怎样计算出【汉字内码索引值】一共有多少个
2405|7
 楼主| hello_galaxy 发表于 2015-8-12 15:40 | 显示全部楼层 |阅读模式
  1. struct typFNT_GB16                 // 汉字字模数据结构
  3.        unsigned char Index[2];               // 汉字内码索引
  4.        char Msk[32];                       // 点阵码数据
  5. };
  6. struct typFNT_GB16 code_GB_16[] =          // 数据表
  7. {
  8. "检", 0x10,0x40,0x10,0x40,0x10,0xA0,0x10,0xA0,
  9.       0xFD,0x10,0x12,0x0E,0x35,0xF4,0x30,0x00,
  10.       0x58,0x40,0x56,0x48,0x91,0x4C,0x11,0x48,
  11.       0x11,0x50,0x10,0x04,0x1F,0xFE,0x10,0x00,
  12. "测", 0x00,0x00,0x40,0x44,0x27,0xE4,0x24,0x54,
  13.       0x85,0x54,0x65,0x54,0x25,0x54,0x0D,0x54,
  14.       0x15,0x54,0x25,0x54,0xE5,0x54,0x21,0x04,
  15.       0x22,0x84,0x24,0x44,0x28,0x54,0x20,0x08,
  16. "到", 0x01,0x04,0x7F,0x84,0x08,0x04,0x10,0x24,
  17.       0x22,0x24,0x41,0x24,0x7F,0xA4,0x08,0xA4,
  18.       0x0A,0x24,0x7F,0x24,0x08,0x24,0x08,0x24,
  19.       0x08,0x04,0x0F,0x84,0xF8,0x14,0x00,0x08,
  20. "卡", 0x02,0x00,0x02,0x20,0x03,0xF0,0x02,0x00,
  21.       0x02,0x00,0x02,0x04,0xFF,0xFE,0x02,0x00,
  22.       0x02,0x00,0x02,0x80,0x02,0x60,0x02,0x30,
  23.       0x02,0x10,0x02,0x00,0x02,0x00,0x02,0x00,
  24. "注", 0x00,0x80,0x40,0x40,0x30,0x44,0x17,0xFE,
  25.       0x80,0x40,0x60,0x40,0x20,0x40,0x08,0x48,
  26.       0x17,0xFC,0x20,0x40,0xE0,0x40,0x20,0x40,
  27.       0x20,0x40,0x20,0x44,0x2F,0xFE,0x20,0x00,
  28. ……
  29. }
这样的结构体怎样计算出【汉字内码索引值】一共有多少个?
麦可可 发表于 2015-8-12 20:02 | 显示全部楼层
一个汉字32个,乘以汉字就知道了,汉字的个数可以取数组成员的个数决定
评分
参与人数 1威望 +1 收起 理由
hello_galaxy + 1 神马都是浮云
查看全部评分
黑夜的风 发表于 2015-8-13 10:01 | 显示全部楼层
楼主要计算的是哪个东西呢?糊涂了
黑夜的风 发表于 2015-8-14 14:49 | 显示全部楼层
由你的取字模的大小决定的。
september7 发表于 2015-8-15 15:07 | 显示全部楼层
16*16的字模,每8个点占一个字节,总共就是16*16/8=32个字节
eggbiscuit 发表于 2015-8-29 16:20 | 显示全部楼层
根据你的取模大小就可以决定了
 楼主| hello_galaxy 发表于 2015-11-19 16:50 | 显示全部楼层
确实是这么大的,谢谢了!
 楼主| hello_galaxy 发表于 2015-11-19 16:51 | 显示全部楼层
结贴分数不够了,哈哈,给你单独评分吧。
