[ZLG-ARM]
时钟问题
1336|1
reeper|  楼主 | 2009-4-9 14:59 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include
#include
#include
typedef  unsigned char  uchar ;
typedef unsigned int  uint;
#define P_262 P1   //口线连线(从高到低):A3,A2,A1,A0,D1,D0,Wr,_
  sbit P_wr = P_262^1;
  sbit Fclk_S2=P2^2; //CPLD选择Fclk控制线
  sbit Fclk_S1=P2^1;
  sbit Fclk_S0=P2^0;
sbit PFS0=P2^3;//工作模式工作模式选择0
sbit PFS1=P2^4;//工作模式工作模式选择1
long FLCK = 1000000 ; //MAX262工作频率
uchar Mod=2;//工作模式0,1,2,3
#define PI 3.1415926
#define delay_262()  _nop_();_nop_();_nop_()
void delay(unsigned int d)
{unsigned char j;
while(d!=0)
   d--;
   j=70;
   do {j--;} while(j!=0);
//写两比特的数据
void write(uchar add,uchar dat2bit)
   P_262=(P_262&0x0f)|(add<<4);
  P_262=(P_262&0xf3)|((dat2bit<<2)&0x0c);
  P_wr=0;
  delay_262();
  P_wr=1;
  delay_262();
//设置A通道工作模式
void Set_AM(uchar mod)
   write(0,mod);
//设置A通道F值
void Set_AF(uchar datF)
   write(1,datF);
   datF=datF>>2;
   write(2,datF);
   datF=datF>>2;
   write(3,datF);
//设置A通道Q值
void Set_AQ(uchar datQ)
   write(4,datQ);
   datQ=datQ>>2;
   write(5,datQ);
   datQ=datQ>>2;
   write(6,datQ);
   datQ=(datQ>>2)&1;
   write(7,datQ);
//设置B通道工作模式
void Set_BM(uchar mod)
   write(8,mod);
//设置A通道F值
void Set_BF(uchar datF)
   write(9,datF);
   datF=datF>>2;
   write(10,datF);
   datF=datF>>2;
   write(11,datF);
//设置A通道Q值
void Set_BQ(uchar datQ)
   write(12,datQ);
   datQ=datQ>>2;
   write(13,datQ);
   datQ=datQ>>2;
   write(14,datQ);
   datQ=(datQ>>2)&1;
   write(15,datQ);
//基本计算
//根据截止频率fc计算中心频率f0
uchar CopF0(float q, float fc)
        q  =  pow(q, 2);
        q  =  (float)q*2;
        q  = (float)(q-1)/q;//1-(1/q)
        fc = (float)fc * sqrt(sqrt(1+pow(q,2))-q);
float CopF0_tx(float q, float fc)
        q  =  pow(q, 2);
        q  =  (float)q*2;
        fc = fc * sqrt(sqrt(1+pow(q,2))+q);
//根据中心频率求设定值FN
float CopFn(uchar mod, float f0)
if (1==mod)
  return ((float)((FLCK*2.8284271247/f0)/PI)-26);
else
   return ((float)((FLCK*2/f0)/PI)-26);
//根据Q求设定值QN
uchar CopQn(uchar mod, float q)
if (1==mod)
         return (128-(float)(90.51/q));
else
                 return (128-(float)(64/q));
//功能接口函数
//设定频率
Set_F0(uchar mod,float f0 )
  if(f0>28612)
     Fclk_S2=0;Fclk_S1=0;Fclk_S0=0;//Fclk 4M
     FLCK=4000000;
  else if(f0>14306)
      Fclk_S2=0;Fclk_S1=0;Fclk_S0=1;//Fclk 2M
      FLCK=2000000;
  else if(f0>7153)
     Fclk_S2=0;Fclk_S1=1;Fclk_S0=0; //Fclk 1M
     FLCK=1000000;
  else if(f0>3683)
     Fclk_S2=0;Fclk_S1=1;Fclk_S0=1;//Fclk 512K
     FLCK=512000;
  else if(f0>1831)
      Fclk_S2=1;Fclk_S1=0;Fclk_S0=0;//Fclk 256
      FLCK=256000;
  else
      Fclk_S2=1;Fclk_S1=0;Fclk_S0=1;//Fclk 128
      FLCK=128000;
Set_AF(CopFn(mod,f0));
Set_BF(CopFn(mod,f0));
//设置滤波器模式 , 0为底通、1为高通、2为带通
Set_PFmod(uchar mod)
if(mod<3)
     switch(mod)
      { case 0:
              PFS1=0FS0=0;
              Mod=0;
              break;
         case 1:
              PFS1=0FS0=1;
              Mod=2;
              break;
         case 2:
              PFS1=1FS0=0;
              Mod=0;
              break;
     Set_AM(Mod); Set_BM(Mod);
//uint Tx;
float Tx;
void main(void)
   Tx=CopFn(Mod,120048);
   Tx=CopQn(Mod,1);
   Tx=CopF0(0.7,60000);
   Tx=CopF0_tx(0.7,Tx); */
   delay(10000);delay(10000);delay(10000);
   Set_AM(Mod);
   Set_AQ(CopQn(Mod,1));
   Set_BM(Mod);
   Set_BQ(CopQn(Mod,1));
  //Set_AF(CopFn(Mod,5000));
  //Set_BF(CopFn(Mod,5000));
   Set_PFmod(2);
  Set_F0(Mod,8000);
  for(;;);
请各位帮忙看看。这个程序中52单片机的时钟信号是怎么输入给MAX262的。硬件应该怎么样连接?
zcying| | 2009-4-9 15:00 | 只看该作者
SPI?还是通过单片机那个自动引脚?
