[STM8] 还是坑爹的I2C问题
11139|30
 楼主| ww_升 发表于 2015-8-14 15:50 | 显示全部楼层 |阅读模式
I2c, TE, ST, ev, ck
STM8S003F3P6芯片
硬件I2C
产生问题:程序经常死机,偶尔正常,都是卡在I2C_CheckEvent函数里面,写了独立看门狗也没作用
搞的心塞,求大神打救
贴出程序:
#define I2C_Speed              100000
#define I2C1_SLAVE_ADDRESS7    0xA0
GPIO_Init(GPIOB, GPIO_PIN_4, GPIO_MODE_OUT_OD_HIZ_FAST);//PB4 I2C_SCL 功能引脚,总线的时钟脚,设为高速开漏高阻输出。
GPIO_Init(GPIOB, GPIO_PIN_5, GPIO_MODE_OUT_OD_HIZ_FAST);//PB5 I2C_SDA 功能引脚,总线的数据脚,设为高速开漏高阻输出
I2C总线写一个字节
void I2C_Write(unsigned char ADDR,unsigned char Wdata)
          ITStatus it_status;
                FlagStatus flag_status;
                I2C_GenerateSTART(ENABLE);
//I2C启动  /* Send STRAT condition */
                /* Test on EV5 and clear it */
                //while(!I2C_CheckEvent(I2C_EVENT_MASTER_START_SENT));
    while(!I2C_CheckEvent(I2C_EVENT_MASTER_MODE_SELECT ));
          I2C_Send7bitAddress(ADDR, I2C_DIRECTION_TX);   //写I2C从器件地址和写方式
                /* Test on EV6 and clear it */
    //while(!I2C_CheckEvent(I2C_EVENT_MASTER_ADDRESS_ACKED));
                while(!I2C_CheckEvent(I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED));
          I2C_SendData(Wdata);                                 //写数据到器件相应寄存器
                /* Test on EV8 and clear it */
    while (!I2C_CheckEvent(I2C_EVENT_MASTER_BYTE_TRANSMITTING));
          /* Send STOP condition */
    I2C_GenerateSTOP(ENABLE);
I2C总线读一个字节
返回:16位数值
unsigned int I2C_Read(unsigned char ADDR)
   unsigned int temp;
                unsigned char tmp1,tmp2;
                  /* While the bus is busy */
                while(I2C_GetFlagStatus(I2C_FLAG_BUSBUSY));
//I2C启动        /* Generate start & wait event detection */
                //while (!I2C_CheckEvent(I2C_EVENT_MASTER_START_SENT));
    while (!I2C_CheckEvent(I2C_EVENT_MASTER_MODE_SELECT));
                I2C_Send7bitAddress(ADDR, I2C_DIRECTION_RX);   //写I2C从器件地址和写方式
    //while (!I2C_CheckEvent(I2C_EVENT_MASTER_ADDRESS_ACKED));
                while (!I2C_CheckEvent(I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED));
                //I2C_ClearFlag(I2C_FLAG_ADDRESSSENTMATCHED);
                /* 2 variables are used to avoid any compiler optimization */
      /* Read the SR1 register */
      tmp1 = I2C->SR1;
      /* Read the SR3 register */
      tmp2 = I2C->SR3;
                while (!I2C_CheckEvent(I2C_EVENT_MASTER_BYTE_RECEIVED));
          temp = I2C_ReceiveData();//启动主I2C读方式
                             //读取I2C接收数据 第一字节
                /* Disable Acknowledgement */
                I2C_AcknowledgeConfig(I2C_ACK_NONE);
          temp = (temp<<8)+I2C_ReceiveData();        //读第二字节 合成16位数值
                I2C_GenerateSTOP(ENABLE);                      //I2C停止
                I2C_AcknowledgeConfig(I2C_ACK_CURR);                                    //启动主
I2C读方式,结果应答NO_ACK
          return temp;
gaoyang9992006 发表于 2015-8-14 16:26 | 显示全部楼层
坑爹的代码。我都难以理解了。
dirtwillfly 发表于 2015-8-14 16:27 | 显示全部楼层
坑爹的代码。我都难以理解了。
:lol
STARM 发表于 2015-8-14 23:50 | 显示全部楼层
  1. #define I2C_Speed              100000
  2. #define I2C1_SLAVE_ADDRESS7    0xA0
  3. void Init( void )
  4. {
  5.   //PB4 I2C_SCL 功能引脚,总线的时钟脚,设为高速开漏高阻输出。
  6.   GPIO_Init( GPIOB, GPIO_PIN_4, GPIO_MODE_OUT_OD_HIZ_FAST );
  7.   //PB5 I2C_SDA 功能引脚,总线的数据脚,设为高速开漏高阻输出
  8.   GPIO_Init( GPIOB, GPIO_PIN_5, GPIO_MODE_OUT_OD_HIZ_FAST );
  9. }
  10. /*********************************************
  11. I2C总线写一个字节
  12. **********************************************/
  13. void I2C_Write( unsigned char ADDR, unsigned char Wdata )
  14. {
  15.   ITStatus it_status;
  16.   FlagStatus flag_status;
  17.
