&nbsp;malloc,&nbsp;calloc,&nbsp;realloc&nbsp;and&nbsp;free,&nbsp;you&nbsp;must&nbsp;specify&nbsp;the&nbsp;location&nbsp;and&nbsp;size&nbsp;of&nbsp;the&nbsp;heap&nbsp;region.<br /><br /><br />
jumpoo 发表于 2009-5-11 13:51 | 显示全部楼层
我以前也改成微库的方式,就出错了
acertm 发表于 2009-5-12 12:47 | 显示全部楼层
学习了,还有这个学问呢
msleep 发表于 2009-5-19 14:30 | 显示全部楼层
