[ZLG-MCU] IAR for ARM5.11 如何设置编译,连接的参数
1919|2
 楼主| haibingcug 发表于 2008-3-10 21:41 | 显示全部楼层 |阅读模式
我在编译时出现下面警告,是什么问题,是startup.c文件的问题吗?很着急,希望得到解决!把程序下载后,系统老是死进入&nbsp;错误中断&nbsp;,这是什么问题?<br /><br />Linking&nbsp;<br />Warning[Lp012]:&nbsp;no&nbsp;sections&nbsp;with&nbsp;name&nbsp;DATA_ID&nbsp;included&nbsp;-&nbsp;special&nbsp;symbol&nbsp;DATA_ID$$Base&nbsp;(referenced&nbsp;from&nbsp;C:Documents&nbsp;and&nbsp;Settings兵哥桌面GPIO_IN_OUTDebugObjstartup.o)&nbsp;will&nbsp;be&nbsp;zero&nbsp;<br /><br />Warning[Lp012]:&nbsp;no&nbsp;sections&nbsp;with&nbsp;name&nbsp;DATA_I&nbsp;included&nbsp;-&nbsp;special&nbsp;symbol&nbsp;DATA_I$$Base&nbsp;(referenced&nbsp;from&nbsp;C:Documents&nbsp;and&nbsp;Settings兵哥桌面GPIO_IN_OUTDebugObjstartup.o)&nbsp;will&nbsp;be&nbsp;zero&nbsp;<br /><br />Warning[Lp012]:&nbsp;no&nbsp;sections&nbsp;with&nbsp;name&nbsp;DATA_Z&nbsp;included&nbsp;-&nbsp;special&nbsp;symbol&nbsp;DATA_Z$$Base&nbsp;(referenced&nbsp;from&nbsp;C:Documents&nbsp;and&nbsp;Settings兵哥桌面GPIO_IN_OUTDebugObjstartup.o)&nbsp;will&nbsp;be&nbsp;zero&nbsp;<br />
hotpower 发表于 2008-3-10 23:38 | 显示全部楼层
俺还是退回去了~~~
zlgmcu 发表于 2008-3-11 10:25 | 显示全部楼层
还是建议您采用IAR 4.42A版本
(zlgmcu_wdx)