  18.   I2C_GenerateSTART( ENABLE );
  19.
  20.   //I2C启动
  21.   /* Send STRAT condition */
  22.   /* Test on EV5 and clear it */
  23.   //while(!I2C_CheckEvent(I2C_EVENT_MASTER_START_SENT));
  24.   while ( !I2C_CheckEvent( I2C_EVENT_MASTER_MODE_SELECT ) )
  25.     ;
  26.
  27.   I2C_Send7bitAddress( ADDR, I2C_DIRECTION_TX );   //写I2C从器件地址和写方式
  28.   /* Test on EV6 and clear it */
  29.   //while(!I2C_CheckEvent(I2C_EVENT_MASTER_ADDRESS_ACKED));
  30.   while ( !I2C_CheckEvent( I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED ) )
  31.     ;
  32.
  33.   I2C_SendData( Wdata );                           //写数据到器件相应寄存器
  34.   /* Test on EV8 and clear it */
  35.   while ( !I2C_CheckEvent( I2C_EVENT_MASTER_BYTE_TRANSMITTING ) )
  36.     ;
  37.
  38.   /* Send STOP condition */
  39.   I2C_GenerateSTOP( ENABLE );
  40. }
  41. /*********************************************
  42. I2C总线读一个字节
  43. 返回:16位数值
  44. **********************************************/
  45. unsigned int I2C_Read( unsigned char ADDR )
  46. {
  47.   unsigned int temp;
  48.   unsigned char tmp1, tmp2;
  49.   /* While the bus is busy */
  50.   while ( I2C_GetFlagStatus( I2C_FLAG_BUSBUSY ) )
  51.     ;
  52.
  53.   I2C_GenerateSTART( ENABLE );
  54.
  55.   //I2C启动
  56.   /* Generate start & wait event detection */
  57.   /* Test on EV5 and clear it */
  58.   //while (!I2C_CheckEvent(I2C_EVENT_MASTER_START_SENT));
  59.   while ( !I2C_CheckEvent( I2C_EVENT_MASTER_MODE_SELECT ) )
  60.     ;
  61.
  62.   I2C_Send7bitAddress( ADDR, I2C_DIRECTION_RX );   //写I2C从器件地址和写方式
  63.   /* Test on EV6 and clear it */
  64.   //while (!I2C_CheckEvent(I2C_EVENT_MASTER_ADDRESS_ACKED));
  65.   while ( !I2C_CheckEvent( I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED ) )
  66.     ;
  67.   //I2C_ClearFlag(I2C_FLAG_ADDRESSSENTMATCHED);
  68.   /* 2 variables are used to avoid any compiler optimization */
  69.   /* Read the SR1 register */
  70.   tmp1 = I2C->SR1;
  71.   /* Read the SR3 register */
  72.   tmp2 = I2C->SR3;
  73.
  74.   while ( !I2C_CheckEvent( I2C_EVENT_MASTER_BYTE_RECEIVED ) )
  75.     ;
  76.   //启动主I2C读方式
  77.   temp = I2C_ReceiveData( );
  78.
  79.   //读取I2C接收数据 第一字节
  80.   /* Disable Acknowledgement */
  81.   I2C_AcknowledgeConfig( I2C_ACK_NONE );
  82.
  83.   while ( !I2C_CheckEvent( I2C_EVENT_MASTER_BYTE_RECEIVED ) )
  84.     ;
  85.   temp = ( temp << 8 ) + I2C_ReceiveData( );      //读第二字节 合成16位数值
  86.   I2C_GenerateSTOP( ENABLE );                     //I2C停止
  87.   I2C_AcknowledgeConfig( I2C_ACK_CURR );          //启动主I2C读方式,结果应答NO_ACK
  88.
