[ZLG-MCU] LM3S6916 RTC
3811|13
 楼主| gdpiao 发表于 2008-3-2 18:53 | 显示全部楼层 |阅读模式
RTC, lm, TE, se, BLE
请教如何配置LM3S6916&nbsp;Hiberate&nbsp;里的&nbsp;RTC?<br /><br />是否如下:<br />1.HiberateClkSelect();<br />2.HiberateEnable(SysClkGet());<br />3.HiberateRTCEnable();<br /><br />然后就可以<br />HiberateRTCSet(mysec);<br />mysec&nbsp;=&nbsp;HiberateRTCGet();<br /><br />如果不是,请问具体的流程是如何?<br />还是有其他特殊的操作?
 楼主| gdpiao 发表于 2008-3-3 09:33 | 显示全部楼层
RTC 都没起振
RTC&nbsp;都没起振<br /><br />HiberateRTCGet&nbsp;回来的总是0。是否需要配置其他才能启动?&nbsp;或者说是硬件上有其他要求?比如:Vbat一定要多少v之类的?
 楼主| gdpiao 发表于 2008-3-3 09:58 | 显示全部楼层
RTC 耗电大
另外,还有一个问题。我用的是3V&nbsp;纽扣电池加4148&nbsp;和3.3v&nbsp;加4148&nbsp;竞争供电,结果,没3个星期,电池电量剩下0.6v&nbsp;,根据datasheet&nbsp;是16ua&nbsp;我就不知道是不是在掉电的时候一定要进入hiberate&nbsp;deep&nbsp;sleep&nbsp;mode&nbsp;,(因为我的程序还没有这步),导致这样的效果。
 楼主| gdpiao 发表于 2008-3-3 10:35 | 显示全部楼层
RTC Initialization In datasheet
If&nbsp;a&nbsp;32.678-kHz&nbsp;oscillator&nbsp;is&nbsp;used,&nbsp;then&nbsp;perform&nbsp;the&nbsp;following&nbsp;steps:<br />1.&nbsp;Write&nbsp;0x44&nbsp;to&nbsp;the&nbsp;HIBCTL&nbsp;register&nbsp;at&nbsp;offset&nbsp;0x10&nbsp;to&nbsp;enable&nbsp;the&nbsp;oscillator&nbsp;input.<br />2.&nbsp;No&nbsp;delay&nbsp;is&nbsp;necessary.<br />The&nbsp;above&nbsp;is&nbsp;only&nbsp;necessary&nbsp;when&nbsp;the&nbsp;entire&nbsp;system&nbsp;is&nbsp;initialized&nbsp;for&nbsp;the&nbsp;first&nbsp;time.&nbsp;If&nbsp;the&nbsp;processor<br />is&nbsp;powered&nbsp;due&nbsp;to&nbsp;a&nbsp;wake&nbsp;from&nbsp;hibernation,&nbsp;then&nbsp;the&nbsp;Hibernation&nbsp;module&nbsp;has&nbsp;already&nbsp;been&nbsp;powered<br />up&nbsp;and&nbsp;the&nbsp;above&nbsp;steps&nbsp;are&nbsp;not&nbsp;necessary.&nbsp;The&nbsp;software&nbsp;can&nbsp;detect&nbsp;that&nbsp;the&nbsp;Hibernation&nbsp;module<br />and&nbsp;clock&nbsp;are&nbsp;already&nbsp;powered&nbsp;by&nbsp;examining&nbsp;the&nbsp;CLK32EN&nbsp;bit&nbsp;of&nbsp;the&nbsp;HIBCTL&nbsp;register.
 楼主| gdpiao 发表于 2008-3-5 11:05 | 显示全部楼层
LUMINARY XNP
NXPfdf&nbsp;
 楼主| gdpiao 发表于 2008-3-11 22:51 | 显示全部楼层
on the status
 楼主| gdpiao 发表于 2008-3-12 11:17 | 显示全部楼层
Done
Done<br /><br />悲哀啊。<br />我终于决定不使用LM的arm了。技术支持太让我失望了。
ZlGaRm 发表于 2008-3-12 11:36 | 显示全部楼层
gdpiao
您好!<br />&nbsp;&nbsp;这是我们工作的失误!!我们BBS技术支持的值日版主没有看到此贴,我本人在查漏贴时也没有查到!十分抱歉!这说明我们查找漏贴的机制有问题!<br /><br />&nbsp;&nbsp;关于那个问题,请您直接致电020-22644252,我也已请那方面的同事来回帖。请您留下您的电话,我直接向您道歉。<br />&nbsp;&nbsp;<br />&nbsp;&nbsp;此外,我们会反思,为什么数天过去,3个BBS支持小组成员都没发现这个漏贴,这是我们需要总结的地方。<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;By&nbsp;&nbsp;zlgarm_ltt
ZlGaRm 发表于 2008-3-12 11:41 | 显示全部楼层
您好!<br />&nbsp;&nbsp;此外,您以后能否直接致电我们,毕竟这样绝对快速可靠。BBS上的技术支持无论如何是滞后的。<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;By&nbsp;zlgarm_ltt
ZLGARM 发表于 2008-3-12 14:44 | 显示全部楼层
我们正在处理
谢谢gdpiao提出此问题。很多客户都关心RTC问题,所以我们正在整理程序,完成后会在本帖发表。<br /><br />(zlgarm_zsg)
 楼主| gdpiao 发表于 2008-3-12 15:26 | 显示全部楼层
问题已经解决
由于我没购买zlg的开发板,所以一直没有好意思打扰。后来我通过email&nbsp;请教Luminary&nbsp;Micro,在他们的工程师指导下已经解决问题了。多谢各位关心
muweiliuhao 发表于 2010-9-6 15:07 | 显示全部楼层
咋解决的 我也是这个问题  LM3S9B90
黑发尤物 发表于 2010-9-7 22:55 | 显示全部楼层
怎么解决的?楼主分享下吧
3B1105 发表于 2010-9-12 16:37 | 显示全部楼层
希望楼主可以和大家分享下怎么解决的