  89.   return temp;
  90. }
正版长小强 发表于 2015-8-15 17:52 来自手机 | 显示全部楼层
在我印象中0系列的没有出过问题,工业环境。
 楼主| ww_升 发表于 2015-8-16 23:13 | 显示全部楼层
这个是你试过没问题的吗?
dragon_hn 发表于 2015-8-17 09:49 | 显示全部楼层
用while ( !I2C_CheckEvent( I2C_EVENT_MASTER_BYTE_RECEIVED ) )这种死循环等,效率不会比IO口模拟的I2C好,为啥不用IO口模拟的I2C呢?
aaa1125456 发表于 2015-8-18 16:21 | 显示全部楼层
你死在哪里了啊 ,看我帖子 有个调试好的 只是我的用的stm8l052r8 反正差不多
aaa1125456 发表于 2015-8-18 16:22 | 显示全部楼层
估计清 标志位没清干净
aaa1125456 发表于 2015-8-18 16:29 | 显示全部楼层
你发送完地址  准备接收的时候忘了发停止位了吧 I2C_GenerateSTOP(I2C1,ENABLE);
aaa1125456 发表于 2015-8-18 16:32 | 显示全部楼层
state_tmp102 tmp102_read(unsigned int *byte)
    unsigned int x = 0x0fff;
    unsigned int byte1 = 0,byte2 = 0;
    if(tmp102_tmpConversion() == ERROR_TMP102)
        return ERROR_TMP102;
    x = 0x0fff;
    while(I2C_GetFlagStatus(I2C1,I2C_FLAG_BUSY))                               //总线忙
        x -- ;
        if(x <= 1)
    I2C_GenerateSTART(I2C1,ENABLE);                                             //起始位
    x = 0x0fff;
    while(!I2C_CheckEvent(I2C1,I2C_EVENT_MASTER_MODE_SELECT))
        x -- ;
        if(x <= 1)
    I2C_Send7bitAddress(I2C1,0x90,I2C_Direction_Transmitter);                   //从地址
    x = 0x0fff;
    while(!I2C_CheckEvent(I2C1,I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED))
        x -- ;
        if(x <= 1)
    I2C_SendData(I2C1,0x00);                                                    // 指针地址
    x = 0x0fff;
    while(!I2C_CheckEvent(I2C1,I2C_EVENT_MASTER_BYTE_TRANSMITTED))
        x -- ;
        if(x <= 1)
    I2C_GenerateSTOP(I2C1,ENABLE);                                              //停止位
    x = 0x0fff;
        x -- ;
        if(x <= 1)
    x = 0x0fff;
        x -- ;
        if(x <= 1)
    I2C_Send7bitAddress(I2C1,0x91,I2C_Direction_Receiver);                      //从地址
    x = 0x0fff;
    while(!I2C_CheckEvent(I2C1,I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED))
        x -- ;
        if(x <= 1)
    x = 0x0fff;
    while(!I2C_CheckEvent(I2C1,I2C_EVENT_MASTER_BYTE_RECEIVED))                //接收到数据高位
        x -- ;
        if(x <= 1)
    byte1 = (unsigned char)I2C_ReceiveData(I2C1);
    x = 0x0fff;
    while(!I2C_CheckEvent(I2C1,I2C_EVENT_MASTER_BYTE_RECEIVED))                //接收到数据低位
        x -- ;
        if(x <= 1)
    byte2 = (unsigned char)I2C_ReceiveData(I2C1);
    I2C_AcknowledgeConfig(I2C1,DISABLE);
    *byte = (byte1 << 8) | byte2;
    *byte = *byte >>4;                                                          //高12位为温度
    return SUCCESS_TMP102;
643757107 发表于 2015-8-18 19:23 | 显示全部楼层
我习惯用SPI,不习惯用IIC,因为经常出差错。
STARM 发表于 2015-8-19 11:46 | 显示全部楼层
这个是你试过没问题的吗?
没有,网上找的仅供参考。
 楼主| ww_升 发表于 2015-8-19 16:36 | 显示全部楼层
用while ( !I2C_CheckEvent( I2C_EVENT_MASTER_BYTE_RECEIVED ) )这种死循环等,效率不会比IO口模拟的I2C好, ...
有没有模拟I2C程序可以参考下?
 楼主| ww_升 发表于 2015-8-19 16:38 | 显示全部楼层
估计清 标志位没清干净
请问哪里还需要清标志位呢?
 楼主| ww_升 发表于 2015-8-19 16:40 | 显示全部楼层
请问其中的ERROR_TMP102是在哪
lrhsx33 发表于 2015-8-21 09:40 | 显示全部楼层
淘宝20多元的逻辑分析仪 看看你的波形有没有问题,这那很方便学习用。
Thor9 发表于 2015-8-28 21:37 | 显示全部楼层
标志位清了没啊
zh113214 发表于 2015-8-29 08:42 来自手机 | 显示全部楼层
收藏了,问题一时还看不出,有时间再帮楼主给看看吧。
天灵灵地灵灵 发表于 2015-8-29 08:52 | 显示全部楼层
IIC的协议就没有SPI的好用。我是偏爱SPI的。
